Keeley Compressor C4 [gut shot]  [traced]
Re: Keeley Compressor C4 [gut shot]
Postby sadrew » 08 Sep 2009, 08:56
sevinisthenumber wrote:Were do i place the pre gain knob into the circuit? Use a 100ka pot on the input as a variable resistor?
bump
sadrew
Have thanks: 15 times
Postby gkoerselman » 08 Sep 2009, 10:03
I assume that with the 'pre gain' you actually mean the 'clip' control (which is sometimes called 'clipping' or 'trim' I believe on the actual enclosures)...
This clip control is the 150k shown in my diagram connected by pad P1A-B and P2A-B.
gkoerselman
Have thanks: 36 times
Postby irmcdermott » 18 Feb 2011, 02:03
So the trimmers are still in there? As well as the external pots? I'm just a little confused reading through the thread.
irmcdermott
Has thanked: 19 times
Have thanks: 20 times
Postby seedseed » 31 May 2011, 10:12
Any verified schematics on this seems to be lying dormant
seedseed
Have thanks: 5 times
Postby bubstance » 31 May 2011, 11:13
It's a Ross clone, so any Ross layout/schematic will do just fine. Also: http://freestompboxes.org/viewtopic.php?f=7&t=4860#p64200.
bubstance
Has thanked: 80 times
Have thanks: 112 times
Postby seedseed » 31 May 2011, 13:20
Yeah but for all the hype i've heard about this pedal it can't be exactly the same with all components there has to be some form of variation. I'd like to know what it is.
seedseed
Postby WhiteKeyHole » 31 May 2011, 14:20
So buy one and be sure to tell us your findings.
WhiteKeyHole
Has thanked: 41 times
Have thanks: 231 times
Postby bubstance » 31 May 2011, 20:53
seedseed wrote:Yeah but for all the hype i've heard about this pedal it can't be exactly the same with all components there has to be some form of variation. I'd like to know what it is.
Don't trust hype. Remember the hype about the CJOD? Turns out that wasn't very different. Remember the Saffron Squeeze? That was a Ross too.
Hype =/= different.
bubstance
Postby seedseed » 03 Jun 2011, 10:15
Yeah no worries whitekeyhole with your money hahhaha
seedseed
Postby gormangox » 07 Jun 2011, 18:53
Fast attack (or recovery) is when the resistor is set to "near zero value" or when the resistor is 150K?
gormangox
Postby gormangox » 07 Jun 2011, 19:15
When that resistor is set to 10K I can hear only a little bit more volume but I can't see differences in the attack of the compression....
Can you explain to me which differences I should hear from a 150K to a 10K?
Which sound test can I make (playing the guitar) to hear better this difference?
gormangox
Postby WhiteKeyHole » 07 Jun 2011, 23:15
seedseed wrote:Yeah no worries whitekeyhole with your money hahhaha
WhiteKeyHole
Postby The Rotagilla » 08 Jun 2011, 06:10
Crimson wrote:Sustain pot: are you sure is reverse log?
Yes.
The Rotagilla
Have thanks: 57 times
Re: Keeley Compressor C4 [gut shot]  [traced]
Postby IvIark » 21 Jul 2012, 16:39
Currently unverified but I'll let you know when that changes. Instead of using two 1K resistors I left the trimmer used in the Dyna Comp and Ross Comp in place, so if you leave it in its middle setting that would replicate the C4 with the added advantage of being able to fine tune the extremes of the Clip control.
For this message the author IvIark has received thanks: 9
Ang3lus (22 Jul 2012, 07:23), atreidesheir (22 Jul 2012, 01:45), Duckman (21 Jul 2012, 18:49), guycapuano (30 Jul 2012, 18:06), irmcdermott (22 Jul 2012, 04:05), modman (27 Feb 2013, 23:50), Nocentelli (21 Jul 2012, 17:47), sinner (29 Jul 2012, 02:29), stompthis (02 Aug 2016, 14:56)
IvIark
Has thanked: 668 times
Have thanks: 678 times
Postby Xavier » 21 Jul 2012, 20:49
Many thanks for this one (and ALL the rest), Ivlark !!!. What a monster job...........
Xavier
Have thanks: 2 times
Postby Ang3lus » 22 Jul 2012, 07:32
yeah, thanks for this one :D
been wanting to try the keeley for ages.
Ang3lus
Have thanks: 13 times
Postby IvIark » 29 Jul 2012, 02:26
The vero has been verified so it's safe to build :mrgreen:
IvIark
Postby pedalgrinder » 30 Jul 2012, 09:42
great vero and thanks for the contribution but it's still not a verified keeley we still have no idea what's in and before someone says there fav comment of go buy it. We should do a tracers fund and contribute $10 bucks each so we all put in. I'll put in $10 anyone else up for it.
pedalgrinder
Has thanked: 202 times
Have thanks: 151 times
Postby IvIark » 30 Jul 2012, 10:21
If we bought one via the tracers fund we'd end up with exactly the same gut shot as you already have on page 1 of this thread. So this is no more and no less verified than any other pic > trace > schematic > layout on the site. In fact the quality of the gut shot with trace and BOM by vietpham, this is likely to be more accurate than some of our other traces.
IvIark
Postby IvIark » 30 Jul 2012, 11:25
Just as a follow up to that, here's the gutshot with the missing resistor values:
Looks pretty accurate to me so I'm not too sure what else we could be missing.
IvIark
Users browsing this forum: AluminumBird, art7710, dikenn, FuzzMonkey, Jeffology, Tash and 7 guests
