Steel Panther - Pussy Melter  [traced]
bugg
my favorite amplifier: Fender Twin
Has thanked: 51 times
Been thanked: 336 times
Post by bugg »
R21 / R26 are 1K.. unfortunately no pic of the Sizzle pot value, but I'm fairly certain the schematic is correct for this revision.
Manfred
Has thanked: 1675 times
Been thanked: 1360 times
Post by Manfred »
I made a frequency response compare of the Sizzle filter with both potentiometer values (10 kOhms and 100 kOhm).
Thereby the value steps were 1 kOhm respectively 10 kOhms.
The 10 kOhms potentiometer gives more significant changes than the 100kOhms potentiometer does.
bugg
Post by bugg »
Manfred wrote:I made a frequency response compare of the Sizzle filter with both potentiometer values (10 kOhms and 100 kOhm).
Very cool, much appreciated! :D
10K was definitely used at some point so it'd certainly be worth trying it. I'm going to build a couple of these so I can A/B them and I'll make a note in the build docs about the alternate part values.
equinox
Post by equinox »
k. nice.
thanka guys! and thanka to the dude that did the video dissecting the unit. he got it from every single angle. there was 2 parts that were hard to find but they were all identifiable. the hardest was the 220R but it was caught also for a brief moment under a pot and you caught a glimpse between pot terminals!!! lol
id like to hear the A-B n look forward to the feedback Bugg. ill have to see if i have an extra 10k pot.
We are assuming no other changes like caps thou!
bugg
Post by bugg »
equinox wrote:We are assuming no other changes like caps thou!
Yep, of course. I'm just interested because of Manfreds simulations with the 10K pot in the existing circuit.
I have no doubt the traced values are correct for that revision of the circuit.
FeVeR2112
Has thanked: 47 times
Been thanked: 60 times
Post by FeVeR2112 »
One question I have is - why the CA3240EZ op amp? and what else would do the exact same job without changing values on the circuit?
Manfred
Post by Manfred »
FeVeR2112 wrote:One question I have is - why the CA3240EZ op amp? and what else would do the exact same job without changing values on the circuit?
-Very High Input Impedance (ZIN) 1.5TerraOhms (Typ)
-Very Low Input Current (II) 10pA (Typ) at +/-15V
- Slew rate ~30Volts/Microsecond
All of these properties make the CA3240EZ very close to a so-called "ideal Op-amp",
that means the circuit is nearly independent of the OP-amp and is almost determined by the external circuity.
- wide Common-Mode Input Voltage Range (VICR):
Can be Swung 0.5V Below Negative Supply Voltage Rail
That avoid issues due to OP-amp blocking.
plush
Has thanked: 36 times
Been thanked: 172 times
Post by plush »
Manfred wrote: - Slew rate ~30Volts/Microsecond
Oh, too good to be true. It's slew rate is 3x times lower, around 10 V/uS.
Manfred
Post by Manfred »
Thanks for the hint, you are right.
I got that value from an OP-amp list, that is obvious wrong.
I had a look at different datasheets and find a slew rate between 7 to 9V/us.
This gives a maximum frequency of ~248 kHz repectively ~318 KHz at an operating voltage of 9 Volts,
up to this frequencies the sine swing remain undistorted.
I think that is good enough for audio.
FeVeR2112
Post by FeVeR2112 »
While the op amp may be close to ideal, since we socket the IC, we can test out whether the Op Amp chosen here makes that difference in tone. From pin-out it is compatible with the usual OP Amp suspects like OPA2134, TL072, 4580....
I will breadboard it up and see what happens - maybe some feline fusion.
mutante
Post by mutante »
I builted it up with PCB from PedalPCB.com few months ago. Of course, Sizzle was A100k. My first feeling was something wrong. Cuz it's too much treble. I did not know why.. Should I change A100k to A10k for Sizzle to fix it?
plush
Post by plush »
mutante wrote:I builted it up with PCB from PedalPCB.com few months ago. Of course, Sizzle was A100k. My first feeling was something wrong. Cuz it's too much treble. I did not know why.. Should I change A100k to A10k for Sizzle to fix it?
Sure, you can try something with lower value, (50, 25 or 10k).
Also, if you are can't decide what to change, online circuit simulators with real time simulations (https://www.falstad.com/circuit/) can be very handy. You can simulate a part of a circuit to decide which part does the thing. I won't recommend them for simulating complicated circuits though.
Manfred
Post by Manfred »
Here the Bode-plots for further potentiometer values in steps of 10% for each.
The lower the potentiometer value and the larger is the change of the frequency depend on the potentiometer setting.
equinox
Post by equinox »
I liked the tone in the video that showed the 10k with the 1k resistors, soo I'll probably changing my components out to support this.
Manfred
Post by Manfred »
The fact is that the "Sizzle" control is a presence control, it is similar to the circuit on the Wampler Phanteon.
mutante
Post by mutante »
Sizzle potentiometer was changed to A10K a few minutes before. Everything is perfect. A10K is correct value.
equinox
Post by equinox »
Looking forward to it. Going to use A10k Sizzle and I'll put 10k's on R21 and R26. Then put 1k's across they 10k's and see which I like better which should total 990 ohm or within 1%, so should be close.
WHAT is the result of increasing or decreasing these resistors?
I think I messed up the last board as could not get working and 1st one with Buggs layout and design and put the switch on the wrong side and soldering and desoldering. This one is virgin, so I'm expecting no issues. Board should be today so I'll populate and hook up tonight
Manfred
Post by Manfred »
equinox wrote:Looking forward to it. Going to use A10k Sizzle and I'll put 10k's on R21 and R26. Then put 1k's across they 10k's and see which I like better which should total 990 ohm or within 1%, so should be close.
The change of both values to 10k does not influence the frequency response noticeably.
The filter formed by C2,R21,R19,R22 has a flat frequency response within the audio frequency range, with R21 = 10k the high roll-off frequency changes to about 16 kHz.
The change in value of R26 to 10k changes nothing.
stringline
Has thanked: 18 times
Post by stringline »
bugg wrote:R21 / R26 are 1K.. unfortunately no pic of the Sizzle pot value, but I'm fairly certain the schematic is correct for this revision.
[ Image ]
I saw the 3pdt or footswitch and asked myself "how can I get this?"
