BOSS CE-3 Signal Allowance HEPL ME!)
Postby midiez1997 » 23 Feb 2019, 15:43
Hi guys! My name is Dima, and I am their Belarus. So sorry for my incorrect English)
I am the owner japanese BOSS CE-3. And the problem is that when you turn on the effect, the output A: signal from the output sags on the volume.
The output B: signal from the output -such a problem does not have, with him everything is in order.
The pedal is completely original, the only thing I changed electrolytic capacitors there to eliminate the background.
I think to check the oscillograms and compare with the factory ones, but I heard that they often have this drawback. And can i play around with the denomination of the elements and eliminate this drawback?
Thank you all in advance!)
midiez1997
Users browsing this forum: cbriere, fuzzbunny, Google [Bot] and 23 guests
