Brian May's Deacy Amp secrets revealed  [traced]
Re: Brian May "Deacy Amp" Secrets Revealed
Postby lolbou » 22 Jul 2017, 21:39
http://antiqueradios.com/forums/viewtopic.php?f=4&t=213655&start=20 Problem solved, might be helpful to the thread. It's a Supersonic pr80 radio circuit. (Been posted here before in the Fryer replica thread)...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
Has thanked: 346 times
Have thanks: 234 times
Converting Brain May Deacy amp to a Pedal?
Postby trebbooster » 27 Nov 2017, 11:22
Hello,
I was wondering if anyone would have any idea how to modify the Brain May Deacy amp into a pedal? The strip board diagram I'm looking at using was put up by Paul in the lab https://paulinthelab.blogspot.com/2012/ ... board.html
If anyone here would know how to possibly turn this into a great pedal, please post your mods.
Thank you and have a great week :)
trebbooster
Re: Brian May's Deacy Amp secrets revealed
Postby bancika » 28 Nov 2017, 13:59
sure, you can put a resistive load instead of the speaker and tap the output from there. Google firezog line out.
bancika
Has thanked: 16 times
Have thanks: 80 times
Previous
Users browsing this forum: No registered users and 25 guests
