Chunk Systems - Agent 00FUNK!  [traced]
Coolhat
Post by Coolhat »
I´m resurrecting this thread because I am at my wit´s end with this build. I can not get any kind of filtering going, the sound just goes "through" the circuit unaffected.
I have built it using tagboardeffects vero layout and I´ve gone over every single component, joint, link and cut dozen times already and I can not find a fault. My voltages are more or less the same as the ones JohnK posted earlier. I´ve probed the hell out of the circuit, but to be honest, it´s not much use when I do not know what I am supposed to be looking for.
The thing is, I´m still quite new at this pedal malarkey and this is my most complex project to date. I´ve done some reading on ECFs and I have some idea how they work, but I´m struggling to make sense of this circuit. So I would really appreciate some help. I´m not expecting people to do my troubleshooting for me, but I would be very grateful if anyone could help me understand what is and what should be going on with the circuit. Perhaps some kind of basic walk-through or even just some tips on where to focus my attention.
Thanks in advance!
chicago_mike
Has thanked: 22 times
Been thanked: 316 times
Post by chicago_mike »
This might be a bust....
I tried to build JohnK's version twice...No go.
I'm gonna try when I have some free time to redo the layout. And double triple check.
Skyline FX 2013
johnk
Has thanked: 36 times
Been thanked: 293 times
Post by johnk »
Hmm. i've built 3 of them using that layout and all of them work perfect. here's my latest one:
chicago_mike
IT WAS ME!! :slap: :slap: :slap: :slap: :slap: :slap: :slap: :slap: :slap: :slap:
Skyline FX 2013
johnk
Post by johnk »
chicago_mike wrote:IT WAS ME!! :slap: :slap: :slap: :slap: :slap: :slap: :slap: :slap: :slap: :slap:
so it works now?
Paul_5
Post by Paul_5 »
you know, if you use a 4PDT switch for the sweep direction you can switch between two independent pots for pitch - makes it easier than monkeying around on a gig...
The sounds in my head don't match the sounds from my amp, I guess that's why I'm here...
Paul_5
Post by Paul_5 »
Is it ok to substitute the LM324 with another TL074? I'm not terribly au fait with opamps, so any advice is gratefully received.
