Emma - Reezafratzitz [ goop-alarm ]  [traced]
Fuzzer
Been thanked: 21 times
Post by Fuzzer »
gtrplaya101 wrote:Verified?
Verify it.
miwanone
Post by miwanone »
Here you go, bigger pads! So still unverified, but it won't be long... ;-)
https://img17.imageshack.us/img17/9978/layoutw.png
https://img253.imageshack.us/img253/92/ ... ansfer.png
marshmellow
Has thanked: 20 times
Been thanked: 127 times
Post by marshmellow »
If you make sure that the schematic you have drawn is correct (by comparing with the original and using the ERC), Eagle does that for you if you use the DRC. That's what it's for.
miwanone
Post by miwanone »
Checked by DRC, made a few little changes.
Still not verified ofcourse.
https://img214.imageshack.us/img214/92/ ... ansfer.png
https://img83.imageshack.us/img83/9273/layouta.png
HENK
Has thanked: 312 times
Been thanked: 5 times
Post by HENK »
Hello
some News for this??
Greets Thilo
miwanone
Post by miwanone »
It's still unverified, but here's the latest version of my PCB-design. The only jumper left is on a pot (bias). I corrected some extreme angles in the traces and gave some of the traces a bit more space.
https://img26.imageshack.us/img26/9978/layoutw.png
https://img8.imageshack.us/img8/92/readyfortransfer.png
miwanone
Post by miwanone »
Etching now, hope to verify it within a few days (missing some of the components)
:D
miwanone
Post by miwanone »
Ok, at this point I've got a low gain output with a volume drop. All the pots work like they should, the LED is working correctly, the bypass signal is ok. I swapped a few components for other values (like 10nF instead of 6n8, 91pF instead of 100pF) because I didn't have them, but I don't think that could be the problem. Could it be the IC? I used a 4069.
Any tips?
miwanone
Post by miwanone »
This is one hell of a confirmed build! :D
I did make some small improvements in the PCB design, so here is my latest, VERIFIED version:
Ready for transfer
Layout
miwanone
Post by miwanone »
And my design.. :)
quaternotetriplet
Has thanked: 10 times
Post by quaternotetriplet »
Please post the parts list. thanks
miwanone
Post by miwanone »
Please read the whole topic. Thanks 8)
distortion_gfx1
Has thanked: 26 times
Post by distortion_gfx1 »
great job guys :applause:
I wish we make the board smaller that it would fit to a small 1290NS enclosure!!!
Btw, tnx alot!!!! weeeeeeeeeeee :mrgreen:
Barcode
Been thanked: 32 times
Post by Barcode »
was the volume drop resolved?
miwanone
Post by miwanone »
I can post eagle files on request, I've got some sound samples here! It's clean, clone, original.
http://www.gitaar.net/forum/index.php/f ... eeza_1.mp3
http://www.gitaar.net/forum/index.php/f ... eeza_2.mp3
http://www.gitaar.net/forum/index.php/f ... eeza_3.mp3
No volume problems at all, works like a charm. Here's my build, next to an original:
*edit* just so you know, all of the samples were recorded using a fender strat, into a hotrod deluxe. 8)
Valoosj
Post by Valoosj »
I finished making my own smaller layout. It should fit in a Zvex style enclosure. Will post the files here when it's verified.
Bazinga!
Barcode
Post by Barcode »
miwanone wrote:I can post eagle files on request, I've got some sound samples here! It's clean, clone, original.
Well, is the layout you posted just before my post the same? Is that the functional one? If so, no need for the Eagle files as far as I'm concerned.
miwanone
Post by miwanone »
Yes, it's the same verified functional pcb.
chriscustom
Post by chriscustom »
Greetings! I badly speak in English, therefore I am sorry.
It seemed to me that sound examples under these references:
http://www.gitaar.net/forum/index.php/f... eeza_2.mp3
And
http://www.gitaar.net/forum/index.php/f... eeza_3.mp3
The identical. I am mistaken?
miwanone
Post by miwanone »
You are right, the last one should be this:
