Way Huge - Aqua-Puss  [traced]
Re: Way Huge - Aqua-Puss
Postby madbean » 01 Mar 2012, 01:06
There are only a couple of stages the dry signal passes through before the output. Turn the MIX all the way down, and then audio probe the outputs of 1) input buffer 2) pins 1 and 7 of the dual op-amp (TL072, or whatever you used). This should clue you into where the signal is dropping.
madbean
Postby LaceSensor » 01 Mar 2012, 01:21
madbean wrote:There are only a couple of stages the dry signal passes through before the output. Turn the MIX all the way down, and then audio probe the outputs of 1) input buffer 2) pins 1 and 7 of the dual op-amp (TL072, or whatever you used). This should clue you into where the signal is dropping.
Cool. Will do that tommorow. Its midnight here now :)
I used an LF353 FWIW
LaceSensor
Has thanked: 42 times
Have thanks: 246 times
Postby LaceSensor » 01 Mar 2012, 12:40
Fixed by replacing Q1. Thanks bean
LaceSensor
Postby LaceSensor » 01 Mar 2012, 16:27
Sweet
LaceSensor
Postby Seiche » 01 Mar 2012, 16:45
wow, neat build!
whats the difference between the two PCBs?
Seiche
Has thanked: 242 times
Have thanks: 186 times
Postby LaceSensor » 01 Mar 2012, 17:02
Seiche wrote:wow, neat build!
Just v1 = blue v2 = red, the v2 fixed 2 ground connections that you have to jumper. Otherwise identical.
The red one I built has the modulation add on (copied with a few changes from Sabros design)
LaceSensor
Postby madbean » 04 Mar 2012, 21:54
Just came across this template in my files. Print at 300DPI to get the right dimensions.
madbean
Postby LaceSensor » 06 Jun 2012, 01:52
Thanks to Abfelkin who sent me his last couple boards.
Heres the first one done, for a good friend of mine.
Gutshots tommorow when I have light.
LaceSensor
Postby abfackeln » 06 Jun 2012, 02:03
Love it!
abfackeln
Have thanks: 42 times
Postby Kunfuz » 06 Jun 2012, 07:38
Just bought a Red board with a MN3005 fron ngoda Rob that he had had hidden in a dark drawer :thumbsup
"Working" at work is an artform I have mastered to Jedi-level...
Kunfuz
Postby TubeOrgasmer » 06 Jun 2012, 09:03
Any news on when the dual delay and lfo add on PCBs from madbean will be available?
TubeOrgasmer
Have thanks: 2 times
Postby LaceSensor » 07 Jun 2012, 17:56
Heres some better pics including the insides
LaceSensor
Postby Seiche » 07 Jun 2012, 18:34
got my board. now where to get those 24mm board-mount pots?
only one I can find is this one. Only in that useless value :?
Seiche
Postby sinner » 07 Jun 2012, 18:58
Seiche wrote:got my board. now where to get those 24mm board-mount pots?
Don't be so sure, Banzai is often out of stock with stuff they carry on ;)
Has thanked: 1240 times
Have thanks: 1099 times
Postby Seiche » 07 Jun 2012, 19:52
Do you mean I should write them because it's not in the online store? :scratch:
Seiche
Postby sinner » 07 Jun 2012, 21:56
You should do that with all your orders from Banzai. They owe me 60 euro in parts (backordered) since 2010
Postby Seiche » 07 Jun 2012, 22:11
I think I get you now. You're saying that what's in the store isn't necessarily in stock, right? That's sucks dude.
I thought you were trying to say that what they have in their warehouse isn't necessarily visible online, lol. Trying to tell me that they might have the 24mm pcb pots but it doesn't show up online.
Hey I live in the city they are located, should I go there and give them some polish concrete shoes for you? :mrgreen:
Seiche
Postby LaceSensor » 08 Jun 2012, 01:11
or just use 16mm pots and wire peices of solid core onto them, like I do.
DIY board mount pots FTW!
For this message the author LaceSensor has received thanks:
Seiche (08 Jun 2012, 06:11)
LaceSensor
Postby danielzink » 08 Jun 2012, 02:32
or....
Mouser:
31VQ601-F
31VQ405-F
Dan
http://www.danielzink.com
MoonWatcher wrote:Silent ain't better. If someone cracks the shitwind, I want to know what's headed my way. Silence is for the library and the cemetery.
For this message the author danielzink has received thanks:
danielzink
Has thanked: 10 times
Have thanks: 28 times
Postby Seiche » 08 Jun 2012, 06:13
LaceSensor wrote:or just use 16mm pots and wire peices of solid core onto them, like I do.
Yeah I'll probably resort to that method. I've been doing this alot.
danielzink wrote:31VQ601-F
31VQ405-F
thanks! That's what I was looking for.
Seiche
Users browsing this forum: Cigla tel., kymar and 9 guests
