Zvex - Box of Rock  [traced]
Re: Zvex - Box of Rock
Postby 5thumbs » 14 Jul 2009, 20:00
kurtlives wrote:Been meaning to build this one for a long time and finally getting around to it...
Did anyone save a copy of Torchy's vero layout before he pulled them?
Here's the veroboard layout I downloaded from this thread a while ago. I can't vouch for it because I never used it, as I ended up modifying madbeans' layout and running with it.
If Torchy (or other originator of this image, as there is no ID or copyright info on the image) wants to exercise their copyright and have me remove it, please let me know. I did not originate this design, so I will respect the copyright claims of the originator.
Modding a DS-1? Please read 'Build Your Own DS-1 Distortion'.
"Other than a good first-in-line buffer/booster, using other FX to improve bad clean tone is like gift-wrapping garbage."
5thumbs
Have thanks: 6 times
Postby telecaster » 14 Jul 2009, 20:55
Found this, don't know if this is it.
KindaFuzzy - Looks like a blue nail polish and nutella sandwich.
Freekish - "Our originality is in the basement. Our business is in the toilet"
Guitarlcarl - I did take offence at being called an idiot by a moron.
telecaster
Has thanked: 178 times
Have thanks: 14 times
Postby kurtlives » 14 Jul 2009, 23:12
^^Thanks 5thumbs.
^telecaster that is exactly what I was looking for. Thanks so much.
Now to build... :horsey:
kurtlives
Have thanks: 5 times
Postby sevinisthenumber » 31 Jul 2009, 23:39
i have built 2 or three of these and the one i just built has a weird gain knob issue,... When the gain is in the last 5% of rotation it fizzles out to 0 volume...? ANy ideas? Ive verified all the bs170's position, wiring, caps, etc...
C.S. Lewis
sevinisthenumber
Have thanks: 31 times
Postby Evz » 20 Aug 2009, 20:35
This is a silly question, but as i have notice, the ZV pedals "Box of...." are cascaded SHO's, so Theoretically, if i take the BOR or the BOM circuit can i just remove the tone and boost/gate circuit to get a simple distortion box? (i dont really care for any tone feature)... would that be possible?
Evz
Postby 5thumbs » 20 Aug 2009, 22:30
Evz wrote:This is a silly question, but as i have notice, the ZV pedals "Box of...." are cascaded SHO's, so Theoretically, if i take the BOR or the BOM circuit can i just remove the tone and boost/gate circuit to get a simple distortion box? (i dont really care for any tone feature)... would that be possible?
If you read back earlier in this thread, you'll find that someone has already done a BoR layout with the boost stage removed. I believe there were both vero and PCB layouts in this configuration.
As for BoM, if you go look through that thread, there were layouts available for it, minus the gate portion (which you prefer.)
If the layouts aren't still there, you could nicely ask the folks on those threads to repost the files. I'm sure they'll cough them up for you.
Good luck!
5thumbs
Postby nickeroo » 25 Aug 2009, 22:19
I have a (probably totally noob-tastic) question about the layout telecaster posted above.
c9 and c10 ask for a 2nf capacitor...and I can't seem to find one (I'm in the UK)
I can find a whole load of types of 2.22 nf caps, but no 2 nfs. I was using Musikding first, and could get everything there except those two caps. Maplin and RS didn't give me any joy.
can anyone help...?
nickeroo
Postby madbean » 25 Aug 2009, 22:43
2n2 is fine. You most likely would not notice the difference.
madbean
Postby nickeroo » 25 Aug 2009, 22:56
I was hoping someone would say that... :¬D
Thank you, madbean.
Finally, for the non-polarised caps, do I need to look at specific capacitor types, would I notice if all were ceramic, or if there's a mix between poly and ceramic. Couldn't see any specific indication to say if there's any need to favour one type for one cap, another type for another?
(again, possibly a very noob-ish question...!)
nickeroo
Postby madbean » 26 Aug 2009, 01:44
nickeroo wrote:I was hoping someone would say that... :¬D
Thank you, madbean.
It's more a matter of personal taste. You would likely notice a difference between all ceramic and all poly-film. I believe the stock unit actually uses multi-layered ceramics (little blue dudes) and tantalums. Anyway, I personally stick to all ceramic under 1n and metallized/poly film for 1n-1uF. You can't fault a bad sounding pedal on components if you stick to those types, IMO.
madbean
Postby nickeroo » 26 Aug 2009, 01:54
Thank you again, madbean. You've improved my life a little, and hopefully opened a few doors with your advice. I actually found the "2nf" question answered in an FAQ on another subforum of the board (this place gets a bit confusing with all the updates and revisions and so on!!) a little while after I read your answer.
:applause:
nickeroo
Postby kurtlives » 27 Aug 2009, 02:07
Can someone check the boost section? It looks like there is a set 5K resistance from source to ground. Doesnt look like the wiper is doing anything.
kurtlives
Postby madbean » 27 Aug 2009, 02:56
Wiper should be connected to ground.
madbean
Postby kurtlives » 27 Aug 2009, 03:19
Yes exactly, so the PCB mounted pot is wrong.
kurtlives
Postby kurtlives » 28 Aug 2009, 03:30
If you do build using Torchy's vero...
Switch lugs 3 and 1 on the tone pot around.
On the boost circuit, ground lug 3, lug 2 goes to the MOSFET's source.
kurtlives
Postby BaLaClavaAa » 30 Aug 2009, 21:22
So wait, which vero layout is correct?
BaLaClavaAa
Postby rasta_maleek » 30 Aug 2009, 22:12
hi from spain, i did make some layout for this, i use the gutshots and the schematic, i do reversed process
rasta_maleek
Has thanked: 64 times
Have thanks: 48 times
Postby delaystomper » 22 Sep 2009, 00:44
hi guys im new to this forum and i ran across this topic .. im very interested and desperate to build the zvex box of rock , can anyone help me out and point me to the right schematic and layout that were posted here ,,?there is been so many that im a bit lost.
thanks .
by the way i just finished building the fuzz factory and i got to say im very please with it.!!
delaystomper
Postby 5thumbs » 23 Sep 2009, 20:00
delaystomper wrote:hi guys im new to this forum and i ran across this topic .. im very interested and desperate to build the zvex box of rock , can anyone help me out and point me to the right schematic and layout that were posted here ,,?there is been so many that im a bit lost.
thanks .
I used madbeans' layout for the BOR w/boost; I had zero problems with it. For simplicity's sake, I repackaged his images into a PDF document, which I've also attached to this reply. (Mr. Beans, if you don't appreciate the repackaging/reposting of your work, please let me know and I'll pull it.)
Good luck!
Krankosaurus.pdf
For this message the author 5thumbs has received thanks:
spray6969 (11 Apr 2017, 18:02)
5thumbs
Postby delaystomper » 24 Sep 2009, 08:32
thank you friend i will give it a try this weekend and hope it works, i think i'll be getting my bs170 by that time also
thanks agian !!!
delaystomper
Users browsing this forum: No registered users and 10 guests
