Barber Electronics - Dirty Bomb [gut shots + schematic] [traced]
- J0K3RX
- Degoop Doctor
The layout I posted goes along with the original DB, if you read the entire post you will see There is a 91 ohm resistor at the junction of R16 and C16...
Look in the bottom right corner under the 82n cap - White, brown, black = 91 ohm
original schematic
As for the LED pads that's pretty simple to figure out, I thought?
Edit: ah, now I see you were questioning the placement of the 91 ohm and not it's existence in the mix... my bad
original schematic
I have an original DB which I bought used. Like it but I have to keep the treble control down at 9.00 - everything above that is too fizzy for my set up.
I have read about a "cap mod" for this pedal but could not find any details except that it involves a 2n2 cap.
Any input would be greatly appreciated.
Thanks, Stephan
Thanks, Stephan
Got the answer - it's a cap across the volume pot.
I did another variation of the cap mod. I used a 0.0033uf cap in series with a 22k resistor across the volume pot, which is in essence the Rectifier presence control but turned down completely. Like it so far - takes a bit of the fizz off without neutering the tone.
Since the presence pot in the rectifier is a 25k linear pot, you can choose anything up to 47k to be in that range - or add a small trimmer.
Cheers Stephan
Cheers Stephan
