Zvex - Box of Rock  [traced]
Postby tuemmueh » 12 Dec 2007, 10:50
But C6&7 in beans layout are wrong labeled, aren't they? He says 22n while the schem says 2n ...
tuemmueh
Have thanks: 2 times
Postby madbean » 12 Dec 2007, 12:52
Thanks for reminding me...here's the corrected layout (from my super secret blah blah). The traces on this are gynormous...but it was my first PCB layout, afterall :oops:
madbean
Postby Lovepedal Detective » 12 Dec 2007, 17:09
I've updated the vero layout. The main problem was that the previous version had the output of each gain stage coming off of the Gate instead of the Drain like it's supposed to. Also C2 was backwards.
LPD
Image[/img]
Lovepedal Detective
Have thanks: 3 times
Postby Igloo » 13 Dec 2007, 05:02
A good time to be stopping by...
Hmmm looks like a pinout error in the original! My goodness! I should know better than that!
OK, updated on the first page.
Lovepedal..you may wish to have a look at C4 and R6 from your "update" of my layout.....
Guys, please PM me directly if you find an problems with any layouts. I would prefer that rather than cutting them up.
Cheers Igloo.
Igloo
Postby Lovepedal Detective » 13 Dec 2007, 17:12
Igloo, not sure what you are talking about on my C4 and R6? I don't see anything wrong?
Sorry I redid your layout. I hadn't seen you around so I figured I'd just redo it. Thanks for your initial work.
Whoops I see it now. C3 is actually where the problem is. Thanks for the catch.
LPD
Lovepedal Detective
Postby The Pup » 30 Dec 2007, 08:09
Thanks for the schematic...I own a Vexter I got on trade...I like the OD circuit, but not the slight bass hump. I think I might modify it now.
The Pup
Postby nokaster » 30 Dec 2007, 10:49
i'm a little confused... which vero layout is the correct one?
also, what is a good substitute for the 1N5817?
thx!
nokaster
Postby briggs » 30 Dec 2007, 12:44
That diode is used for polarity protection. Stick in a 1N4001 or anything or just omit it (Get your polarity right!)
I am Klon.
briggs
Has thanked: 30 times
Have thanks: 123 times
Postby nokaster » 30 Dec 2007, 13:01
ok!
but which one is the correct layout?
nokaster
Postby briggs » 30 Dec 2007, 13:36
Use lovepedals vero on the last page. Or madbeans PCB. 8)
I am Klon.
briggs
Postby nokaster » 30 Dec 2007, 13:38
thx man!
nokaster
Postby Torchy » 30 Dec 2007, 20:59
The vero layout is still incorrect. C3 connects directly from Q1 Drain to Q2 Gate. C4 and R6 both connect to the gate of Q2 but the other ends are floating (ie not connected to anything).
The signal path should be C3 ->C4/R6 -> Q2 Gate.
I havent checked the rest.
Torchy
Postby Igloo » 30 Dec 2007, 22:25
Yes, also it is missing C10 from the tone section.
Igloo
Postby Igloo » 30 Dec 2007, 23:30
My ORIGINAL layout on page one is updated...
It looks correct to my eyes but also I have asked another forum member to double check it.
Happy new year to all.
Igloo
:D :D :D
Igloo
Postby bumblebee » 31 Dec 2007, 01:01
found another layout for the Bor on this japanese site
bumblebee
Have thanks: 4 times
Postby Lovepedal Detective » 31 Dec 2007, 01:53
Torchy wrote:The vero layout is still incorrect. C3 connects directly from Q1 Drain to Q2 Gate. C4 and R6 both connect to the gate of Q2 but the other ends are floating (ie not connected to anything).
Whoops. I updated mine, but it looks like the wrong image got posted. I'll fix mine and put up a correct image.
LPD
Lovepedal Detective
Postby Zaphod_Beeblebrox » 31 Dec 2007, 19:36
Thanks for all the hard work.
I'm a complete n00b at pedal building, but I've always wanted a BoR and if anyone comes out with a kit I'll be first in line.
Zaphod_Beeblebrox
Postby soulsonic » 31 Dec 2007, 23:57
Zaphod_Beeblebrox wrote:Thanks for all the hard work.
You're in luck dude! They already have one available.
Right HERE
[smilie=a_ohyahbaby.gif]
Has thanked: 56 times
Have thanks: 268 times
Postby The Pup » 01 Jan 2008, 00:47
Right HERE
But what about the bass hump? I must mod my BoR to be truly happy and fulfilled.
The Pup
Postby Goop_buster » 01 Jan 2008, 00:57
Right HERE
cool thanks!
Hey Zaphod
I think that was intended as a joke. There is no BOR kits around (AFAIK).
However the BSIAB has a tone control which is very similar to that in BOR. To be nice we could say that there is a high probability that Zvex was inspired by the BSIAB.
Although in my opinion the real origin for this type of tone ctrl is the old Big Muff.
Goop_buster
Have thanks: 5 times
Users browsing this forum: LaboratoryManiac, MBens11, mdd59, tubejock and 2 guests
