EQD BOWS signal path schematic
Postby Manfred » 05 Jun 2019, 12:56
Before longer time I had got an EQD bows for repair, now I found my handwritten drawings from the signal path of it.
Here the redrewn schematic:
For this message the author Manfred has received thanks: 7
Intripped (08 Jun 2019, 17:04), jhergonz (05 Jun 2019, 14:58), karul (05 Jun 2019, 21:40), mirosol (05 Jun 2019, 16:41), roseblood11 (05 Jun 2019, 21:52), sixthfloor (06 Jun 2019, 09:52), storyboardist (07 Jun 2019, 15:16)
Manfred
Has thanked: 1044 times
Have thanks: 626 times
Re: EQD BOWS signal path schematic
Postby Manfred » 06 Jun 2019, 08:08
Here the schematic once again with the read voltages.
For this message the author Manfred has received thanks: 3
287m (06 Jun 2019, 10:07), Intripped (08 Jun 2019, 17:04), sixthfloor (06 Jun 2019, 09:52)
Manfred
Postby Manfred » 06 Jun 2019, 19:29
Here the shot that I have made.
jalmonsalmon (07 Jun 2019, 03:59)
Manfred
Postby Seiche » 08 Jun 2019, 11:06
So this is an NPN rangemaster with full range mod?
Only the transistors emitter seems to be biased differently (100R instead of 3k9).
Seiche
Has thanked: 264 times
Have thanks: 214 times
Postby Manfred » 10 Jun 2019, 01:00
Seiche wrote:So this is an NPN rangemaster with full range mod?
The BOWS has a more symmetrical clipping than the NPN rangmaster.
Seiche (10 Jun 2019, 16:37)
Manfred
Postby Manfred » 10 Jun 2019, 14:44
I built the circuit on breadboard for measuring the values.
It was hard to find a OC139 of a bunch of 100, which matches nearly the read DC-values of the orignal device,
there fore is necessary to set the bias setting for the rest of the bunch.
Seiche (10 Jun 2019, 16:38)
Manfred
Postby Seiche » 10 Jun 2019, 16:39
So they are probably using a transistor with Hfe = 35, am I understanding this correctly?
Seiche
Postby Manfred » 10 Jun 2019, 19:55
Seiche wrote:So they are probably using a transistor with Hfe = 35, am I understanding this correctly?
Yes, it is.
I took out the transistor of the circuit after the measurement and then I read its values by means of my semiconductor analyzer.
Manfred
Postby Manfred » 11 Jun 2019, 00:44
I remembered having a bunch of BF128C transistors which have a lower Hfe, so I have replace the OC139 by it for a test.
The input seriell circuit made of the 10k resistor and the 100n capacitor was to be adjusted to maintain the gain and the frequency response.
I replaced 10k by 27k and 100n by 47n.
The result looks not bad, but maybe a bias adaption is needed to obtain better results.
Seiche (13 Jun 2019, 10:34)
Manfred
Postby Manfred » 13 Jun 2019, 21:57
I must correct the transistor type, I had mistakenly read B instead S.
It is the SF128 transistor made in GDR.
According to sources in the Internet it could be can be replaced by a BC140.
Seiche (14 Jun 2019, 05:34)
Manfred
Postby Manfred » 14 Jun 2019, 05:59
In order to make a circuit comparison, I just ordered BC140-6 and BC140-10 transitors.
Manfred
Postby Manfred » 20 Jun 2019, 14:55
As anounced, the comparation trace graphs using the BC140-6 and the SF128C transistors.
The resulst are very similar.
Manfred
Users browsing this forum: MBens11, mireg and 11 guests
