Devi Ever - Legend of Fuzz
Re: Devi Ever - Legend of Fuzz
Postby HEAD » 26 Mar 2010, 21:58
the Silver Crank part does work as it probably should. I did breadboard it once.
Helge
HEAD
Has thanked: 25 times
Have thanks: 43 times
Postby RnFR » 26 Mar 2010, 22:14
i think Devi probably uses about 3 different cap values and 5 different resistor values in all of the DE pedals. it's kinda funny. probably makes it easy!
Has thanked: 150 times
Have thanks: 174 times
Postby soggybag » 26 Mar 2010, 23:32
Are all of these DE pedals made by randomly connecting transistors and resistors and caps together?
soggybag
Has thanked: 18 times
Have thanks: 8 times
Postby teej212 » 17 May 2010, 21:54
here is a verified Schematic for the 33 side, with PNP layout from above
incorrect schematic removed by moderator.
teej212
Have thanks: 9 times
Postby papercutnoise » 18 May 2010, 07:24
teej212 wrote:here is a verified Schematic for the 33 side, with PNP layout from above
The schematic has 3 resistors listed but the layout only gives values for two. Could you tell me what the values are for each resistor on the schematic? Thanks
papercutnoise
Postby HEAD » 18 May 2010, 11:10
:shock: Which schematic? The one posted above has only two pictured and it is correct. I breadboarded exactly that a while ago. It works and sounds quite cool - I you have in mind how crude this little circuit is.
HEAD
Postby ~arph » 18 May 2010, 12:09
The schematic has three pictured, but the layout left out R1 in the schematic.
Collector-base resistor is 2.2M and the collector-9v is 10k.
I don't know the value for R1 I guess it depends on what the value of the "control" pot is.
~arph
Has thanked: 65 times
Have thanks: 169 times
Postby HEAD » 18 May 2010, 12:36
Damn! :oops: My fault I didn't read "resistors" but "transistors" - dunno why! Excuse me! Mea culpa! :|
HEAD
Postby teej212 » 18 May 2010, 13:03
i have R1 at 10k, its just to put a limit on the control knob so all the signal does not get directed to ground
teej212
Postby teej212 » 18 May 2010, 13:05
trust me, the first layout was wrong, there was no 3.3m resistor in there, it was definately a 10k and i just added a gain control which is the control devi uses herself
teej212
Postby papercutnoise » 18 May 2010, 22:43
Apparently she almost always uses 100k pots in her pedals. Surely this image is pretty clear as to what resistors are used....
[url]
http://farm4.static.flickr.com/3044/307 ... cdd4_o.jpg[/url]
According to this online resistance calculator it's a 100k (Brown, Black, Yellow, Gold) and 2.2m (Red, Red, Green, Gold)
[url]
http://www.dannyg.com/examples/res2/resistor.htm[/url]
So there's 3 resistors (10k connected to the pot, 2.2m, 100k) and 2 100k pots from what I can work out
papercutnoise
Postby teej212 » 18 May 2010, 22:50
oh, you think that band is orange not yellow?
teej212
Postby papercutnoise » 18 May 2010, 23:01
actually yeah it's probably orange actually so it'd be a 10k, sorry. Damn these tired eyes! Sorry, I've been in front of a computer for over 10 hours today.
So 10k, 10k, 2.2m resistors and two 100k pots should do the trick?
papercutnoise
Postby teej212 » 19 May 2010, 20:30
Yup
pretty cool sounding short decay fuzz
teej212
Postby papercutnoise » 23 May 2010, 02:40
Any chance of getting the 33/silver crank schematic posted back up?
papercutnoise
Postby sevinisthenumber » 14 Jul 2010, 04:20
Is there a layout or verified schematic for the bit fuzz?
C.S. Lewis
sevinisthenumber
Have thanks: 31 times
Postby papercutnoise » 14 Jul 2010, 19:48
sevinisthenumber wrote:Is there a layout or verified schematic for the bit fuzz?
There's now exact layout that I know of but the bit is basically a 33 running into a GZ.
Details on the 33 (AKA Silver Crank) are here...
[url]
http://forum.deviever.com/viewtopic.php?f=40&t=8220[/url]
Details on the GZ are here (the GZ is a variation of the VFM/SM Circuit)....
http://forum.deviever.com/viewtopic.php?f=153&t=4191
And here....
[url]
http://www.etsy.com/listing/50620483/sm ... zg-pcb-kit[/url]
Basically you have the input going through the first pot (intensity) into the 33, the output of the 33 goes straight into the in of the GZ then into the second pot (Volume) and then to the output. Hope that made some sort of sense
papercutnoise
Postby papercutnoise » 14 Jul 2010, 20:44
ok, tried to do out a layout for the Silver Crank/33. If you spot any errors please let me know.
papercutnoise
Postby teej212 » 15 Jul 2010, 05:00
its good but you could make the board much smaller
teej212
Postby euronymous0001 » 02 Apr 2011, 00:29
so after almost 2 years, is the schem verified? :mrgreen:
euronymous0001
Has thanked: 19 times
Have thanks: 29 times
Users browsing this forum: bighud, e_bee and 12 guests
