Barber - Tone Press
Re: Barber - Tone Press
Postby briggs » 15 Mar 2009, 11:58
It's an OTA - read the last page. The general set up looks to be a ross compressor style circuit with a clean blend function.
I am Klon.
briggs
Has thanked: 30 times
Have thanks: 124 times
Postby madbean » 20 Mar 2009, 19:59
Any chance we could get some pics from you?
madbean
Postby IvIark » 21 Mar 2009, 03:38
Just hoof it out, sticky pads can be replaced without any need for repair. In fact if you do it I'll send you the sticky pads free of charge! :)
IvIark
Has thanked: 668 times
Have thanks: 680 times
Postby NOC3 » 22 Mar 2009, 06:26
ibodog2 wrote:I got one of these in a trade last weekend and it didn't work. The guy had removed the chip and put in a socket. Then he decided to try out a JRC4558d chip in it.
:slap:
LOL!!! :lol:
NOC3
Has thanked: 10 times
Have thanks: 28 times
Postby madbean » 22 Mar 2009, 07:39
Thanks for the pics!
madbean
Postby madbean » 09 May 2009, 18:26
Killer. I think it could be traced now. By someone not me. :P
madbean
Postby analogguru » 10 May 2009, 01:03
Boahhh..... how boring......
1.) take a Ross Compressor and place a 1µF electrolytic in parallel to the 150k in the side-chain.
2.) place a µ-amp stage in parallel to the input (nobody knows why there are two input-buffers in parallel, so don´t ask me).
3.) connect instead of the 50k output-poti of the Ross compressor a stereo 50k lin poti.
4.) connect the second half of the stereo-poti in reverse to the output of the µ-amp-stage
5.) mix the middle lugs of the stereo-poti with two 100k resistors and connect it to the input of another µ-amp stage
6.) after this µ-amp stage place a 100k log poti for output level
.....and you have got it.
If you need a schematic visit the Barber-homepage in a couple of days, there will be a project for the Tone Press soon - like it was done with the Ltd after it appeared on FSB.org.
Have thanks: 116 times
Postby Ben N » 10 May 2009, 07:41
Hmmm... I wonder: why mu-amps? Why not just use a dual opamp?
Ben N
Have thanks: 9 times
Postby 22uf » 10 May 2009, 12:55
ibodog2 wrote:I decided to rebox this one to get the jacks on the top. I hate it when they use big big boxes and put the jacks on the sides. Anyway that means the board is flippable now. Let me know ASAP if these shots don't do the trick before I put it back in another box. Also I'd appreciate advice on where to add the switch to put in a "janglebox" mode in this thing. :)
analogguru wrote:
I am not so much interested in getting the darker setting of the Janglebox but rather the bright jangle setting.
Then do a search for the 150k resistor at the output of the CA 3080 (or BA 6110) ofyour dynacomp (clone) and simply remove the capacitor which is connected in parallel (typically 1nF) to this resistor and you´ve got it.
From a previous post - not sure if that will help. I'd be interested in getting more of a Janglebox sound out of a tone press also..
22uf
Have thanks: 2 times
Postby NetStar » 13 Jun 2009, 14:22
Where are the details on the LTD?
I take it they are no longer there.
Thanks.
NetStar
Postby Seljetnoma » 14 Jun 2009, 18:22
ibodog2 wrote:This is the cap that I put on a switch.
Pardon my ignorance, but what does it do when you put the cap on a switch?
Whats the jangle mod exactly?
Greets,
Frank
Seljetnoma
Postby phuzle » 05 Aug 2009, 01:52
I just wanted to bump this thread because I couldn't find any info on Barber's site about a Tone Press schematic or something similar. I'm interested in the BYOC comp which seems similar, but the Barber looks simpler and from what little I know its supposed to be a little better. Also, I don't have any 3080's, (I'll have to order one, but before I do) are there any good compressor schematics that use different IC's (besides the BYOC's ba6110)?
