Friedman BE50 schematic needed
Postby POTL » 13 Feb 2019, 22:35
Anybody have?
POTL
Has thanked: 65 times
Have thanks: 61 times
Re: Friedman BE50 schematic needed
Postby karul » 14 Mar 2019, 22:43
BE50 improved clean v.135 switch fix
BE50 Deluxe V1.5 and
BE100
https://ampgarage.com/forum/viewtopic.php?f=9&t=31026
Schematic was done by some guy Patrice on SLOclone forum:
http://www.slocloneforums.com
If you want to register to this forum, there is a question - 'What is the name of Joey's favorite cat?'
Answer is: 21ap14ax3/4
For this message the author karul has received thanks: 3
287m (15 Mar 2019, 11:39), Intripped (18 Mar 2019, 09:22), plush (15 Mar 2019, 09:14)
karul
Has thanked: 282 times
Have thanks: 178 times
Postby POTL » 15 Mar 2019, 16:20
Are these exactly current schemes?
I am confused by the voltage divider after the first cascade
68K / 10M
This gives a voltage drop of 24dB, the first stage is something like a treble booster with a gain of about 12dB, more like a lightweight heater and tone corrector.
I did not play friedman - does the HBE mode really give a small boost? I thought it would be a full fledged gain giving much more distortion.
POTL
Postby plush » 15 Mar 2019, 16:33
Year 2019, yet still no input protection...
plush
Has thanked: 29 times
Have thanks: 82 times
Postby karul » 15 Mar 2019, 18:30
karul
Postby POTL » 15 Mar 2019, 22:19
plush wrote:Year 2019, yet still no input protection...
Are you talking about this?
To be honest, I saw a lot of schemes for new models of amplifiers and pedals, and nowhere did I encounter protection at the input.
Perhaps this is overengineering.
POTL
Postby plush » 15 Mar 2019, 22:44
Nah, I was talking about protecting the meatbag, not the amp.
For this message the author plush has received thanks:
J0K3RX (17 Mar 2019, 00:34)
plush
Postby Optical » 16 Mar 2019, 23:45
POTL wrote:Are these exactly current schemes?
68K / 10M
No. The 10M is to prevent pops from the relay switching. Look up stream
Optical
Have thanks: 15 times
Postby POTL » 17 Mar 2019, 20:16
68K / 10M
I was sealed, I meant the voltage divider 1M + 68K
POTL
Postby Optical » 17 Mar 2019, 21:54
Yes the 1M/68k divider is correct.
The BE preamp is already fairly gainy and does not need much more push, the HBE boost is all it really needs.
Optical
Users browsing this forum: andy-h-h, puffmajster and 12 guests
