Skreddy - Mayo
Re: Skreddy Pedals - Mayo
Postby nokaster » 29 May 2008, 22:17
i got the info from the schematic in the first post of this thread...
nokaster
Postby Gila_Crisis » 29 May 2008, 23:03
all the 100ohm resistors are marked as 120ohm and then there is a 100pF cap marked as a anfi rfi, which i don't know where you got it.... :?
Gila_Crisis
Have thanks: 66 times
Postby Skreddy » 30 May 2008, 02:44
Gila_Crisis wrote:all the 100ohm resistors are marked as 120ohm and then there is a 100pF cap marked as a anfi rfi, which i don't know where you got it.... :?
Right. Plus I don't use a pull-down resistor (the way the bypass switch is wired obviates this), my dc-protection diode scheme is not the standard 1N4001 to ground (it's either a schottky or a germanium in-line), and the led resistor is way too low for any modern bright led.
Skreddy
Have thanks: 226 times
Postby vanguard » 30 May 2008, 07:11
so, skreddy...when's your next big muff iteration coming out? i'm so impressed by the mayo circuit and your handling of this thread i want to buy one of your pedals, and not off ebay. any chance of a custom build?
vanguard
Postby Skreddy » 30 May 2008, 07:57
vanguard wrote:so, skreddy...when's your next big muff iteration coming out? i'm so impressed by the mayo circuit and your handling of this thread i want to buy one of your pedals, and not off ebay. any chance of a custom build?
When I'm done with the rollout of my echo, I was planning to finish designing and tweaking my version of the FSB.o opensource fet overdrive aka "mosfet madness". And then maybe dial in a new muff design using whatever decent-sounding, modern transistors win my taste test. I'm trying to get away from NOS transistors, 'cause they always seem to run out just as a product achieves its highest popularity.
But Scotty at ProAnalog has sent me 4 sample bags of transistors, most of which are hard to find, when-they're-gone-they're-gone kind of things, and I'm really taken by one particular model. What I'll do with them is probably make an intentionally-overpriced Mayo-esque limited-edition reissue kind of thing, just to pay the tax bill. Oh yeah; riding a small-hobby-turned-business into profitability without hiring a certified public accountant is not advisable.
Custom builds are possible.
Skreddy
Postby nokaster » 30 May 2008, 11:42
I didn’t have any 100R’s, so i used 120R’s in my build. Forgot to change that in the list.
CRFI = anti Radio Frequency Interference
Pulldown resistor, polarity protection diode and power filtering cap were added as I’m used to.
All in all I’ve posted the wrong emitter resistor values, all the other stuff is added protection/filtering etc…
So excuse my mistake on the 100R's.
Change RLED to taste...
Hope someone finds the layouts and list usefull.
nokaster
Postby RiGLEY » 30 May 2008, 11:49
I have finished this pedal, it's a very mean little machine, and it's working great! Thanks to all who have contributed. I've used 120 Ohm emitter resistors. How does this affect the sound? Should I try to get some 100 Ohm's and replace?
RiGLEY
Postby Skreddy » 30 May 2008, 17:12
RiGLEY wrote:I have finished this pedal, it's a very mean little machine, and it's working great! Thanks to all who have contributed. I've used 120 Ohm emitter resistors. How does this affect the sound? Should I try to get some 100 Ohm's and replace?
What'd you use for transistors? The 120 Ohm emitter resistors will just calm it down a bit, make it more controlled-sounding, and probably reduce the noise level slightly compared to 100 Ohms. Who knows if its better or worse than stock unless you experiment; likely just a matter of taste and also on whether the transistors you used benefit from this kind of treatment. Probably very subtle regardless.
Skreddy
Postby RiGLEY » 30 May 2008, 21:59
Skreddy wrote:What'd you use for transistors? The 120 Ohm emitter resistors will just calm it down a bit, make it more controlled-sounding, and probably reduce the noise level slightly compared to 100 Ohms. Who knows if its better or worse than stock unless you experiment; likely just a matter of taste and also on whether the transistors you used benefit from this kind of treatment. Probably very subtle regardless.
