Emma - Reezafratzitz [ goop-alarm ]  [traced]
Re: Emma - Reezafratzitz [ goop-alarm ]
Postby hendershot » 07 May 2009, 20:09
Hello New guy here, long time follower. Was wondering which IC was used in verified version. Bill of materials mentions 4049 but that chip is 16 pin and the pcb has 14 pins. I would assume 4069 is the correct IC being that it has 14. Also are they buffered or unbuffered (cd4069ub or cd4069B). Thanks and keep up the good work.
hendershot
Postby miwanone » 07 May 2009, 20:51
I used an unbuffered 4049.
miwanone
Have thanks: 6 times
Postby Barcode » 07 May 2009, 22:33
4069 is mentioned on the schem, so it is probably a safe bet. Good point about the pins...
Barcode
Have thanks: 35 times
Postby miwanone » 08 May 2009, 00:31
I meant 4069 ofcourse, it's getting late.. :slap:
miwanone
Postby hendershot » 08 May 2009, 02:02
Thanks guys. Etching tonight. Ill let you know results in couple days.
hendershot
Postby chriscustom » 24 May 2009, 19:52
Valoosj wrote:I finished making my own smaller layout. It should fit in a Zvex style enclosure. Will post the files here when it's verified.
There are results? :hmmm:
chriscustom
Have thanks: 3 times
Postby Valoosj » 28 May 2009, 13:41
Finished it and it sounds good.
I'll upload the layout when I get a chance.
Bazinga!
Valoosj
Postby distortion_gfx1 » 29 May 2009, 14:14
any updates on the smaller layout? :D
distortion_gfx1
Has thanked: 33 times
Postby neilnil » 29 May 2009, 17:34
I have one, though it has some space issues. I tried to make it too small and 3 electrolytes don't have enough room to stay tidy. If you can handle or just live with this, go ahead! This layout is verified to work as it's supposed to, but not tested against an original one.
Jun
neilnil
Have thanks: 9 times
Postby Valoosj » 29 May 2009, 19:59
Hehe, mine is the same size, but has an odd shape.
Bazinga!
Valoosj
Postby chriscustom » 30 May 2009, 15:31
neilnil wrote:I have one, though it has some space issues. I tried to make it too small and 3 electrolytes don't have enough room to stay tidy.
Jun
Download Layout
http://chriscustom.com/photo/e/rfratz_sm.rar
chriscustom
Postby screamingdemon » 07 Jun 2009, 15:40
Could this one running at 18 volts?
screamingdemon
Postby SPeter » 07 Jun 2009, 16:00
SPeter
Have thanks: 76 times
Postby kantul » 08 Jun 2009, 05:35
I built reztfrazitz few months ago, I found out it had such a good sound dynamics, yet I could not get the best tone. a bit too much bright, maybe brit character?
Mine is noisy when set in maximum gain, so I always set on medium gain.
However I never tried the real effect.
kantul
Postby distortion_gfx1 » 15 Jun 2009, 14:44
Jun
Download Layout
nice tnx guys.. :applause:
distortion_gfx1
Postby hobbes234 » 24 Jul 2009, 09:12
Hi Guys,
I am newbie and i am trying to build my own Reeza. :D
I am not sure if i am posting in the right sub-forum. :scratch:
I have a few questions regarding the parts used in this project and i hope to get some advice from you guys.
I would be shopping for the parts at my local Hardware store this weekend and i would like to know the following.
Would there be a difference if i were to use a 0.5W resistor compared to a 0.25W resistor?
Which type of resistor should i get? does the breakdown voltage affects the quality of the tone?
Please bear with me if my questions sound silly... :oops:
hobbes234
Postby Greg » 24 Jul 2009, 11:39
0.5W resistor is fine.. except it will generally be larger.
It won't affect the tone.
Greg
Has thanked: 77 times
Have thanks: 195 times
Postby hobbes234 » 24 Jul 2009, 20:13
Greg_G wrote:0.5W resistor is fine.. except it will generally be larger.
Thanks for the info Greg,
Types of resistors won't affect the tone too right? Does Carbon or metal films resistors make a difference?
hobbes234
Postby Greg » 25 Jul 2009, 01:19
Some say there's a difference, but it'll be minor if there is.
Check out the "mojo vs mojo" thread here... or here's a link with some info:
http://acapella.harmony-central.com/archive/index.php/t-1804459.html
Greg
Postby hobbes234 » 25 Jul 2009, 04:12
Thanks Greg! :applause:
That was really enlightening!
hobbes234
Users browsing this forum: andy-h-h, johncatoline13, mk6786, okamo00 and 12 guests
