DSM OmniCabSim
Re: DSM OmniCabSim
Postby Anjang » 29 Jan 2019, 10:12
its work for Guitar and Bass ??
Anjang
Re: DSM OmniCabSim
Postby J0K3RX » 29 Jan 2019, 21:08
Anjang wrote:its work for Guitar and Bass ??
http://www.youtube.com/watch?time_conti ... lBLAt-1bq4
J0K3RX
Has thanked: 330 times
Have thanks: 516 times
Re: DSM OmniCabSim
Postby temol » 02 Feb 2019, 19:59
What's the proper wiring of the GND lift with balanced output? Simple swith disconnecting pin1 from GND is good enough? I've also seen R and C in a different configurations along with a switch.
T.
temol
Has thanked: 13 times
Have thanks: 133 times
Re: DSM OmniCabSim
Postby Dsmnoisemaker » 02 Feb 2019, 20:52
I used both..both works..I think the one with the cap and resistor is more "legal" :D
Dsmnoisemaker
Have thanks: 11 times
Re: DSM OmniCabSim
Postby temol » 04 Feb 2019, 22:25
Thank you for the reply Daniel.
Here is my version of the sim, boxed and almost ready (I have to wire GND switch) .
T.
For this message the author temol has received thanks:
sixthfloor (06 Feb 2019, 11:45)
temol
Re: DSM OmniCabSim
Postby Dsmnoisemaker » 05 Feb 2019, 02:55
Be aware that some xlr jacks will have a chassis ground connection which will defeat the ground lift.
Dsmnoisemaker
Re: DSM OmniCabSim
Postby lukatosh » 11 Feb 2019, 01:50
Hi Daniel, Lucas here...from Chile. (Escribo en inglés por si alguien más se anima a responder).
may i ask some questions about your design?
What about using phantom power?
What would be the values of the resistor and capacitor in the "ground lift" arrangement? Different values are used on different schematics even when (apparently) they do the same function.
what about the power rating of the resistor? Here i'm looking at a PCB of a preamp that has XLR out and there is a 49R9 resistor (SMD) tied to pin 1 of the XLR jack
http://sound.whsites.net/p35-f2.gif
http://www.hansenaudio.se/Active%20DI%20box%201975.jpg
http://www.hansenaudio.se/Active%20DI-b ... ematic.png
https://i.warosu.org/data/diy/img/0008/ ... 357746.gif
https://www.prosoundweb.com/images/uplo ... igure6.jpg
Muchas gracias!!
lukatosh
Has thanked: 33 times
Have thanks: 180 times
Re: DSM OmniCabSim
Postby plush » 11 Feb 2019, 10:07
Hi Lukatosh
Based on my experience, most phantom power sources do not provide enough power for your preamps/cabsims to operate properly.
Resistor+cap @ ground lift is essential if you are using phantom power. Total ground lift will basically remove ground connection and phantom power won't work.
Knowing, that there should be DC signal path, the resistor must be of pretty low value, ~10-100R. Cap usually ~100n.
The purpose of the resistor is to lift the part of the circuit, preventing stray currents, which are pretty low at this point. Very typical implementation, changing the values won't make much difference.
plush
Has thanked: 28 times
Have thanks: 65 times
Re: DSM OmniCabSim
Postby temol » 12 Feb 2019, 12:00
Here is the build document for the BAJA version of the Omnicabsim - omnicabbaja-xlr_build_doc.pdf
T.
For this message the author temol has received thanks: 3
287m (27 Feb 2019, 02:52), digitalman (05 May 2019, 13:23), dikenn (05 Mar 2019, 10:26)
temol
Re: DSM OmniCabSim
Postby Ben N » 13 Feb 2019, 14:09
I see the space advantage of using a pair of quads, obviously, but it seems to me that NE5532 would make more sense for outputs--single, balanced or headphone. Given that this puppy may well be last in a signal chain before amp/pa/desk/interface, it ought to have a little line driving oomph.
