Way Huge - Aqua-Puss  [traced]
Way Huge - Aqua Puss
Postby sergedeep » 18 Aug 2007, 18:45
Has anyone yet been able to verify to what extent the Aqua Puss is different from a DM-2 (without flipflop)?
sergedeep
Postby modman » 20 Aug 2007, 04:12
small but a gutshot still (thank mcb!)
http://archive.ampage.org/threads/0/fxg ... set-1.html
Has thanked: 3121 times
Have thanks: 570 times
Postby stomper » 02 Sep 2007, 17:03
Regrettably, I don't have any tech info. I did have an opportunity to hear one compared to the following;
Maxon Analog(the expensive one)
Boss DM2
Boss DD3
TubeEchoplex
EhDMM
The AquaPuss definitely had the closest cop of the echoplex. The Boss DM did not have the clarity of tone. Probably chalk it up to build quality.
stomper
Has thanked: 22 times
Postby markm » 04 Sep 2007, 03:05
It seems some claim the Aqua Puss was one of the BEST delays
ever known to mankind.
I'd love to have one!! 8)
markm
Have thanks: 8 times
Postby vanessa » 04 Sep 2007, 03:45
Have you tried the Ibanez DE-7 yet?
8)
vanessa
Have thanks: 10 times
Postby estragon » 04 Sep 2007, 13:21
Is it me, or the gutshot has only a BBD, a clock driver IC and a quad opamp and NO compander (NE571)?
estragon
Have thanks: 5 times
Postby analogguru » 04 Sep 2007, 13:54
Hmm... I don´t know, I can recognize a BBD near the clock chip, 2 transistors, a 8 pin chip below the cables (dual Op-amp?) - and a 16 pin IC which can´t be a quad Op-Amp (which would have only 14 pins).
Have thanks: 116 times
Postby alessandro » 04 Sep 2007, 15:06
HI GUYS!I THINK THAT EH MEMORY MAN DELUXE IS THE BEST ANALOG DELAY!I POSTED ALL THE SCHEMATIC PCB AND LAYOUT PLUS A MOD TO DOUBLE THE TIME TO MODMAN AND YOU CAN FIND IT INTO THE DIY EFFECTS PROJECTS :shock: !TRY IT!by KAPUTEPALLA!!!!!
alessandro
Postby vanessa » 04 Sep 2007, 17:21
alessandro wrote:HI GUYS!I THINK THAT EH MEMORY MAN DELUXE IS THE BEST ANALOG DELAY!I POSTED ALL THE SCHEMATIC PCB AND LAYOUT PLUS A MOD TO DOUBLE THE TIME TO MODMAN AND YOU CAN FIND IT INTO THE DIY EFFECTS PROJECTS :shock: !TRY IT!by KAPUTEPALLA!!!!!
Why are you shouting at us?
:lol:
vanessa
Postby alessandro » 04 Sep 2007, 20:13
I'm not a bad guy, i'm not shouting!Nice to meet all you friend and to contribute to this forum!I posted the rm voodoovibe project pcb+layout+corrected schematics!Have fun!CIAO(shouted)!!!!!AHAHAH
alessandro
Postby vanessa » 04 Sep 2007, 20:32
alessandro wrote:I'm not a bad guy, i'm not shouting!Nice to meet all you friend and to contribute to this forum!I posted the rm voodoovibe project pcb+layout+corrected schematics!Have fun!CIAO(shouted)!!!!!AHAHAH
Good to have you aboard Alessandro! Thank you for the project.
:D
vanessa
Postby stomper » 04 Sep 2007, 23:26
8)
I haven't tried the Ibanez, but thanks for the heads up!
stomper
Postby celadine » 05 Sep 2007, 06:34
Anyone notice that metal can transistor hiding near one of the jacks? I was thinking of smoothing out BBD delay noise by using a germanium transistor, but it looks like he beat me to it. Also, the BBD chip seems to be a mn3x05 or mn3008/3208B (no surprise). The data sheets refer to the strange 8pins-package-big- enough-for-14-pins as 'larger 8pin dip'.
The 16-pin chip by itself could be a lm136/700, used for compansion, or extra filtering.
[edit: of course, estragon and alessandro are correct about the 16-pin being a compander chip. :oops: The DM-2 schem makes it pretty clear.]
celadine
Has thanked: 16 times
Have thanks: 16 times
Postby sergedeep » 05 Sep 2007, 08:19
Yeah, I did notice that. He changed the type of transistors several times however (as far as I can tell from the different pictures I have seen)...
I tried to retrace it on the basis of pictures and, as far as I can tell from the components, it has a lot in common with the DM-2. But the devil is in the detail ;-)
I'll see what other information I have on my other computer.
sergedeep
Postby estragon » 05 Sep 2007, 12:11
analogguru wrote:Hmm... I don´t know, I can recognize a BBD near the clock chip, 2 transistors, a 8 pin chip below the cables (dual Op-amp?) - and a 16 pin IC which can´t be a quad Op-Amp (which would have only 14 pins).
You are right, AG. In the first image posted I couldn't see the opamp under the cables. The new set of gutshots make it pretty clear.
One thing that makes an interesting change in sound are the rectifier filter capacitors in the compander. Boss uses 220n (DM2, DM-3), Ibanez 470n (AD-100), and EH 1u. This changes the perceived attack on the delayed notes.
In particular, small caps like 220n produce a softer attack that is nice for reverb-like sounds. On the other end, 1u retains the natural pick attack of the strings.
Experimentation is recommended in this area.
Cheers.
estragon
Postby alessandro » 05 Sep 2007, 12:53
The 16 pins chip 90% is the NE 570 or NE 571N (are the same) used in the most popular delay as expander comander and to reduce BBD noise!I'm very interested in this effect!Have you traced the pcb?CIAO!!!
alessandro
Postby markm » 05 Sep 2007, 13:06
alessandro wrote:The 16 pins chip 90% is the NE 570 or NE 571N (are the same) used in the most popular delay as expander comander and to reduce BBD noise!I'm very interested in this effect!Have you traced the pcb?CIAO!!!
Me too!! :D
markm
Postby bajaman » 05 Sep 2007, 13:14
me three :lol: :lol:
Has thanked: 446 times
Have thanks: 1519 times
Postby estragon » 05 Sep 2007, 15:55
The new set of pictures correspond to at least two different units. One of the pictures show 220n capacitors near the 16-pin IC, presumably used for the rectifier filtering. This would lead to believe the Boss companding circuit is employed.
It is necessary to determine if the antialiasing pre and post filters use Boss values or are different, thus producing a different/better overal sonic characteristic.
Another question is, is the BBD an MN3005 fed from +9V or an MN3205 fed from a lower voltage?
estragon
Next
Users browsing this forum: dimebag0307, Duckman, heinrich, now:here and 8 guests
