Bixonic - Expandora  [traced]
Re: Bixonic - Expandora  [traced]
Postby choudy » 09 Feb 2010, 21:32
Thanks for reply.
I've already found an error. One of LM308 was halfway broken. At least i've designed new pcb layout and found complete schematics (thanks archive.org) :-)
For this message the author choudy has received thanks: 3
fuzzlab (18 Sep 2011, 22:31), jb351 (20 Jan 2011, 02:23), Tchock (28 Sep 2015, 07:18)
choudy
Have thanks: 4 times
Postby Renegadrian » 10 Feb 2010, 15:59
So summing it up, has anyone successfully built an Expandora (ver.1)?!
Are those schems/layouts verified?!
Renegadrian
Has thanked: 16 times
Have thanks: 10 times
Postby choudy » 16 Feb 2010, 23:58
Yeah, I've finally build Bixonic Expandora. Posted schematic is verified and better than one from RG Keen site. I have to do some final cleanup in layout, so please be patient.
choudy
Postby Renegadrian » 17 Feb 2010, 01:58
WOW :applause:
I could need to build one for a friend in the next weeks - keep us posted of new layouts!
Thank you!
Renegadrian
Postby Zztop128 » 16 Apr 2010, 09:36
Great pedal, I've got the original and it does sound great.
For wich reason is the RN2206 used?
And isn't R11(1M) too big?
Zztop128
Postby Zztop128 » 09 Jun 2010, 17:28
I've just build this pedal.
I used an LDR and an LED instead of using the Sharp opto unit. That was not a very good idea, so I ordered a H11F2 optocoupler. I also discovered that the 2N3703 isn't doing anythng. I assume that it should amplify the signal it gets from IC3?
Zztop128
Postby caspercody » 12 Jun 2010, 17:08
Does anyone know the difference from the original to the EXP-2001? The 2001 has a drive pot on it.
caspercody
Has thanked: 29 times
Have thanks: 37 times
Postby cbriere » 12 Jun 2010, 17:32
caspercody wrote:Does anyone know the difference from the original to the EXP-2001? The 2001 has a drive pot on it.
I have a EXp-2001, and i open it up to see what is inside.
The IC is not a 308, it 's a tlo72
i can put pics here if needed.
I should also receive the schamtics soon.
cbriere
Postby caspercody » 13 Jun 2010, 01:46
Thanks! Would love to see pictures, and the schematic.
caspercody
Postby caspercody » 22 Nov 2010, 01:28
Any news on the 2001 schematic, or pictures?
Rob
caspercody
Postby cbriere » 22 Nov 2010, 01:46
caspercody wrote:Any news on the 2001 schematic, or pictures?
Rob
it is here
http://freestompboxes.org/viewtopic.php?f=1&t=9834&p=106768&hilit=bixonic#p106768
cbriere
Postby caspercody » 22 Nov 2010, 02:15
Thanks! Has anyone made it, to verify it is correct?
caspercody
Postby Barry » 13 Apr 2011, 02:40
Wouldn't that be a TL071?
Barry
Postby azrael » 09 Jul 2011, 17:48
Does anyone have the transfer to choudy's layout?
azrael
Has thanked: 33 times
Have thanks: 93 times
Postby choudy » 10 Jul 2011, 10:53
Here it is.
redstone iii (17 Jul 2011, 08:24)
choudy
Postby quickapple » 16 Sep 2011, 08:16
Hi
What is the CI noted in Figure 5, I want to try this pattern. :D
quickapple
Postby mich » 18 Sep 2011, 03:37
4u7
mich
Have thanks: 23 times
Postby quickapple » 18 Sep 2011, 09:42
But my poor english would say: IC noted 5 in the schematic
Sorry
quickapple
Postby Joe L » 12 Feb 2012, 22:10
Renegadrian wrote:So summing it up, has anyone successfully built an Expandora (ver.1)?!
Almost finished with mine. I found a direct cross reference to the Toshiba RN2206 transistor used to sink the current through the opto. The NTE2370 even has the correct internal bias resistors and specs so it should work perfectly. I found Newark and Moyer Electronics stock the part but am still looking to see if Mouser has a direct cross reference in a different brand.
..Joe L
Joe L
Users browsing this forum: ErkBerg, frooshontay, soggybag and 12 guests