Has anyone RI'ed the Keeley to see what differences there are between that and a Ross?
phuzle
Postby RnFR » 24 Jul 2010, 13:54
Ben N wrote:Hmmm... I wonder: why mu-amps? Why not just use a dual opamp?
found this on the Barber site-
Re: Tone Press as Clean Boost?
by David Barber » Sat Apr 11, 2009 12:20 pm
notyalcer wrote:
I just posted this at TGP right before I saw this new board...
I have a Tone Press that I am not using much, and inspired by this phrase from the manual that it can be used as "a “class A” clean boost pedal with about 8 db of boost", decided to try it out as such (by turning the blend and sustain knobs all the way CCW and using volume at about 3 c'clock). I am comparing it to an AMZ minibooster I built which is JFET based. The Tone Press has a heavier tone to it, seems to boost the low end more than the highs, but by comparison the AMZ is fairly linear but with a high end emphasis that adds sparkle. I have not tried the TP as boost with the band yet, but it seems like a good flavor to add. I use a boost to buffer and lift the signal a bit, not to slam the input of my amp.
I have two questions: is anyone else using a TP as a simple clean boost with success? and is the gain section of the TP at all similar to either the Launch Pad or B-Buff circuitry? Probably a better question for Mr. Barber, I know. Thanks.
The Tone Press uses two FET SRPP sections in the "dry" and mixer sections, these are biased and gain staged for headroom and tone as the primary concern. This is a very different approach to SRPP use, than the common "boutique booster" that we see redundantly throughout the hand built pedal landscape. In the Tone Press the SRPP adds lots of sweetness and a slight "tube style" softening that using bipolars or an opamp did not seem able to provide. The Launch Pad has even more headroom and output than the Tone Press, by using a balanced line driver circuit with 24 VDC of supply internally, we can get near perfect rendition of the input reflected at the output, but with lowered impedance and about 20db of available boost.
The Tone Press is usually seen as having a slightly colored sweetness than the LP, and the LP has tremendous output available while staying very clean (most boosts start to clip while going to high boost levels). So you have different flavors and different available boosts at output.
PRS SE One, PRS SE EG, Anderson Hollow T, Anderson Hollow Classic, Hamer Artist, Duncan Seth Lovers, All Barber Pedals, Barber Echelon.
http://www.barberelectronics.com/sounds.html
http://www.barberelectronics.com/pickuptest.htm
David Barber
Has thanked: 150 times
Have thanks: 174 times
Postby layupe » 22 Sep 2010, 08:35
analogguru wrote:Boahhh..... how boring......
Sounds even easy when you say :wink: but im not able to figure out how to add those "µ-amp stages" to the Ross Compressor :scratch: Is there any schematic for this?
I understand this one can be boring for most of you being just a modded/improved? Ross clone but im sure im not the only one here that would love to build one since the Tone Press is reported like being a very good sounding compressor...
It would be great to have an schematic and maybe a layout too to follow and make things easyier for people like me but any help about how to acomplish this changes in the original Ross to get the Barber's take of the Ross would be much appreciated aswell...
layupe
Postby mirosol » 04 Nov 2017, 09:06
Seems like solder side photos were gone, so here you go. Got mine with clean signal path dead and traced the problem to both 5457s of the µamp being shorted. No idea how that happened. Swapped those for new ones and it's very nice sounding thing. And since i've mostly seen "parallel compression" done with inverter mixer after OTA, i didn't find this approach boring at all :)
+m
For this message the author mirosol has received thanks: 3
dv8r601 (18 Nov 2017, 05:48), Manfred (04 Nov 2017, 09:36), Pokfor (01 Jun 2018, 08:13)
mirosol
Has thanked: 156 times
Have thanks: 363 times
Postby Pokfor » 04 Jun 2018, 13:30
From photo and this topic, as well as other photos from here http://www.barberelectronics.com/custom ... _blog.html I tried to remove the circuit.
It turned out this.
Errors are possible, be careful.
There is a second version of this pedal with two switches. I saw several photos of this version and reflected my assumptions on the diagram in red.
For this message the author Pokfor has received thanks:
Manfred (04 Jun 2018, 13:51)
Pokfor
Have thanks: 12 times
Previous
Users browsing this forum: art7710, dgc85 and 13 guests
