yes it starves the supply to the CMOScommathe wrote:That bias control is interesting. Is it just starving the op-amps and preventing them from amplifying the whole wave properly?
it makes the pedal very flexible.
you gonna have to ask the pros and i ain't oneMbas974 wrote:IC4069 makes too much noise on the max distortion.
Is there a design solution for this IC
or there is a alternative IC for reducing noises ?
Short answer: no.Mbas974 wrote:IC4069 makes too much noise on the max distortion.
ggedamed wrote: Actually, Reeza is not supposed to be dark. If it is dark, the capacitors are bigger than they should be. Mine sounded dark until I discovered one of the tone caps being 100n instead of 100p ( , I know).
@TubeHuger: wire connections in a pedal are too short to have a significant effect on tone.
Maybe this?zedsnotdead wrote:Now im scared
