highway jones wrote:I built this with a JRC386 and it sounds fantastic! I had none of the issues I have seen described by some others here. However, the max gain is bunched up at the very end of the gain pot's rotation but, I don't really use that much gain anyway. The only thing I would like to change is to lower the gain at the lowest pot setting. Where is a good place to start to address this? The 470R resistor?
If im not mistaken you can disconnect pin 8 from 1 and lower the gain considerbly. I'm not sure how this will alter the sound, but thats how its done with the noisy cricket and the other circuits using the lm386.