BTW, Daniel, that 2015 video is of this version, right? Because, whatever its limitations, it sounds mega. :applause:
Ben N
Has thanked: 16 times
Have thanks: 12 times
Re: DSM OmniCabSim
Postby Dsmnoisemaker » 13 Feb 2019, 17:19
Yes is that version..:)
Dsmnoisemaker
Re: DSM OmniCabSim
Postby fersynes » 27 Feb 2019, 01:48
I just built the bajaman version and it sounds very great! A friend of mine have an origilan deluxe version that I will take borrow to compare.
The only thing I found is that the gain is too much that saturates the input of my presonus audio interface so easy. I tested with a POD HD 500X direct to the audiobox and run it trough my studio monitors. Trust me, you don´t want to take it of!
I will reply after compare them, thank you for this great pedal!
fersynes
Have thanks: 4 times
Re: DSM OmniCabSim
Postby fersynes » 02 Mar 2019, 16:25
O compared them and there are a lot of difference between them. First, whith the same parameters the bajaman's always sounds with less body, anyway with some tweak You can reach very similar results. Second, bajaman's have considerably a LOT of More gain. For the last, the deluxe version have all single potentiometers. I am out of city right now but next week I Will upload some pictures
For this message the author fersynes has received thanks:
smanq (04 Mar 2019, 00:48)
fersynes
Re: DSM OmniCabSim
Postby Ichabod_Crane » 06 Mar 2019, 14:47
I'm following the veroboard version here: http://tagboardeffects.blogspot.com/201 ... absim.html
It's still not verified and seems to have some problem. I checked quickly and the veroboard layout follows the same schematic on PedalPCB: https://www.pedalpcb.com/docs/UniCab.pdf
I don't know if the PedalPCB version is an exact clone of the original DSM OmniCab.
If someone built the veroboard layout just tell us, please. ;)
Ichabod_Crane
Has thanked: 18 times
Have thanks: 6 times
Re: DSM OmniCabSim
Postby fersynes » 06 Mar 2019, 19:56
Here are some pics of an original omnicab. The first noticeable difference is that de mid pot is different with the pedalpcb version but the others are right. Pretty different with the values of bajaman´s version
https://www.dropbox.com/sh/iuyvnbn8c5qp ... XLuqa?dl=0
For this message the author fersynes has received thanks: 2
Fabiosg (14 Mar 2019, 04:04), Lithium_Grim (06 Mar 2019, 20:31)
fersynes
Re: DSM OmniCabSim
Postby Ichabod_Crane » 06 Mar 2019, 20:18
Thanks! ;)
I don't know well the Bajaman' version because I didn't follow all the discussion, maybe I can read it soon.
I'd like to know if the PedalPCB is a real clone of the DSM, at least the main circuit of the sound. If just the Mid pot has a different it could be just a little detail we could modify.
I have interest in the tagboard veroboard laout because probably I may build that, usually I don't buy pcb.
Ichabod_Crane
Re: DSM OmniCabSim
Postby Lithium_Grim » 06 Mar 2019, 20:34
fersynes wrote:Here are some pics of an original omnicab. The first noticeable difference is that de mid pot is different with the pedalpcb version but the others are right. Pretty different with the values of bajaman´s version
Is this the same "era" version that the trace was based on or is it more recent?
Lithium_Grim
Have thanks: 14 times
Re: DSM OmniCabSim
Postby fersynes » 13 Mar 2019, 17:39
This is the Deluxe version, more recent with aux, phones out, etc
fersynes
Re: DSM OmniCabSim
Postby Fabiosg » 14 Mar 2019, 03:53
Pls, what is the phones amp IC ? I can't read it. Thank you.
Fabiosg
Re: DSM OmniCabSim
Postby fersynes » 14 Mar 2019, 20:04
Fabiosg wrote:Pls, what is the phones amp IC ? I can't read it. Thank you.
This is a LM386 but now they are using a MAX9722 for better
Fabiosg (15 Mar 2019, 00:47)
fersynes
Users browsing this forum: No registered users and 15 guests