Q1 (BC549B) :
e : 33 mV
b : 0.6 V
c : 3.91 V
Q2 (BC238B) :
e : 32 mV
b : 0.62 V
c : 6.23 V
Q3 (BC547B):
e : 31 mV
b : 0.61 V
c : 3.79 V
Q4 (BC238B):
e : 1.05 V
b : 1.64 V
c : 4.78 V
I have tried to match the mayo voltages measured by Zero. I like how it sounds with these.
RiGLEY
Postby vanguard » 30 May 2008, 22:10
so i think my volume problem may be due to using an incorrect cap somewhere? i can't figure out how to read them accurately. first person to tell me if the following guesses i used were correct wins my thanks.
first cap says "110k". i assumed this to be 100pF?
47k = 47pF ???
472M = 4.7nF ???
vanguard
Postby Skreddy » 30 May 2008, 23:31
vanguard wrote:so i think my volume problem may be due to using an incorrect cap somewhere? i can't figure out how to read them accurately. first person to tell me if the following guesses i used were correct wins my thanks.
47k = 47pF ???
472M = 4.7nF ???
The schematic at the beginning of this thread has the correct values in it.
Skreddy
Postby vanguard » 31 May 2008, 00:25
oh, snap. i just had v2 in the wrong place all this time. it just fired up like a monster out of hell. thanks a million billion and great work here.
:applause:
vanguard
Postby nokaster » 01 Jun 2008, 14:40
somehow the edit button wasn't where it should be.
here's an update on the big muff versions list.
nokaster
Postby swt » 04 Jun 2008, 18:14
fact is...buy an original today, and you'll have to wait for 20 years, and if it was a good one (luck on your side), you can sell it on ebay ( or whatever at the moment), for good bucks.
But you buy something from a booteeker, and the worst deal will be have your money back from a resell. But chances are you'll get more than you pay for it.
SO... i'm glad there are lots of chances on the market. each one knows where to invest their money. Anyway, thanks to skreddy for the good info and good vibe, and please try to stay on the market. good luck!.
swt
Have thanks: 9 times
Re:
Postby Brian M » 05 Jun 2008, 05:43
Greg_G wrote:Marc's one of the good guys in the industry.
He's honest about his designs, reasonable pricing, no goop, and his stuff sounds great IMO.
The Screw Driver is a classic.
Marc is one of my favorite people in the stompbox market. He's a sharp guy on many other topics as well.
He's also willing to deal with buying and testing obsolete parts. That's something I've never wanted to even try beyond building one or two pedals.
Brian M
Have thanks: 53 times
Postby vanessa » 07 Jun 2008, 18:46
Skreddy wrote:
vanguard wrote:But Scotty at ProAnalog has sent me 4 sample bags of transistors
I wonder where he got a hold of an original MK1 Tonebender to dissect for his MK1 clone? $250? :roll: Maybe I should get a kickback for providing him with the schematic? :lol:
vanessa
Have thanks: 10 times
Postby Gila_Crisis » 10 Jul 2008, 06:20
nokaster wrote:i want to post a V2 for my layout, which can be used by those who don't want the split up resistance from 9V to C of Q4.
i just wanna say thank you a lot for this layout. i just built a Green Urss Big Muff with it and it sounds awesome!!!!!
:cheers :cheers :cheers
Gila_Crisis
Postby Cow4prez » 31 Jul 2008, 19:51
I dunno, based on this youtube clip, it's probably better to not build a mayo... and you can save yourself $300 USD.
http://www.youtube.com/watch?v=X8qEp-fHNK4
Cow4prez
Have thanks: 5 times
Postby JimiB » 31 Jul 2008, 21:07
I think the mayo in that clip sounds way better thatn the EH
JMHO
YMMV
:thumbsup
JimiB
Postby nokaster » 31 Jul 2008, 22:00
it is my pleasure!
i see pics popping up of muffs build with my layout, but people don't tend to share there opinions or results, so many many thx for your kind words!
so far i've build the mayo... sounded wicked!
and i've got the boards finished for a ram and a triangle, but i've been lazy with the off board wiring. :oops:
should finish those soon!
nokaster
Users browsing this forum: Frost, marshmellow, nickthemen, SpencerPedals and 6 guests
