Brian May's Deacy Amp secrets revealed  [traced]
Postby vanessa » 29 Aug 2007, 16:35
analogguru wrote:Funny that the Treble Booster in the Vox Cooltron Booster uses the same incorrect (2k4 instead of 2k2 emitter-resistor, 1n instead of 100p etc.) values which were posted before on the web.
enjoy,
That is strange. I'll have to dig around for my notes but I'm certain that the VOX Deacy reissue uses those values from the hand drawn boost on the other page. When that amp first came out they claimed that they worked with the original and made an "exact copy" of May's treble boost (they could not state that about the amp because it's not an exact copy). I wonder if Cornish's values changed over the years and for what reason?
vanessa
Have thanks: 10 times
Postby analogguru » 29 Aug 2007, 16:55
I don´t know....The values in my schematic are from an original Guild (factory) schematic.
Why ? You should know by now that you can claim everything..... and that the truth is not revealed so fast, there exists: goop.
And the hand drawn schematic is the only one on the net which is known as the "May´s treble boost". How many people did have access to the Guild schematic when the cloners didn´t ?
So where is the risk ? In the meantime there are sold thousands of units and later you always can say: "Sorry, now we know better...but the unit we worked on, was exactly that....yes sorry, but now it is destroyed (or given back) and not longer available that we could proof this to you.."
Most important part is that you believed it before you bought it....
...or as one well known designer (I am talking about a designer, not Zachieee) wrote:
Yeah... it doesn't really matter what's inside... It only matters what it looks like! lol
Have thanks: 116 times
Postby vanessa » 29 Aug 2007, 17:36
Really good points, but that May Boost schematic (hand drawn) that's been floating around the net had to come from somewhere?
Now I have to dig and find my notes!
:D
vanessa
Postby Torchy » 29 Aug 2007, 18:04
http://www.geofex.com/FX_images/BrianMayboost.jpg
http://www.geofex.com/schemata.htm
A contribution from Stan Cotey. This is reputed to be a tracing of the Real Thing.
Torchy
Postby JHS » 29 Aug 2007, 19:06
The org. TB-83 has only one trannie in it, IMHO the schem from Analogguru looks more like the TB-83PLUS line driver.
Cornish wrote that there is a noise-reduction circuit in front of the TB-83.
It's good as a base so I will give it a try. I intend to split'l split it into the buffer- and the booster-section to be more flexible. There's nothing that cannot be modded to sound good...
JHS
JHS
Have thanks: 3 times
Postby analogguru » 29 Aug 2007, 20:57
To avoid confusions:
The posted schematic is not any "marketing story" about the same pcb-layout and components over the last 30 years for a gooped product which cannot be verified but should be sold today for approx. $300,-- ....
The posted schematic is the preamp/booster sold together with the second series of Guild´s "Red Special" Brian May Guitars in the 90´s.
The guitar and the preamp can be found here including guts:
http://www.hendrixguitars.com/Va0111.htm
The original schematic contains:
DSGN: PETE CORNISH
Postby grolschie » 29 Aug 2007, 23:31
Yeah. I guess many perhaps think it should be pronounced "D.C", but it's probably "Deeky".
grolschie
Postby gnognofasciani » 21 Sep 2007, 16:48
Does anybody know what are the specs for t1 and t2?
gnognofasciani
Have thanks: 11 times
Postby RLBJR65 » 22 Sep 2007, 12:52
Look at the first page of posts :wink:
RLBJR65 wrote:Colne 06005 (Hammond 57318) 3.5:1 + 1, Primary Rp 130 ohms, secondarys Rs 40 ohms.
Colne 06006 (Hammond 57319) 3.1 + 3.1:1, Primarys Rp 1 ohm, secondary Rs 0.2 ohm.
RLBJR65
Postby gnognofasciani » 22 Sep 2007, 14:33
RLBJR65 wrote:Look at the first page of posts :wink:
D'oh!
I'm sorry for the stupid question :oops:
gnognofasciani
Postby RLBJR65 » 23 Sep 2007, 13:13
Check out the Orchestrator. http://www.pedalpushers.com/amp.html
RLBJR65
Postby markm » 23 Sep 2007, 13:39
RLBJR65 wrote:Check out the Orchestrator. http://www.pedalpushers.com/amp.html
Interesting! 8)
markm
Have thanks: 8 times
Postby grolschie » 23 Sep 2007, 13:41
Interesting! 8)
The sound sample is a remake of "Procession" from Queen II album. Freakin' awesome album. Really worth a listen.... the album that is. :D
grolschie
Postby modman » 23 Sep 2007, 13:52
$899 listen to the sound sample is all I saw at first glance.
man that sounds crazy but kind of expensive for lofi -- :D
Has thanked: 3110 times
Have thanks: 559 times
Postby RLBJR65 » 24 Sep 2007, 12:58
One of those guys is the one I was working with on the bosstone. That board shown is not mine though.
I think I may have pissed the guy off asking q's or maybe he noticed I posted about the bosstone, Oh well!
I'm sure if he was not already pissed at me he will be when he discovers I posted that link on a forum [smilie=a_chuckle.gif]
IMO the clip sounds great.
I wonder if they can make a consistant sounding product, matching GE's etc.
$899 is a bit steep but you get a FREE pedal with it :wink:
For the record, I would like to make it publicly known that I currently have no financial or other connections to Pedal Pushers or its owner(s). In the past some of my intellectual property was provided to them freely. I also do not anticipate having any future dealings with Pedal Pushers or its owner(s).
RLBJR65
Postby sosodef » 07 Nov 2007, 14:56
I might build the may treble booster. Is it dirty or clean?
sosodef
Postby analogguru » 16 Nov 2007, 18:33
Here:
http://cgi.ebay.com/Deacy-Red-Special-A ... dZViewItem
you can find this:
http://i1.ebayimg.com/07/i/000/c4/5d/19e5_1.JPG
http://i19.ebayimg.com/03/i/000/c4/5d/1d3b_1.JPG
http://i12.ebayimg.com/02/i/000/c4/5d/1ab3_1.JPG
A standard transistor turntable/radio amplifier produced in millions on sale for $ 850,-- :shock: :shock: .... time for a (universal)-project.
Postby vanessa » 16 Nov 2007, 18:40
analogguru wrote:A standard transistor turntable/radio amplifier produced in millions on sale for $ 850,-- :shock: :shock: .... time for a (universal)-project.
Ahhh the fruits of our own evils... Ain't it grand?
:twisted:
vanessa
Postby sosodef » 16 Nov 2007, 18:53
what is this fireplace boost? The cornish one? anyone have a schematic?
Its a silicone boost with 35db. I want that.
sosodef
Re: Brian May "Deacy Amp" Secrets Revealed
Postby lolbou » 18 May 2009, 12:34
[smilie=bump.gif]
Hi, I bought yesterday an old mid-sixties radio (5 bucks!). This was a quite common unit here in France (these were produced in Paris intra muros!).
I did easily find the appropriate schem, with hand written notes on it.
It looks a lot like the above schematics (Roberts), and I did easily remove the trannies since those were socketed...
Here it goes:
1 Raytheon 2N271A / CK766A
2 Thomson 37T1
1 Thomson 991T1
2 Thomson 988T1
1 Thomson 909T1
As you can see on the schem, there are other names (equivalents?) for each one.
3 AF127
1 AC125
1 AC128
2 AC132
Are these real equivalents? Can I get some nice sound from them (using the output circuit)?
I'm really a beginner with old trannies, so any help would be great! Thanks...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
Has thanked: 347 times
Have thanks: 240 times
Users browsing this forum: bumblebee, illus1on7 and 13 guests
