Pete Cornish - Mystery Pedal [gooped][x-ray'd]
Postby Seiche » 17 Jun 2019, 19:20
:lol:
so Aion posted two pictures of an "original design" cornish pedal, one a gooped gutshot and the madlad actually apparently x-rayed the PCB lol. Not anymore info though.
I wonder what it actually is. I can see one or two opamps and two transistors, as well as a trimpot.
Seiche
Has thanked: 259 times
Have thanks: 212 times
Re: Pete Cornish - Mystery Pedal [gooped][x-ray'd]
Postby aionios » 18 Jun 2019, 15:08
I'll let you guys speculate for awhile... but tracing is complete on my end and a PCB (including schematic and more photos of the trace) will be released in about 2 months, so you won't have to wait long ;)
It's very much an original circuit though. I was surprised since most of his are either value-tweaked clones or hybrids.
Aion Electronics - DIY PCB projects for classic and obscure circuits
For this message the author aionios has received thanks: 4
Frank_NH (18 Jun 2019, 17:10), LowEnd (11 Jul 2019, 03:05), Seiche (18 Jun 2019, 17:47), Zokk (21 Jun 2019, 08:15)
aionios
Have thanks: 62 times
Postby Seiche » 18 Jun 2019, 17:49
How do you infer component values from an xray or gooped board? I assume you degooped it, or maybe took it apart and measured it?
Seiche
Postby aionios » 18 Jun 2019, 19:18
Seiche wrote:How do you infer component values from an xray or gooped board? I assume you degooped it, or maybe took it apart and measured it?
The X-ray was a first pass at mapping out the circuit topology to see if it was even worth the effort to degoop. If it turned out to be a clone of something already known, or close (Cornish described it as original - but you know how that can go) then we might not have gone through the trouble to tear it apart further. But, it was indeed original so we persevered!
aionios
Postby FeVeR2112 » 19 Jun 2019, 03:27
What Cornish pedal model is this of?
FeVeR2112
Has thanked: 22 times
Have thanks: 34 times
Postby gght » 19 Jun 2019, 18:59
OC-1?
gght
Have thanks: 8 times
Postby FeVeR2112 » 19 Jun 2019, 19:31
As it is a "new and original design".... I google searched the Cornish site and found these models that claim to be original:
BD-1
CC-1
OC-1
3Q-1
hmmmm.... which could this be then? oh... the suspense.
FeVeR2112
Postby Seiche » 19 Jun 2019, 19:46
From the website:
BD-1 - Bass Driver
CC-1 - Crunch Pedal
OC-1 - Optical Compressor
3Q-1 - Active EQ with Linear Boost
What sounds most likely? The x-ray doesn't look like an optical compressor tbh, I don't see an optocoupler.
Seiche
Postby trixdropd » 20 Jun 2019, 23:41
That pcb trace design under the ic though lol
trixdropd
Postby Seiche » 21 Jun 2019, 05:50
trixdropd wrote:That pcb trace design under the ic though lol
Yeah what is that? Or is that inside the IC?
Seiche
Postby plush » 21 Jun 2019, 08:02
It's not the pcb, it's the insides of the IC.
plush
Has thanked: 28 times
Have thanks: 60 times
Postby johnk » 13 Jul 2019, 19:16
no schematic yet?
johnk
Has thanked: 32 times
Have thanks: 273 times
Postby aionios » 14 Jul 2019, 21:39
johnk wrote:no schematic yet?
Not yet, but soon. I'm doing up a PCB for it and will pull back the curtain on everything at once :)
johnk (14 Jul 2019, 22:38)
aionios
Users browsing this forum: jt, pietro_moog, vtguedes and 14 guests
