Blackout Effectors Whetstone Phaser  [traced]
Sogum92
Been thanked: 13 times
Post by Sogum92 »
Dear,
I trace out Blackout Effectors Whetstone Phaser
Sorry, It is no Schematic, Only Layout
I attacted Wiring image
It is working
Thanks.
Blackout Effectors Whetstone Phaser_Wiring.jpg (60.39 KiB) Viewed 4600 times
pervyinthepark
Post by pervyinthepark »
might get around to making my own schematic for this :P
DanAmpora
Has thanked: 10 times
Been thanked: 27 times
Post by DanAmpora »
Beat you to it. Still kindly check if I've missed something. :lol:
DanAmpora
Post by DanAmpora »
This should be the correct one now, I forgot the output capacitor :oops:
whetstone v2 rev1.1.pdf
missed the output cap
(78.33 KiB) Downloaded 945 times
Sogum92
Post by Sogum92 »
DanAmpora wrote:This should be the correct one now, I forgot the output capacitor :oops:
Thanks a lot :)
mulekicker
Post by mulekicker »
Anyone with a working build from this schematic? I made the vero Alex put up over at tagboardeffects but no luck. Could definitely be my error but I can't find any.
Sogum92
Post by Sogum92 »
mulekicker wrote:Anyone with a working build from this schematic? I made the vero Alex put up over at tagboardeffects but no luck. Could definitely be my error but I can't find any.
My Layout & Wiring is 100% Working.
I will check your vero layout
mulekicker
Awesome. Thank you!
mulekicker
BTW. Thanks to Alex and MAO over at tagboardeffects, the vero layout is verified. I fucked up one of the pins on a 13700, duh! Thank you so much for doing this one, it's super sweet.
Sogum92
Post by Sogum92 »
mulekicker wrote:BTW. Thanks to Alex and MAO over at tagboardeffects, the vero layout is verified. I fucked up one of the pins on a 13700, duh! Thank you so much for doing this one, it's super sweet.
I see. Congratutation.
Original IC is NE5517N x 3
All TR is Fairchild.
Thanks.
Sogum92
Post by Sogum92 »
http://www.blackouteffectors.com/wp-con ... nual_1.pdf
The FIX setting kills the LFO completely.
In this setting the RATE knob will manually sweep through different points in the phasers sweep,
allowing for stuck-wah- like sounds, hollow telephone effects, and provides overall different approaches to tone shaping.
