Xotic - BB+
telefone
Post by telefone »
anybody trace one yet? Looks like the 'A' channel uses a single green LED and the 'B' channel uses a single 2N7000 for distortion 'color'.
AL
Post by AL »
telefone,
Check the top of the page in this section under announcements. There are a pile of schematics and gutshots.
AL
telefone
Post by telefone »
AL wrote:telefone,
AL
Right, and this isn't one of them, so your point is?
AL
Post by AL »
telefone wrote:
AL wrote:telefone,
AL
There is a shcem for an Xotic BB preamp. Is that not the same thing? My apologies for trying to be helpful. :roll:
AL
telefone
Post by telefone »
AL wrote:
telefone wrote:
AL wrote:telefone,
AL
AL
No, it's not the same thing. The BB+ has 2 channels and you can switch the order of them. The 2 channels are different than the original BB preamp (so I don't really understand the similar naming). There doesn't seem to be much interest in it.
telefone
Post by telefone »
Cow4prez
Post by Cow4prez »
telefone wrote:anybody trace one yet
maybe you can be the first ;)
I wonder why they had to use 2 separate boards or just use a multilayer PCB. This seems more inefficient.
YuGi
Been thanked: 25 times
Post by YuGi »
telefone wrote:anybody trace one yet? Looks like the 'A' channel uses a single green LED and the 'B' channel uses a single 2N7000 for distortion 'color'.
:hmmm: I quickly analyzed the pictures and does not seem to be so. Channel A has uno green LED + 2 diodes (one black like a 1N4001 and one ike a 1N914 but blue :scratch: ). Channel B has 2 blue diodes and 2 black diodes.
Someone knows more exactly the diodes used? I'm interested to a clone of this thing :mrgreen:
Jack Deville
Completed builds: too many. too many.
Been thanked: 86 times
Post by Jack Deville »
Who does the Xotic layouts?!
I'm a "professional."
Buy my products and make me rich.
www.jackdeville.com
MoonWatcher
Has thanked: 40 times
Been thanked: 52 times
Post by MoonWatcher »
YuGi wrote:one ike a 1N914 but blue :scratch: ). Channel B has 2 blue diodes and 2 black diodes.
Blue diodes may indicate that they are Schottky barrier diodes. If you can get a number off of their bodies, you'll be good to go.
YuGi
Post by YuGi »
I find this photo on the net, unfortunately, only about A channel :mrgreen:
So I think the black diode is a 1N4005 :hmmm:, the blue one may be also a zener, but what means 46?
Mike31
Post by Mike31 »
Probably a BAT46 which is a Schottky.
That is definitely a different combo, a silicon/schottky against a green led.
YuGi
Post by YuGi »
Mike31 wrote:Probably a BAT46 which is a Schottky.
:applause:
B channel is probably silicon/schottky against silicon/schottky. :thumbsup
YuGi
Post by YuGi »
:applause:
:hmmm: in the channal B circuit there is a transistor in series with the diodes (it seems that only pin 1 and 3 are connected).. maybe the 2N7000 mentioned by telefone?
Then the branchs are:
- 1N4005 - BAT46 -
- BAT46 - 1N4005 - 2N7000 -
jimbob_400
Post by jimbob_400 »
:applause:
- 1N4005 - BAT46 -
That would be my guess also.
I wonder what was crossing their minds when they decided to put schottky, 1n and a mosfet together :hmmm:
YuGi
Post by YuGi »
I think to reach a particular "forward voltage drop".
There is another transistor in the channel A side, but it do not seems to be connected to the diodes.. maybe a buffer :hmmm:
jimbob_400
Does anyone own one of these or have any more gut shots? We have some part values to find :D
jstbrowsin
Grease Monkey
Has thanked: 65 times
Post by jstbrowsin »
bumpty bump I hope someone responds to this I'm keen as to make this one. [smilie=a_teeth.gif]
kev01 wrote:This one wins the gooooooooooop award. That has more silicone than Pamela Anderson.
ct88
Been thanked: 9 times
Post by ct88 »
andrewwoo
Post by andrewwoo »
Has anyone built this? I've always wanted a standalone pedal of the Channel B side of the BB+. Not sure if it's even possible.
