Zvex - Box of Metal  [traced]
Re: Zvex - Box of Metal (gut shots)
Postby madbean » 13 Jan 2009, 20:36
I'll double check my build, too. I was in a rush to complete so maybe I'm wrong.
madbean
Postby andregarcia57 » 13 Jan 2009, 20:55
I am thinking about using this noisegate in a GT2, will work?
members/bajaman/Baja/Vzex/MoxofBetalGatesketch.jpg
andregarcia57
Have thanks: 86 times
Postby DimebuGG » 14 Jan 2009, 01:18
andregarcia57 wrote:I am thinking about using this noisegate in a GT2, will work?
OT: IMO, the GT-2 is not a noisy pedal if you're only using TLC2262 chips..
DimebuGG
Have thanks: 160 times
Postby Dead Sea » 19 Jan 2009, 03:24
Hey All;
Followed CJ over here - looks like something I need to try.
Dead
Dead Sea
Postby bajaman » 26 Jan 2009, 02:43
UPDATE - the preset pot is set between 1k ohms and 1.5k ohms NOT 4K ohms as originally suggested.
modman (08 Mar 2011, 12:52)
Has thanked: 408 times
Have thanks: 1381 times
Postby DimebuGG » 31 Jan 2009, 12:49
what are those "72" diodes in the gate circuit?
culturejam,
is there any chance we can hear your build?
DimebuGG
Postby culturejam » 01 Feb 2009, 17:48
DimebuGG wrote:culturejam,
I don't have it anymore. Traded it to another guy. :)
But it sounds dead-on to the commercial version. I tried them side by side.
culturejam
Has thanked: 461 times
Have thanks: 575 times
Postby audioguy » 22 Feb 2009, 15:45
Im about to build this today, is Madbeans layout fully verified? Im assuming so because most everything he posts kicks ass!
audioguy
Has thanked: 24 times
Have thanks: 6 times
Postby madbean » 22 Feb 2009, 16:25
Yes, it is verified by myself and some other rokrs. [smilie=pirate.gif]
madbean
Postby audioguy » 24 Feb 2009, 23:53
I just finished this one, sounds good. I kinda like it. I tweaked the 5k trim pot to my liking, Im assuming thats all you need to do, is adjust to taste?
audioguy
Postby audioguy » 25 Feb 2009, 01:01
OK well the controls are all a bit odd... the tone changes when you turn the volume all the way up. The EQ isnt that great. The mid control is too subtle.
audioguy
Postby culturejam » 25 Feb 2009, 01:13
audioguy wrote:The EQ isnt that great. The mid control is too subtle.
So change the values in the tone stack.
culturejam
Postby audioguy » 25 Feb 2009, 02:54
I might tweak it a little bit. The overall sound of the distortion is nice, I would just like to hear a little more differentiation as I twist the knobs.
Madbeans layout is really nice... I thought it would be a little tight to work with , but it was perfect, well done!
audioguy
Postby bestegw » 25 Feb 2009, 13:55
Hi Guys,
Although I'm more of a low-gain type-a-guy, this could be fun to spend some hours on, especially since the nice, perfect layout of Madbean. Speaking of which, I've tried to download rev 1.0 of the project files and ended up with an error. Is the document still online or is that just me???
Rock on!!!
BSTGW
bestegw
Postby madbean » 25 Feb 2009, 14:16
Oops, I may have relocated it. Here is the final rev1. All docs are 300 DPI.
madbean
Postby DimebuGG » 25 Feb 2009, 16:48
Just want to share this. PCB can be mounted vertically like those in zVex's. Pots are equally spaced. :)
For this message the author DimebuGG has received thanks:
DimebuGG
Postby audioguy » 25 Feb 2009, 17:25
Nice layout Dime!
I just plugged the values into the Tone Stack Calc, and its no wonder I didnt like the EQ, its all pretty flat. When I go home tonight I'm going to tweak it to some more Marshall-y values. Those look like I'll get the sweep that I want. Im primarily looking at changing the 2n for a 470pf and the 47k I'll probably drop to 33k.
audioguy
Postby DimebuGG » 25 Feb 2009, 17:42
A previous post claimed it was a 180pF cap instead of 2nF on his original unit(not vexter series though). :hmmm:
modman (08 Mar 2011, 12:53)
DimebuGG
Postby audioguy » 25 Feb 2009, 19:24
Yeah a 180pf looks better on the calculator. Maybe I'll try one.
audioguy
Postby audioguy » 27 Feb 2009, 01:41
OH MY GOD... I just dropped a 180pf in place of the 2n and this pedal now fucking KILLS!
I normally think ZV is a bit over rated, but he did a nice job on this design. Kudos to the guys that worked on R.E.ing it and to Madbean for the layout.
For this message the author audioguy has received thanks:
audioguy
Users browsing this forum: BigEd, kenny Treble, toshsai, ultralord and 6 guests
