Steel panther pussy melter
Postby dv8r601 » 23 Oct 2018, 18:12
Link
Fast forward to 10:35 for the up close board shots.
Brad The guitologist just got his and takes one apart. Its hybrid smt thru hole, sounds sick as shit.
A500k gain
Bass(booty)c5k
Output 100k
Treble(sizzle)b10k
Opamp ca3240ez(dual bi-mos)
I did spot a sot23 n ch mosfet labeled mv near the clipping switch it also looks to have LEDs in the feedback loop
For this message the author dv8r601 has received thanks:
J0K3RX (05 Nov 2018, 15:49)
dv8r601
Has thanked: 397 times
Have thanks: 18 times
Re: Steel panther pussy melter
Postby FeVeR2112 » 09 Nov 2018, 16:35
Pedalpcb.com has a board available and the schematic if interested... I was asked to build one recently... meh.
FeVeR2112
Has thanked: 20 times
Have thanks: 30 times
Postby toneman » 13 Nov 2018, 00:43
Schemo doesnt seem to be posted on pedalpcb site yet. :-(
just was interested in the topology.....
inquiring minds and all that.........
Tone-to-the-Bone
toneman
Has thanked: 90 times
Have thanks: 19 times
Postby toneman » 26 Nov 2018, 21:08
Hey bugg,
i saw that u are shipping boards for the melter. any idea when the docs will be posted? thanks.
Tone-to-the-Bone
toneman
Postby bugg » 30 Nov 2018, 15:32
Yeah man, docs will be posted soon... I'm way behind again. :lol:
Been swapping some computers around all week, should be starting to play catch up very soon.
For this message the author bugg has received thanks: 2
dv8r601 (01 Dec 2018, 00:20), toneman (01 Dec 2018, 18:57)
bugg
Has thanked: 36 times
Have thanks: 228 times
Postby dv8r601 » 13 Dec 2018, 02:45
Build Doc w/ schematic, courtesy of the Majestic Bugg,
https://www.pedalpcb.com/docs/FaceMelter.pdf
dv8r601
Postby marshmellow » 13 Dec 2018, 16:46
No crackle? That is not ok. :|
And should have used the second opamp as output for proper melting.
marshmellow
Have thanks: 122 times
Postby plush » 13 Dec 2018, 17:00
So... No output from this power line? What's it's purpose then?
plush
Has thanked: 24 times
Have thanks: 39 times
Postby Intripped » 13 Dec 2018, 17:04
plush wrote:So... No output from this power line? What's it's purpose then?
that's how to properly connect an unused opamp
Intripped
Has thanked: 583 times
Have thanks: 215 times
Postby ppluis0 » 13 Dec 2018, 17:59
What is the need to use two resistive dividers to have two independent V/2 supply points ? :scratch:
ppluis0
Has thanked: 42 times
Have thanks: 85 times
Postby toneman » 13 Dec 2018, 18:31
ppluis0 wrote:What is the need to use two resistive dividers to have two independent V/2 supply points ? :scratch:
1) easier trace routing
2) less interaction between stages
3) something else(?)
Tone-to-the-Bone
toneman
Postby plush » 13 Dec 2018, 19:53
well, yeah, but it could definitely be used for a better purpose.
plush
Users browsing this forum: Chugs, Feral Feline, tete1805 and 9 guests
