Analogman - King of Tone  [traced]
FloPoeKo
my favorite amplifier: Reckmeyer-Modded Mesa Lonestar Classic
Has thanked: 18 times
Been thanked: 39 times
Post by FloPoeKo »
Has anyone confirmed which three resistors per "channel" are supposed to be carbon composite instead of carbon film as in the rest of the pedal (please no discussion on the merits of that practice, I sincerely beg you!)?
If one has an insight on that and maybe could refer to actual component numbers in a respective schematic since they all vary ab bit (e.g. "RX/Y/Z in the mad bean-schematic"). I´ve seen some posts on that matter, but to me their supposed location in the circuit somehow doesn´t make much sense...
Many thanks in advance!
mictester
Has thanked: 32 times
Been thanked: 844 times
Post by mictester »
FloPoeKo wrote:Has anyone confirmed which three resistors per "channel" are supposed to be carbon composite instead of carbon film as in the rest of the pedal (please no discussion on the merits of that practice, I sincerely beg you!)?
Why? Can't you bear to find out that there is no difference if you use other types of resistor? The only reason that CC types were used in some positions is that the original manufacturer had some of those values in CC in stock and wanted to get rid of them. He also thought that it would add to the bogus "mojo" value of what is - essentially - a copy of a Marshall Bluesbreaker pedal.
We boutique constructors sometimes use hard-to-find components for no other reason than to try to prevent exact copies of our products!
FloPoeKo
Post by FloPoeKo »
And all my begging remained unheard :cry:
Seriously, I hear you, but to me thats the cost of 0.90€ and the extra socketing... I´d call that rarely an effort, but I wanted to try and hear for myself... 0.90€ and a 1 minute of swapping to debunk a myth by experience, that would be the essence of DIY as far as I´m concerned...
So, once again: Anyone knows the exact resistors?
LordoftheLivingRoom
Post by LordoftheLivingRoom »
Almost all of the links in; Board index ‹ Stompbox Building ‹ Build-Your-Own-Boutique-Pedal < King of Tone; thread are dead. Does anyone have Madbeans Version 2 pcb toner transfer and layout files please?
rcustoms
Has thanked: 363 times
Been thanked: 520 times
Post by rcustoms »
LordoftheLivingRoom wrote:Almost all of the links in; Board index ‹ Stompbox Building ‹ Build-Your-Own-Boutique-Pedal < King of Tone; thread are dead. Does anyone have Madbeans Version 2 pcb toner transfer and layout files please?
as you wish
KingOfKlones_ver2.5.pdf
(762.98 KiB) Downloaded 756 times
guitars,pedals and amps.
@zuleta.rafael(Instagram)
mojah63
Has thanked: 40 times
Been thanked: 24 times
Post by mojah63 »
The 10K after the drive and the 1K after the 2nd opamp directly in the signal path Are CC for added noise/mojo/aesthetics/ just because I can.... I've had a mad bean populated board on my bench for years someone traded me, I finally boxed it up last week. It's now happily boosting my 11R Vox model. Sounds really nice..
tiagojoy
my favorite amplifier: fender
Been thanked: 13 times
Post by tiagojoy »
My king of klone!
The Rotagilla
Post by The Rotagilla »
Does anyone know what the purpose of the two 1µF caps in parallel are at the end of the circuit (one film and one electrolytic)? Why not just use a 2.2µF?
floris
Has thanked: 231 times
Been thanked: 72 times
Post by floris »
The Rotagilla wrote:Does anyone know what the purpose of the two 1µF caps in parallel are at the end of the circuit (one film and one electrolytic)? Why not just use a 2.2µF?
Good question!
And 2,2uF seems a very large value, assuming the output is connected to a 1M impedance of the next stage.
Why not just use a 0,1uF film cap?
alambike
Post by alambike »
Does anyone have the KoT version 4 ?
bugg
Has thanked: 51 times
Been thanked: 336 times
Post by bugg »
alambike wrote:Does anyone have the KoT version 4 ?
You can find the schematic (and PCB if you wish) here: http://www.pedalpcb.com/product/paragon/
alambike
Post by alambike »
Hello,
At the pedalpcb there is only the pcb for sale. The documentation is not available.
Thank you for your help.
bugg
Post by bugg »
Doh! That's one of the ones that haven't been uploaded yet, my apologies. Stay tuned, it'll be posted shortly.
Seiche
Been thanked: 189 times
Post by Seiche »
I finally have a v4 on the way after 7years on the list (and me losing the confirmation email). To be clear, waiting time was only 1,5years.
I'll post some pictures and details of the high gain side when I get it.
Seiche
Post by Seiche »
btw I found this on my computer
Aristocrat_ver.4-AnalogmanKingofTone.pdf
(806.31 KiB) Downloaded 398 times
Seiche
Post by Seiche »
I got the pedal, but only had a quick look. Cap values seem to be the same, except both input caps seem to be 22n instead of 10n, as shown in the aristocrat schematic.
I'll get some pictures and resistor values tomorrow.
teddeeh
Been thanked: 16 times
Post by teddeeh »
Seiche wrote:I got the pedal, but only had a quick look. Cap values seem to be the same, except both input caps seem to be 22n instead of 10n, as shown in the aristocrat schematic.
Yes man, please do. Most interested!!
Seiche
Post by Seiche »
- the input cap is 22n on both sides
- instead of 1s1588, this uses 1n914
- output cap of the high-gain red side has an "H" painted on it, but is the same value 105 as on the yellow side.
- the feedback loop cap on the yellow side ist a weird value. 505? The red side has the usual 101=100pF.
I haven't verified all of the resistors.
Has thanked: 232 times
Been thanked: 887 times
Seiche wrote: after 7years on the list
Am I correct you are not joking? :shock: :shock: :shock:
Seiche
Post by Seiche »
Haha you are correct, however, I did not WAIT 7 years for the pedal. I just didnt decide for 5,5 years if i wanted the pedal. But when I did, they sent it the next day :)
