Benson Preamp  [traced]
Re: Benson Preamp
Postby bmxguitarsbmx » 16 Sep 2019, 18:37
andy-h-h wrote:Any suggestions as to what capacitors should be used to get the same response using a 1M pot instead of 2M or a dual 1M? :hmmm:
Thanks.
Scale all resistors by 0.5, all capacitors by 2. I do mean all resistors and capacitors in this network, including gain pot.
bmxguitarsbmx
Has thanked: 283 times
Have thanks: 87 times
Re: Benson Preamp
Postby knottypine » 29 Sep 2019, 01:34
atalas wrote:
knottypine wrote:Is there a suggested voltage for Q1?
Pedal sounds pretty nice in front of my Music Man with Bass, Mid, and Treble set to 5
~5V, or if you have a bunch of J201, set the source resistance to 12K and swap JFETs until you get one sit at 5V at the source. This will achieve a closer sonic result than just changing the source resistance to achieve 5V for whatever JFET is in there now.
Could someone mock up a stripboard layout with a trimmer for Q1? ✌️
knottypine
Re: Benson Preamp
Postby atalas » 09 Oct 2019, 04:59
You could just bodge in a trimmer instead of the 12k. Maybe use short little jumpers, or even make it an external control.
atalas
Have thanks: 22 times
Previous
Users browsing this forum: echohazard and 9 guests
