Emma - Reezafratzitz [ goop-alarm ]  [traced]
whammy
Post by whammy »
A lot of work went into that goop job.... all to no avail.
Now he can save himself some trouble and not goop.
Bernardduur
Has thanked: 94 times
Been thanked: 735 times
Post by Bernardduur »
Awesome!
chris_d
Post by chris_d »
So what does this thing sound like? Is it a high gainer?
That is a lot of fucking goop. Gadzooks.
-chris
toneman
my favorite amplifier: anything that works
Completed builds: meatolation, wobolation, ringolation clones, PAiA synths/modulars, dipthonizer clone, MOTM modules, pedal mods and repairs
Has thanked: 183 times
Been thanked: 45 times
Post by toneman »
Ahhhh...the smell of burnt epoxy....mmmmmm.....hack hack hack argggggg!!!
(cough) (cough)
So the "bias" is just "starving the drain"(?) :hmmm: Verrrry interesting (sounds like Sgt Shultz)
Basic tone control.... [smilie=a_zzz.gif]
Maybe another TONEcontrol at/in place of R4 ? :?:
AWESOME WORK MODMAN ! :applause:
Now go get a bottle of Oxygen :)
Make that a LARGE :lol:
8) T
Tone-to-the-Bone
sonicvi
Been thanked: 8 times
Post by sonicvi »
Does it sound anything like the old EH Hot Tubes?
picassochild
Post by picassochild »
awesome work Modman!!! Let's tweak it for more mids...
jrc4558
Post by jrc4558 »
One mod to it would be to add an output buffer. Inverters have quite high output impedance, may be an issue driving low impedance inputs. How I found out? Millenium bypass wasn't working with it...
picassochild
check this modded Emma... seems it's pretty easy to mod for more mids...
MoreCowbell
Been thanked: 15 times
Post by MoreCowbell »
picassochild wrote:check this modded Emma... seems it's pretty easy to mod for more mids...
fixed the link for you :)
celadine
Has thanked: 16 times
Been thanked: 19 times
Post by celadine »
A+ dee-goop! Thanks!
:thumbsup
paperhouse
Post by paperhouse »
i'd be eternally grateful for a vero layout :wink:
JiM
Proco Rat
Hot Harmonics
Crackle Not OK
Has thanked: 70 times
Been thanked: 66 times
Post by JiM »
paperhouse wrote:i'd be eternally grateful for a vero layout :wink:
Be careful when you say that, eternity can be quite long, esp. toward the end. 8)
Untested !!!
Untested !!!
Untested !!! <br />Part numbers match previously posted schematic, Eagle files available on request.
Untested !!!
crystalnacht
Post by crystalnacht »
You OWNS!!!
But... What type of BJT input buffer?
2N5088? 2SC1815??
or Some BC series?
ANYONE help!
nickthemen
Has thanked: 36 times
Been thanked: 14 times
Post by nickthemen »
I build this one, and i must say this is the best amplike sounding overdrive i played in a long time, the feel is very tube and cleaning up very well on my strat wich has a 150pf cap on the vol pot. The only thing i had to alter was c10 and r14 into 10n and 39k because on the neck pu it was sounding to muddy.Maybe there is a mistake on the schematic,i played on a original that did not have this problem.I used a bc550c as input buffer and build 2 footswiches in the box, one for a extra gain control and the other as true bypass.Has anyone build this one yet?
JeawJaw
Post by JeawJaw »
what is type of IC1 ?
and
what is part name of IC1?
PurplePeopleEater
Been thanked: 5 times
Post by PurplePeopleEater »
JeawJaw wrote:what is type of IC1 ?
and
According to what is printed on the schematic -
"IC1 is unknown, probably a CD4069 or 74HCU04"
earthtonesaudio
Been thanked: 75 times
Post by earthtonesaudio »
That actually looks like a pretty nice circuit. I think the "bias" control would more appropriately be called "symmetry" but whatever...
Add that and an output buffer and I would give that circuit my stamp of approval. Oh and cease and desist with the epoxy crap. :D
kantul
Post by kantul »
I build reezafratzitz.
my video:
IC: CD4069 & transistor bc549 .
nickthemen
Nice clip, what speaker/amp did you use?, I build one to ,sound was good but there is no smooth transition from clean to drive and back on mine.
kantul
Post by kantul »
nickthemen wrote:Nice clip, what speaker/amp did you use?,
VOX amplifier.
