Catalinbread - Dirty Little Secret  [traced]
loylo
Been thanked: 20 times
Post by loylo »
Which multimeter do you use?
There is a huge difference between your readings and the theoretical resistors' values, according to their colour codes.
They have both 5% tolerance, so the first CC one shouldn't read lower than 950R and the second one 640R...
pietro_moog
Been thanked: 50 times
Post by pietro_moog »
it's a cheap multimeter, like everybody else have. it's precise for all the other stuff.
loylo
Post by loylo »
OK.
I asked because I used to have a very cheap multimeter (less than 3€/5$).
Until I realised all my readings were rather wrong (especially while measuring tube amp transformers).
So I bought a better one, anyway at a reasonnable price (around 30€/50$), which is very accurate.
jymaze
Has thanked: 86 times
Been thanked: 171 times
Post by jymaze »
Sometimes my cheap multimeter drifts randomly when the batteries are not too fresh. I periodically check for accuracy on some 1% resistors i have at hand.
Ripdivot
Been thanked: 78 times
Post by Ripdivot »
Best thing to do is just lift one leg of each component before you measure it and even your "cheap" meter should be pretty close. :thumbsup
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
Ripdivot wrote:Best thing to do is just lift one leg of each component before you measure it and even your "cheap" meter should be pretty close. :thumbsup
+1 on lifting the leg to read a resistor. You will not get an accurate reading with the resistor in circuit. Either lift one leg of the component free of the circuit and read with a meter or better still :secret: read the colour codes on the resistor.
HHR18
Has thanked: 18 times
Post by HHR18 »
Are we ready for a vero guys? Or do we still think some values might be off?
pietro_moog
the schematic is good, the values are ok. we definitely are ready for a vero layout. are you working on one?
roseblood11
Has thanked: 366 times
Been thanked: 314 times
Post by roseblood11 »
pietro_moog wrote:the schematic is good, the values are ok.
Are all other resitor values definitely verified by reading the color codes? You can't measure parts values in circuit, unless you're dead certain that there's nothing in parallel...
pietro_moog
yes, color codes are real.
i can't remove the resistors from the circuit. those traces are very tiny and the CC resistors legs are big, there is a big risk of damaging the pcb.
lukatosh
Has thanked: 33 times
Been thanked: 186 times
Post by lukatosh »
so... the MKIII can't be built using 5457?
imaradiostar
Been thanked: 8 times
Post by imaradiostar »
Sure it can- you just can't be sure it'll sound exactly the same.
By adjusting the gain control, source resistors and bypass caps you should be able to get the same sound, more or less.
We don't know what they're doing to build them- they might be selecting transistors of specific gains anyway. My guess is no but it's possible.
jamie
roseblood11
Uwe stocked the MPF 4393:
http://uk-electronic.de/onlineshop/prod ... df4c9f94b8
:applause: :applause: :applause:
But his link to the datasheet doesn't work. I guess it's this one, but it's possible that he sells transistors from another manufacturer...
http://pdf1.alldatasheet.net/datasheet- ... F4393.html
mmolteratx
Has thanked: 93 times
Been thanked: 619 times
Post by mmolteratx »
imaradiostar wrote:Sure it can- you just can't be sure it'll sound exactly the same.
jamie
Nic has stated that they select FETs before, IIRC. Dunno what parameter they select for in particular, but my guess is pinch off voltage.
roseblood11
Is it possible to do that with a cheap multimeter?
Intripped
Has thanked: 991 times
Been thanked: 305 times
Post by Intripped »
HHR18
Post by HHR18 »
Once the schematic is verified, it might be nice if pietro_moog could post the voltages of the original one so we can compare the two. I never checked the voltages on any other of my Catalinbread builds so I don't think it matters that much.
pietro_moog
the schematic IS verified. unfortunately i sold the pedal, i can not do any more check
biglouis
Post by biglouis »
I can make a layout for this project, but, i don't know how to make layouts on vero.
If i make a pci layout, someone proposes to build?
HHR18
Post by HHR18 »
Vero would be greatly appreciated, don't have the skills to make it myself!
