Xotic - RC Booster [traced]
My guess would be changes in the input cap and also in the Baxandall. Diodes could be anything. Germs might sound cool with bass.
Try increasing the input cap to either 100n or 220n. For the caps on the bass control, 68-100n, and the treble control, 10-15n. Maybe two 1n34a's in series on each side for the clipping diodes.
- george giblet
I was wondering what it really was
My guess for the treble cap is in the 10n region too. For the diodes I was thinking they are either removed or replaced by something along the lines of LEDs, MOSFETs, perhaps a combination with a silicon. Slightly harder clipping but more clean headroom.
The tone control bass frequencies are already fairly low. With the 10n cap the tone control isn't too far of the tech 21 stuff in normal use.
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
i tried this i burn the diodes what could be the problem??????>..... please help i really want to build an rc booster clonemadbean wrote:Not verified. Images are 600 DPI.
Code: Select all
Part Value C1 47n C2 1uF C3 150p C4 33n C5 33n C6 4n7 C7 1uF C8 4n7 C10 100n C11 10uF C12 10uF C13 10uF C14 2u2 R1 1M R2 10k R3 1M R4 10k R5 22k R6 Jumper R7 47k R9 4k7 R10 33k R11 4n7 R12 10k R13 470k R14 10k R15 470R R16 100k R17 22k R18 6k8 R19 15k R20 33k IC1 LF353N Q1 2N5088 Q2 2N5088 D1-D6 1N4148 TREB 50kB VOL 100kA BASS 50kB DRIVE 250kB
Hi guys, I'm trying to fit the RC inside a preamp I'm building and i was wondering if i can take the baxandall and the output buffer out and get away with it. I would not miss the EQ and the output would go directly to the tube so...do you think is possible?
- chicago_mike
I could cut down from 6 to 4 diodes and make a real clean bass bost perhaps...
Skyline FX 2013
- Silent Fly
I can't see why not. If you just need a buffer something simpler might be more effective (and less noisy).mikmix wrote:Can the Rc Booster work as a classic buffer if positioned at the start of the chain ?
- sevinisthenumber
okay. please dont laugh....
i etched this attached layout and did it backwards. This means everything is in mirror image as the traces are actually on the wrong side of the PCB... hope that makes sense. what is the best way to build this board out so that I don't waste it? I have the op amp on the trace side of the board to make the pins hi the correct traces but its still not working?
C.S. Lewis
C.S. Lewis
- sevinisthenumber
it works now. i just mounted the ic and transistors on the trace side....
C.S. Lewis
C.S. Lewis
- fosnal1950
And how does it sound ? What amp are you using it on ?
I heard it being used on a De luxe rev and was impressed !
Hi Everyone,
I'm quite new to the opamp/TS-concept so maybe this might be a silly question: I recently finished my RC (on a breadboard, so its somewhat more prone to bugs) and it shows quite a lot of hum, which disappears when touching the strings or some other mass point. I'm just curious whether that is normal for the RC cause I've heard that it is especially silent!? Also, it doesn't really give me that much of a loudness boost, so for me it seems that there's something wrong.
IC is TL072, diodes 1N4148, transistors are BC549, mojo-resistor is metal though , offboard-wiring is standard with 3pdt from tonepad. I checked the wiring more than twice, everything seems to be allright
Any ideas...?
Christian
Any ideas...?
Christian
- chicago_mike
Has anyone built Madbeans RC Booster? I cant get mine to pass signal. Everything is wired / soldered up according to the pdf.
Skyline FX 2013
- jstbrowsin
- Grease Monkey
I can verify that MadBeans circuit works. I built one and it worked first time lucky me I guess. I'm sorry I can't help with the trouble-shooting process as I'm a paint by numbers sort of guy at the moment but the guys here are excellent with that sort of thing, so I'm sure you will be up and running in no time. What I can offer is "check, recheck and then check your recheck".
Good luck Mike
Good luck Mike
kev01 wrote:This one wins the gooooooooooop award. That has more silicone than Pamela Anderson.
