Analogman - King of Tone  [traced]
Re: Analogman - King of Tone
Postby gian80 » 30 Nov 2013, 11:43
Hi everyone!!!
I can't fine anymore madbeans pcb for the KoT in my documents. Anyone hacking it can post it please?
thank u!
gian80
Postby fakcior » 30 Nov 2013, 13:48
I've got it, but I don't know if I can post it here.
fakcior
Have thanks: 22 times
Postby gian80 » 08 Dec 2013, 15:28
fakcior wrote:I've got it, but I don't know if I can post it here.
PM or email?
gian80
Postby FloPoeKo » 26 Jan 2016, 12:07
Has anyone confirmed which three resistors per "channel" are supposed to be carbon composite instead of carbon film as in the rest of the pedal (please no discussion on the merits of that practice, I sincerely beg you!)?
If one has an insight on that and maybe could refer to actual component numbers in a respective schematic since they all vary ab bit (e.g. "RX/Y/Z in the mad bean-schematic"). I´ve seen some posts on that matter, but to me their supposed location in the circuit somehow doesn´t make much sense...
Many thanks in advance!
FloPoeKo
Has thanked: 25 times
Have thanks: 45 times
Postby mictester » 26 Jan 2016, 16:00
FloPoeKo wrote:Has anyone confirmed which three resistors per "channel" are supposed to be carbon composite instead of carbon film as in the rest of the pedal (please no discussion on the merits of that practice, I sincerely beg you!)?
Why? Can't you bear to find out that there is no difference if you use other types of resistor? The only reason that CC types were used in some positions is that the original manufacturer had some of those values in CC in stock and wanted to get rid of them. He also thought that it would add to the bogus "mojo" value of what is - essentially - a copy of a Marshall Bluesbreaker pedal.
We boutique constructors sometimes use hard-to-find components for no other reason than to try to prevent exact copies of our products!
mictester
Has thanked: 32 times
Have thanks: 798 times
Postby FloPoeKo » 26 Jan 2016, 16:22
And all my begging remained unheard :cry:
Seriously, I hear you, but to me thats the cost of 0.90€ and the extra socketing... I´d call that rarely an effort, but I wanted to try and hear for myself... 0.90€ and a 1 minute of swapping to debunk a myth by experience, that would be the essence of DIY as far as I´m concerned...
So, once again: Anyone knows the exact resistors?
FloPoeKo
Postby LordoftheLivingRoom » 28 Jul 2016, 12:04
Almost all of the links in; Board index ‹ Stompbox Building ‹ Build-Your-Own-Boutique-Pedal < King of Tone; thread are dead. Does anyone have Madbeans Version 2 pcb toner transfer and layout files please?
LordoftheLivingRoom
Postby rcustoms » 28 Jul 2016, 12:30
LordoftheLivingRoom wrote:Almost all of the links in; Board index ‹ Stompbox Building ‹ Build-Your-Own-Boutique-Pedal < King of Tone; thread are dead. Does anyone have Madbeans Version 2 pcb toner transfer and layout files please?
as you wish
KingOfKlones_ver2.5.pdf
guitars,pedals and amps.
@zuleta.rafael(Instagram)
For this message the author rcustoms has received thanks: 6
287m (28 Jul 2016, 13:07), Blitz Krieg (01 Aug 2016, 07:49), floris (28 Jul 2016, 12:42), ilshat (28 Jul 2016, 19:55), LordoftheLivingRoom (29 Jul 2016, 10:39), washburnmemphis (07 Apr 2017, 06:45)
rcustoms
Has thanked: 346 times
Have thanks: 491 times
Postby mojah63 » 01 Aug 2016, 05:21
The 10K after the drive and the 1K after the 2nd opamp directly in the signal path Are CC for added noise/mojo/aesthetics/ just because I can.... I've had a mad bean populated board on my bench for years someone traded me, I finally boxed it up last week. It's now happily boosting my 11R Vox model. Sounds really nice..
mojah63
Have thanks: 17 times
Postby tiagojoy » 02 Aug 2016, 14:33
My king of klone!
For this message the author tiagojoy has received thanks:
Seiche (21 Jun 2018, 21:15)
tiagojoy
Have thanks: 11 times
Postby The Rotagilla » 02 Aug 2016, 20:41
Does anyone know what the purpose of the two 1µF caps in parallel are at the end of the circuit (one film and one electrolytic)? Why not just use a 2.2µF?
The Rotagilla
Have thanks: 57 times
Postby floris » 03 Aug 2016, 10:38
The Rotagilla wrote:Does anyone know what the purpose of the two 1µF caps in parallel are at the end of the circuit (one film and one electrolytic)? Why not just use a 2.2µF?
Good question!
And 2,2uF seems a very large value, assuming the output is connected to a 1M impedance of the next stage.
Why not just use a 0,1uF film cap?
floris
Has thanked: 171 times
Have thanks: 55 times
Postby alambike » 14 Nov 2017, 21:18
Does anyone have the KoT version 4 ?
alambike
Postby bugg » 15 Nov 2017, 01:58
alambike wrote:Does anyone have the KoT version 4 ?
You can find the schematic (and PCB if you wish) here: http://www.pedalpcb.com/product/paragon/
bugg
Has thanked: 36 times
Have thanks: 228 times
Postby alambike » 15 Nov 2017, 21:16
Hello,
At the pedalpcb there is only the pcb for sale. The documentation is not available.
Thank you for your help.
alambike
Postby bugg » 16 Nov 2017, 14:52
Doh! That's one of the ones that haven't been uploaded yet, my apologies. Stay tuned, it'll be posted shortly.
bugg
Postby Seiche » 20 Jun 2018, 11:50
I finally have a v4 on the way after 7years on the list (and me losing the confirmation email). To be clear, waiting time was only 1,5years.
I'll post some pictures and details of the high gain side when I get it.
Seiche
Has thanked: 241 times
Have thanks: 184 times
Postby Seiche » 21 Jun 2018, 21:14
btw I found this on my computer
For this message the author Seiche has received thanks:
nenecarrizo83 (26 Jun 2018, 02:32)
Seiche
Postby Seiche » 06 Jul 2018, 21:55
I got the pedal, but only had a quick look. Cap values seem to be the same, except both input caps seem to be 22n instead of 10n, as shown in the aristocrat schematic.
I'll get some pictures and resistor values tomorrow.
Seiche
Postby teddeeh » 07 Jul 2018, 09:05
Seiche wrote:I got the pedal, but only had a quick look. Cap values seem to be the same, except both input caps seem to be 22n instead of 10n, as shown in the aristocrat schematic.
Yes man, please do. Most interested!!
teddeeh
Have thanks: 10 times
Users browsing this forum: MarkL, MisterLoud, nickthemen and 7 guests
