Moderators: Greg_G, culturejam, moderators
by culturejam » 05 May 2009, 21:51
Okay guys, here's a fun one to play around with.
I was merely tapped to post this, and I was in no way involved with the reversing or drawing the schem. I don't want it to seem like I am trying to take credit here. I'm just the messenger.
This has been played around with a bit on the breadboard, and it is believed that the schematic below is in fact an accurate rendering of the BJFE Dyna Red Distortion. The schematic was donated to FSB anonymously. Apparently this version was slightly modified from the stock circuit on request of the purchaser. Don't know much beyond that. Others here can comment more extensively and with more authority than I can.
Have fun!!
culturejam
- FSB Moderator
by briggs » 05 May 2009, 22:40
This version was modified to contain slightly more lower mids. A simple change in the feedback loop caps should get you back to where the original is.
briggs
- Opamp Operator
by madbean » 05 May 2009, 22:46
So, we have a variation on the Honey Bee, it seems (or vice versa). Thanks for the schem!
madbean
- Degoop Doctor
by IvIark » 05 May 2009, 23:29
Rat-tastic
IvIark
by SPeter » 06 May 2009, 01:45
SPeter
by Lovekraft » 06 May 2009, 03:26
IvIark wrote:Rat-tastic
Ratish indeed. Clipping in both the loop and to ground. Hmm.
Ethan
Lovekraft
by soulsonic » 06 May 2009, 08:11
Lovekraft wrote:Ratish indeed. Clipping in both the loop and to ground. Hmm.
Ethan
You can also see that in the ProCo Brat/Roadkill... it had four 1N4148 diodes in the loop along with the usual to ground.
by Lovekraft » 06 May 2009, 19:18
I didn't know the Brat used that clipping arrangement. I've seen the concept before, on Beavis's Rat mods and BYOC's Rat type pedal, not sure if both sets of diodes are used at once on those pedals. Bjorn is a pretty sharp fellow, bet it sounds great.
Ethan
Lovekraft
by Whoismarykelly » 07 May 2009, 00:25
Woah woah woah wait. How is this a variation of the Honey Bee? Is there now an available HBOD schem? Also, whats up with the opamp in there from a builder who often says his circuits are all discrete? Confused. Thats what I am.
Whoismarykelly
by IvIark » 07 May 2009, 00:50
He fibbed
IvIark
by Fuzzer » 07 May 2009, 01:04
Whoismarykelly wrote:How is this a variation of the Honey Bee?
Fuzzer
- FSB Moderator
by Whoismarykelly » 07 May 2009, 07:51
Fuzzer wrote:Whoismarykelly wrote:How is this a variation of the Honey Bee?
Someone has given me relevant information. I now understand. You should keep fighting the good fight.
Whoismarykelly
by Ghandi » 07 May 2009, 22:55
big thanks man!
could you please tell us what the original fb-loop caps are briggs?
oh, and I'd love to see the honey bee schematic as well!!!
Ghandi
by briggs » 08 May 2009, 16:46
As soul will confirm a 100n cap instead of the 0.47uF one should get you the stock sound. Even more fun would be tointegrate the timmy bass control into a build, ultimate flexibility.
briggs
- Opamp Operator
by picassochild » 08 May 2009, 17:22
briggs wrote:to integrate the timmy bass control into a build, ultimate flexibility.
awesome idea!!!
picassochild
by lynessmy » 18 May 2009, 04:09
I never have luck in LED Clipped devices.....CrunchBox first then DynaRed.
I'm using 3mm diffused RED LED.
It seem lose some PRESENT.
when shop for LED for clippers, Is there any particular parameter i need to look into ?
lynessmy
by soulsonic » 19 May 2009, 08:18
lynessmy wrote:I never have luck in LED Clipped devices.....CrunchBox first then DynaRed.
Sometimes putting another diode in series will help it to sound better. I think a BAT41 in series can make an LED sound much more smooth. It seems that some LEDs tend to turn on too sharply - the different type in series gives it a softer knee (sometimes!).
by lynessmy » 20 May 2009, 18:04
soulsonic wrote:lynessmy wrote:I never have luck in LED Clipped devices.....CrunchBox first then DynaRed.
I tried diffused yellow led and it work better now. It sound more transparent and yet the distortion is heard at the back.
I will your your idea if it nail down my expectation. Thanks.
lynessmy
by Ben N » 20 May 2009, 23:19
picassochild wrote:briggs wrote:to integrate the timmy bass control into a build, ultimate flexibility.
awesome idea!!!
Just take note of the fact that Paul says (in the Timmy thread) that in the next iteration of the Timmy he is planning on moving the bass cut ahead of the opamp stage. I guess a variable resistor in parallel with a series cap?
Ben N
by briggs » 20 May 2009, 23:57
The bass cut integration is currently affecting the gain of bass frequencies amplified within the opamp stage. I can't see the advantages in making the change proposed, hmmmmm but maybe, whereabouts does he mention it, I'm struggling to find it
![a_help [smilie=a_help.gif]](./images/smilies/a_help.gif)
briggs
- Opamp Operator
Users browsing this forum: beand, billonious, Branimir, burning tires, bussche, Depleted, DHendo, difeng, dread pierat, enacoid, felicity kendal, FenderStrat62, forestcaver, geoff_p, Hendrix, iamadamb, Lawnchair, lesmanaz, Liquitone, mikeC, moaner70, patafix, pz, rhandy gaye, spiffy chap, twostring, Uma Floresta, WangoFett, Woodraw, x12, zequitur and 13 guests
