Analogman - King of Tone  [traced]
Re: Analogman - King of Tone
Postby Seiche » 07 Jul 2018, 14:39
- the input cap is 22n on both sides
- instead of 1s1588, this uses 1n914
- output cap of the high-gain red side has an "H" painted on it, but is the same value 105 as on the yellow side.
- the feedback loop cap on the yellow side ist a weird value. 505? The red side has the usual 101=100pF.
I haven't verified all of the resistors.
For this message the author Seiche has received thanks: 2
dv8r601 (10 Jul 2018, 00:00), modman (17 Mar 2019, 13:18)
Seiche
Has thanked: 249 times
Have thanks: 192 times
Postby Dirk_Hendrik » 07 Jul 2018, 16:53
Seiche wrote: after 7years on the list
Am I correct you are not joking? :shock: :shock: :shock:
Has thanked: 255 times
Have thanks: 1022 times
Postby Seiche » 07 Jul 2018, 21:17
Haha you are correct, however, I did not WAIT 7 years for the pedal. I just didnt decide for 5,5 years if i wanted the pedal. But when I did, they sent it the next day :)
Seiche
Postby Dirk_Hendrik » 08 Jul 2018, 09:52
Pfoooh :thumbsup
Postby Seiche » 08 Jul 2018, 10:24
Dirk,
what do you reckon is up with this 505 cap?
That should be 5uF, but that doesnt make sense?
Seiche
Postby Motter » 10 Jul 2018, 19:08
Maybe it's a 50 pf and the second 5 is a tolerance marking? Or maybe an S? Can you see any other markings on it?
Motter
Has thanked: 26 times
Have thanks: 93 times
Postby Seiche » 10 Jul 2018, 21:09
That's what I'm assuming, but it's not consistent with the other one (101).
Seiche
Postby plush » 11 Jul 2018, 12:36
Wow, same happened to my fallout character when i maxed his social marketing bullshit instead of soldering.
plush
Has thanked: 25 times
Have thanks: 46 times
Postby Seiche » 21 Jul 2018, 12:56
So I traced the circuit and it's pretty much what we already know. The only differences are thus:
- output cap of the high-gain red side has an "H" painted on it, but is the same value 105 as on the yellow side. The IC also has and H painted on and the chip id sanded off.
- On the high-gain red side the gain resistor is 100k, on the yellow side it is 1k.
I think the last part is news, as this resistor was always assumed to be 10k and the gain pot changed for high-gain on DIY projects.
For this message the author Seiche has received thanks: 3
lars-musik (09 Sep 2018, 21:56), Manfred (21 Jul 2018, 18:30), nenecarrizo83 (26 Aug 2018, 05:21)
Seiche
Postby morgan wong » 17 Mar 2019, 03:21
Seiche wrote:So I traced the circuit and it's pretty much what we already know. The only differences are thus:
Are you sure? From the picture, they are all 10K, and there is no difference.
morgan wong
Postby Seiche » 19 Mar 2019, 22:22
pretty sure, yes, which pictures are you referring to and which resistors?
I think they were brown-black-red (1k) and brown-black-yellow (100k), but it's not entirely clear on my pictures and I already flipped the pedal.
Seiche
Postby jalmonsalmon » 20 Mar 2019, 01:46
Those magical diodes can be found again and my big question is do they really make a difference in this thing? I made a clone of this and still need to figure out the best settings with those dip switches LOL
jalmonsalmon
Has thanked: 72 times
Have thanks: 23 times
Postby morgan wong » 20 Mar 2019, 23:07
Seiche wrote:pretty sure, yes, which pictures are you referring to and which resistors?
The picture is not clear, the color ring reading looks more like brown - black - orange (10k)
morgan wong
Postby Intripped » 21 Mar 2019, 09:53
that resistor is 10k, but it is not the resistor that Seiche is talking about.
the correct one is behind the 1uF capacitor (square, marked with "H")
Intripped
Has thanked: 588 times
Have thanks: 215 times
Postby Seiche » 21 Mar 2019, 19:00
Intripped wrote:that resistor is 10k, but it is not the resistor that Seiche is talking about.
Correct. The 10k carbon comp is R6 in my schematic. Feedback resistors R5 are not in the direct audio path and thus not carbon comp (but rather carbon film). One of the resistors is behind the cap, which is why I can't find a clear picture of it (I took a few pictures at the time).
These are the best pictures I have of them:
morgan wong (24 Mar 2019, 14:44)
Seiche
Postby Seiche » 21 Mar 2019, 19:24
jalmonsalmon wrote:Those magical diodes can be found again and my big question is do they really make a difference in this thing?
which diodes are you referring to? The Ma856s? Because the 1s1588 were changed to 1n914s by Analogman himself.
I built my clone with Ma858s and 1s1588 but socketed them, but haven't gotten around to actually A/Bing them myself with common replacements.
Seiche
Postby jalmonsalmon » 22 Mar 2019, 18:33
Seiche wrote:which diodes are you referring to? The Ma856s? Because the 1s1588 were changed to 1n914s by Analogman himself.
From pedalhackers site, and I cannot say if those are real MA856s or MA858s
They are pricey too!
jalmonsalmon
Postby Seiche » 23 Mar 2019, 11:30
oh did you buy all of them? :lol:
Seiche
Postby Cigla tel. » 26 Mar 2019, 19:49
I did not have the chance to try the original. but if the schematic is correct, then the clone sound and behaviour should be equal to the original, RIGHT???
Judging by that, i did the clone and the pedal sound great. However, there is not one PRO musician who tried it and remained visibly disappointed in the nature of the sound of this device. :roll:
I made it very well .. i even inserted the original diodes MA856 & 1S1588:
.., bla bla.. and nothing spectacular.
Perhaps the only advantage is that it does not color the sound ... but .. overdrive/distortion with such a neutral tone... :?
I don't understand the hype at all about this device!
BTW. i made only wooden enclosures:
Image Image
Cigla tel.
Have thanks: 3 times
Postby Seiche » 26 Mar 2019, 21:25
don't you mean "didn't remain visibly disappointed"? As in they were disappointed because they expected more?
I also wasn't that fond of it, especially the pairing of playing both sides at the same time. It felt difficult to get a good sound in my opinion. I would prefer a prince of tone kind of deal that only had one of the sides and use a boost in front of it. I could only use them alternating both channels, not at the same time.
Seiche
Users browsing this forum: now:here, PMowdes and 10 guests
