Benson Preamp  [traced]
Re: Benson Preamp
Postby Nocentelli » 18 Aug 2019, 15:15
knottypine wrote:Could I use 2N5457 in lieu of J201?
May be worth trying
knottypine wrote:How about BS170 MOSfet?
Probably won't work
Nocentelli
Has thanked: 894 times
Have thanks: 855 times
Re: Benson Preamp
Postby temol » 18 Aug 2019, 20:10
Here's some Ltspice simulation screenshots.
Comparison between J201 and 2N5457. Drain resistor values adjusted to get the same voltages as with J201.
Frequency response
Output sine.
Sine at drain of Q1. 2N5457 in green.
Sine at drain of Q2. 2N5457 in green.
Sine at drain of Q3. 2N5457 in green.
T.
temol
Has thanked: 13 times
Have thanks: 134 times
Re: Benson Preamp
Postby Manfred » 19 Aug 2019, 08:55
I tried to adapt the circuit values in order to get the same stage gains using the 2n5457 Fets.
The adaption of the drain and source resistors is only possible when the supply voltage is 18 Volts.
Manfred
Has thanked: 1040 times
Have thanks: 624 times
Re: Benson Preamp
Postby temol » 19 Aug 2019, 15:51
It may be cheaper to use charge pump than buy MMBFJ201 transistors :)
T.
temol
Re: Benson Preamp  [traced]
Postby Manfred » 19 Aug 2019, 18:19
I renamed the components of the Wampler Output circuit.
I made these Layouts according the componet names in the schematics.
BensonPreampLayoutComponets.pdf
BensonPreampLayoutSolderSide.pdf
BensonPreampLayoutSolderSideMirrored.pdf
BensonPreampLayoutWamplerModComponets.pdf
BensonPreampLayoutWamplerModSolderSide.pdf
BensonPreampLayoutWamplerModSolderSideMirrored.pdf
SprintLayout6 file contains both versions:
BensonPreamp.zip
For this message the author Manfred has received thanks: 2
atalas (20 Aug 2019, 05:26), Nocentelli (24 Aug 2019, 11:12)
Manfred
Re: Benson Preamp
Postby knottypine » 20 Aug 2019, 05:04
Because I am a bit impatient I went ahead and wired one up with what I had so buckle up...
I didn’t have a:
250pf so I used a 300pf
470pf so I used a 680pf
J201 so I used 2N5457 (Q2 & Q3 biased at 4V)
2M so I used a 1M for the bass pot
What I’ve observed is....
Decent output volume
Very subtle (if any) Bass response
Treble control seems to work in reverse (fully clockwise the sound is “dampened”, moving it counter-clockwise “brightens” the sound)
Drive is pretty distorted even on the lowest settings / starts to squeal past 12 o’clock
I have on order the correct values/replacements so I will implement and report back.
I am very excited at the potential of this circuit and I appreciate this forum and everyone involved.
Cheers!
knottypine
Re: Benson Preamp
Postby atalas » 20 Aug 2019, 05:27
temol wrote:It may be cheaper to use charge pump than buy MMBFJ201 transistors :)
T.
More importantly, it may make other, more readily available JFETS viable.
atalas
Have thanks: 22 times
Re: Benson Preamp
Postby Manfred » 22 Aug 2019, 08:39
I tried different drain and source resistors at supply voltages greater than 9 Volts.
It is at least 30 Volts requiererd to achieve the stage gain and the clipping behaviour using the 2N5457 Jfet.
Manfred
Re: Benson Preamp
Postby knottypine » 04 Sep 2019, 02:24
Checking in!
Switched Bass from 1M to 2M
Just replaced the 2N5457’s with J201’s
Q3 & Q2 are biased at 4v
Q1 measured at 6v
Also I had to rearrange the legs on the on the J201 to DSG (not DGS) to get Output. So I am not sure if the pin out on the strip board layout is correct
Overall more usable gain and more noticeable bass.
knottypine
Re: Benson Preamp
Postby FlyingWild » 04 Sep 2019, 08:44
Hi Knttypine,
Does it still squeal when the drive is turned up beyond 12 O'clock?
Pedal PCB has leg 3 of the treble pot connected to the 22nF cap, 2 to ground and 1 not connected, is this how you had yours wired up?
FlyingWild
Re: Benson Preamp
Postby modman » 04 Sep 2019, 10:45
Manfred wrote:I tried to adapt the circuit values in order to get the same stage gains using the 2n5457 Fets.
We are back home!
http://runoffgroove.com/sd.html
However, modding it to Wampler Plexithingie should not be the subject of this thread.
Also, whatever the builder says, don't believe him until you seen traces and values.
For this message the author modman has received thanks:
alexradium (13 Sep 2019, 08:02)
Has thanked: 3267 times
Have thanks: 608 times
Re: Benson Preamp
Postby knottypine » 05 Sep 2019, 02:48
FlyingWild wrote:Hi Knttypine,
I got it to stop squealing once I used the right value on the 250pf and 470pf caps.
Kinda curious why my bass and treble boost when the knobs are CCW
knottypine
Re: Benson Preamp
Postby atalas » 05 Sep 2019, 09:53
knottypine wrote:Kinda curious why my bass and treble boost when the knobs are CCW
Reverse your lug 1 and 3 connections on your pot, and the jumpers if you installed them.
We are back home!
[ Image ]
We actually started with traces, and eventually got measured values. Benson only came in a made a few small clarifications at the end.
The schematic I last posted should be accurate.
But you're not wrong, and as I stated earlier, nothing revolutionary in this pedal.
atalas
Re: Benson Preamp
Postby knottypine » 07 Sep 2019, 03:39
- I did exactly this and the sweep functions as it should. Thank you.
knottypine
Re: Benson Preamp
Postby knottypine » 07 Sep 2019, 03:43
Is there a suggested voltage for Q1?
Pedal sounds pretty nice in front of my Music Man with Bass, Mid, and Treble set to 5
knottypine
Re: Benson Preamp
Postby atalas » 07 Sep 2019, 07:21
knottypine wrote:Is there a suggested voltage for Q1?
~5V, or if you have a bunch of J201, set the source resistance to 12K and swap JFETs until you get one sit at 5V at the source. This will achieve a closer sonic result than just changing the source resistance to achieve 5V for whatever JFET is in there now.
atalas
Re: Benson Preamp
Postby Sm4sh » 13 Sep 2019, 19:36
Hey !
@Bugg, I'm little confused here.
Why did you use a dual gang pot for the bass on your layout ?
https://www.pedalpcb.com/product/sobpreamp/
Sm4sh
Have thanks: 2 times
Re: Benson Preamp
Postby plush » 13 Sep 2019, 19:56
Sm4sh wrote:Hey !
1M dual pots are way easier to get, than single 2M.
When stacked, dual 1M emulates single 2M.
For this message the author plush has received thanks: 2
bugg (14 Sep 2019, 23:50), Sm4sh (13 Sep 2019, 20:03)
plush
Has thanked: 28 times
Have thanks: 73 times
Re: Benson Preamp
Postby Sm4sh » 13 Sep 2019, 20:05
plush wrote:
Sm4sh wrote:Hey !
Right!!! :slap:
Thank you! :thumbsup
For this message the author Sm4sh has received thanks:
bugg (14 Sep 2019, 23:51)
Sm4sh
Re: Benson Preamp
Postby andy-h-h » 16 Sep 2019, 09:22
Any suggestions as to what capacitors should be used to get the same response using a 1M pot instead of 2M or a dual 1M? :hmmm:
Thanks.
andy-h-h
Have thanks: 5 times
Users browsing this forum: echohazard and 9 guests
