Wampler - Plextortion  [traced]
Postby call1800ksmyazz » 12 Jul 2007, 15:18
Ah cool Brian. I was wondering about the Plextortion. Sounded good. Same with the other Plexi pedal you sell.
call1800ksmyazz
Postby indyguitarist » 12 Jul 2007, 16:22
bump
indyguitarist
Have thanks: 158 times
Postby call1800ksmyazz » 12 Jul 2007, 16:26
Oh awesome again :D . Seems like you have been doing great! :D
call1800ksmyazz
Postby plexilover » 14 Oct 2008, 13:03
hey guys,
anyone heard about? schematic?
greetings
andy
plexilover
Have thanks: 2 times
Re: Wampler - Plextortion
Postby analogguru » 14 Oct 2008, 14:20
The search function is your friend - rumours say:
plextortion: marshall guv type circuit (1st version) with treble boost circuit on the end.
Have thanks: 116 times
Postby plexilover » 14 Oct 2008, 14:27
thanks but i didnt find anything on search function ;)
plexilover
Postby PurplePeopleEater » 14 Oct 2008, 16:23
plexilover wrote:thanks but i didnt find anything on search function ;)
The two pertinent comments I found searching for "Plextortion" were the aforementioned "Guv w/ treble boost" , and another where Brian says it's a "tweaked 1st version Guv".
I hope this helps, at least a little.
PurplePeopleEater
Postby indyguitarist » 15 Oct 2008, 03:38
I'm flattered that my pedal was brought up. :)
I'll start from the beginning - I was always a huge fan of the old blues pearl 'perplexed' pedal, which is a modified guv'nor.
Let's start with this schem: http://www.freeinfosociety.com/electron ... php?id=476
The first version is a modded guv'nor, no additional parts.
c5: .22
r16: 1m, add 100pf in parallel.
remove c4
r6: 470k
c8: 100pf
c9: 1uf
r7: 10k
r1: 1k
c1: .22uf
diodes: 1n914+led, 1n914 on the other side.
IC: tl072 and 5532 on later versions.
500ka volume - iirc - I have since lost my original schem in a hard drive crash. :(
That didn't have enough highs, so I added a high boosting stage, similar to the tubescreamer tone control type, except it didn't tie back into the signal before the opamp (no additional low pass), this was called the 'presence'.
The next version had the same thing, except I added a basic jfet gain stage after that to boost the volume.
Next version, I dropped the presence control and added these changes:
r7: 1k
diodes: led's
c5: .1uf
c2: 47pf
ic: lm833
The last version is about the same - I *think* r8 is just a jumper IIRC.
component types: metal film
ic: 4580
der ya go! It's a good sounding little circuit, and the first and last "clonish" type of circuit I did.
bw
For this message the author indyguitarist has received thanks:
dv8r601 (01 Sep 2017, 09:00)
indyguitarist
Postby indyguitarist » 15 Oct 2008, 03:40
I forgot - last two versions are 100ka volume pots, at the end of the jfet. resistors going to the jfet were 100k into it, 470k to ground IIRC - you may have to fiddle with the 470k for optimum tone though - I'm going from memory here. :)
bw
indyguitarist
Postby indyguitarist » 15 Oct 2008, 04:22
I take it back - second 'cloneish' of sorts - analogecho, which is a modified delay that francisco of tonepad has on his site (i forget the name of it), but I pay francisco for it. :)
bw
indyguitarist
Postby MoreCowbell » 15 Oct 2008, 05:50
Just sayin' "hello" Brian ! I hope all is well....and thanks for the info !
AC
MoreCowbell
Have thanks: 11 times
Postby ieatyouforbreakfast » 15 Oct 2008, 06:25
This is definitely why Brian is one of my favorites in the industry right now. Awesome.
ieatyouforbreakfast
Have thanks: 10 times
Postby ShortScaleMike » 15 Oct 2008, 11:42
Thanks Brian, I'm a big fan of this pedal, I'll definitely be breadboarding the design shortly.
ShortScaleMike
Has thanked: 19 times
Have thanks: 92 times
Postby plexilover » 15 Oct 2008, 15:04
thanks alot :)
plexilover
Postby erikm5150 » 15 Oct 2008, 15:34
indyguitarist, you are awesome! :thumbsup
Thanks for sharing the knowledge
erikm5150
Postby ShortScaleMike » 15 Oct 2008, 22:37
I prototyped this this evening and it sounds great. Really nice tweaks on the original circuit.
ShortScaleMike
Postby bajaman » 16 Oct 2008, 00:58
Hi Brian
thanks for sharing the info - hope all is well with you. :D
Has thanked: 408 times
Have thanks: 1381 times
Postby Lawnchair » 16 Oct 2008, 01:05
Heck of a nice guy, great ears and teaching skills. Thanks Brian.
Lawnchair
Have thanks: 16 times
Postby indyguitarist » 16 Oct 2008, 16:16
glad to help - I'm getting ready to replace the plextortion pedals with a new distortion pedal which (IMO) sounds better and is more versatile - similar gain stages but the eq is a baxandall.
Brian
indyguitarist
Postby nooneknows » 04 Feb 2009, 18:22
hi,
is the Plexidrive based on a similiar circuit (maybe with a simplified tone stack)?
thank you
nooneknows
Has thanked: 22 times
Have thanks: 5 times
Next
Users browsing this forum: Jimiric90 and 21 guests
