Way Huge - Pork Loin  [traced]
Postby okgb » 28 Jun 2011, 00:50
Can't say i'm crazy about most of the amp sounds , but he doe's manage
to use the cae boost overdrive without it sounding horrible ,
Anyone know what the pork Loin pedal is based on [ or basic design ] ?
http://www.jimdunlop.com/blog/?p=3572&u ... dium=email
okgb
Has thanked: 198 times
Have thanks: 41 times
Way Huge Pork Loin
Postby rhcp311 » 25 Oct 2011, 05:52
Has anyone had a chance to trace one of these yet? I'm curious to see what's going on inside these, and there don't seem to be any threads where someone attempted to trace it quite yet.
Thanks! :thumbsup
rhcp311
Have thanks: 2 times
Way Huge - Pork Loin (Guts + Schematic)
Postby early.memoirs » 23 Nov 2011, 19:30
Here's the schematic i've traced from my own unit. Component numbering on the circuit board is a bit odd.
Guts (sorry for not using attachment, will upload the zipped file soon) :
I can take another picture of my PL if needed. Hi-res photo will be sent via e-mail.
First post here, hope to contribute more in the future. :block:
Reason: Updated schematic in other post below
For this message the author early.memoirs has received thanks: 14
Bernardduur (23 Nov 2011, 20:11), culturejam (23 Nov 2011, 22:06), lolbou (23 Nov 2011, 20:44), Nocentelli (23 Nov 2011, 22:06), phibes (23 Nov 2011, 19:35), PmCimini (16 Jan 2012, 20:33), reddo (28 Nov 2011, 07:53), RnFR (27 Nov 2011, 01:40), tp801 (23 Nov 2011, 20:23), WhiteKeyHole (23 Nov 2011, 20:54) and 4 more users
early.memoirs
Have thanks: 34 times
Re: Way Huge - Pork Loin
Postby lolbou » 23 Nov 2011, 20:49
Topics merged.
Congratulations on your reversing, looks like a pretty bitchy unit to trace! :applause: :applause: Thanks for this nice contribution to the forum... :thumbsup
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
Has thanked: 350 times
Have thanks: 240 times
Postby Bernardduur » 23 Nov 2011, 20:55
Awesome!!
Bernardduur
Has thanked: 87 times
Have thanks: 484 times
Postby coldcraft » 23 Nov 2011, 21:48
Me thinks the clean path should have more or less the same 3 transistor stage configuration both before and after the filter section.
coldcraft
Has thanked: 42 times
Have thanks: 83 times
Postby WhiteKeyHole » 23 Nov 2011, 22:39
The stages are just arranged differently superficially. They are the same except that, as drawn, R30 (equivalent to R13) is shorted. That's probably an error.
WhiteKeyHole
Has thanked: 41 times
Have thanks: 231 times
Postby coldcraft » 23 Nov 2011, 23:11
WhiteKeyHole wrote:The stages are just arranged differently superficially. They are the same except that, as drawn, R30 (equivalent to R13) is shorted. That's probably an error.
that was my thinking. for whatever reason, stage 2 was easier to interpret in my head.
coldcraft
Postby coldcraft » 23 Nov 2011, 23:22
it looks like the PN2484 is a general purpose transistor and could probably be replaced by anything common like the 2n5088/9
coldcraft
Postby early.memoirs » 24 Nov 2011, 03:33
oops, sorry for making a new thread on this particular subject, i wasnt sure that this newer way huge belong to the boutique section :mrgreen: (not in a bad way)
dont know how the first stage come up in a different arrangement on the drawing process :scratch:
i'll check it again and see if there's any error in the scheme (probably R30 as said).
early.memoirs
Postby coldcraft » 24 Nov 2011, 04:24
i don't think R30 is wrong, but the junction with C26 and R28 should NOT connect to 9v
coldcraft
Postby early.memoirs » 24 Nov 2011, 08:08
Scheme updated.
The first and the second clean stage is identical, except the value of C1 and C32 between B-E.
Vref junction is around +3V.
Any idea how to make this a bit brighter sounding on the OD side ?. It cuts highs even when fully CW.
I also found that the Presence control doesnt do much.
EDIT : Input and output capacitor shown as electrolytic caps on the scheme. However they're film caps in the actual board.
For this message the author early.memoirs has received thanks: 3
crguti (08 Nov 2012, 14:00), Quietus (27 Nov 2011, 15:23), RnFR (27 Nov 2011, 01:43)
early.memoirs
Postby Sweetalk » 24 Nov 2011, 13:24
Thanks a lot!!!, I've looking for this for a long time, I love the Pork Loin!!.
Lower R12 and the tone control will open up a little bit more.
Sweetalk
Has thanked: 23 times
Have thanks: 17 times
Postby coldcraft » 24 Nov 2011, 13:56
Lower C11 might make it brighter as well. I'm not sure it it would make the presence control better though.
Great work! I don't suppose you have a fat sandwich as well?
coldcraft
Postby early.memoirs » 24 Nov 2011, 20:16
coldcraft wrote:Lower C11 might make it brighter as well. I'm not sure it it would make the presence control better though.
I dont have it. Tried one in a music store, can't dial a good tone out of it (probably have to mess with the internal trimmers).
I'm working on my Swollen Pickle MKII though, parts value is nearly the same as described in the particular thread, except that they have 4 extra pots that really do a lot as opposed to my PL. A great Muff variant (without that annoying hummmmmm like the original one i used to have) :D
Sweetalk wrote:Thanks a lot!!!, I've looking for this for a long time, I love the Pork Loin!!.
TGP crowd says it nails "that Klon tone". :hmmm:
The clean part really blends well with the drive signal (better mix compared to sparkle drive).
And thanks for the suggestions. Will report back soon :block:
early.memoirs
Postby coldcraft » 26 Nov 2011, 04:55
definitely a good basis for some big modifications. I'm working on a tweaked up one now. Going for some more interesting Overdrive character. I'd like to see the input buffer become an OpAmp, and if it was inverting, we could drop the one at the output. Thoughts?
coldcraft
Postby RnFR » 27 Nov 2011, 01:44
early.memoirs wrote:
Scheme updated.
try making c11 smaller. that cap is dumping lots of highs to ground.
Has thanked: 150 times
Have thanks: 174 times
Postby coldcraft » 30 Nov 2011, 17:32
I am amazed at the mileage they got out of 22k resistors.
coldcraft
Postby Sweetalk » 30 Nov 2011, 22:34
Scheme updated.
Really ALL 22k resistors?
Sweetalk
Postby coldcraft » 30 Nov 2011, 22:42
actually no. looking back at the pictures, its definitely not all 22k. we need to get the values.
coldcraft
Users browsing this forum: calfzilla, Nikolas and 11 guests
