BJFE - Emerald Green Distortion Machine  [traced]
Re: BJFE - Emerald Green Distortion Machine
Postby roseblood11 » 24 Jun 2015, 21:00
Could be anything rated for 2 ampere, 1200 volt, maybe STTH212
I think the schematic was posted somewhere, but I can't find the link anymore...
Has anybody tried this pedal with a Proco Rat in front of it? A real Vox set to light crunch sounds great if its boosted with a rat. Could be interesting to put both circuits in one enclosure.
roseblood11
Has thanked: 352 times
Have thanks: 317 times
Postby roseblood11 » 24 Jun 2015, 21:08
@ the3secondrule: Could you measure the hfe of all transistors and the leakage of the 2n1309? That would be helpful to understand the biasing...
roseblood11
Postby Manfred » 26 Jun 2015, 22:22
BJF wrote:Hi,
Here you go:
http://tagboardeffects.blogspot.se/sear ... l/BJF%2FMP
And no I don't mind and never did if anyone wants to build one for their own use or a friend.
Fun note perhaps is that when doing the Bearfoot version some nice 2N1309 had been scouted for another model and I could not resist to try and liked that.
Original BJF model has same circuit but all were made with silicon metal cans medium gain drivers.
have fun
BJ
BJF Electronics
I drew separately the schematic in accord with the strip board layout.
For this message the author Manfred has received thanks: 5
atreidesheir (28 Jun 2015, 05:09), HENK (27 Jun 2015, 05:11), modman (10 Jul 2015, 12:28), ppluis0 (04 Jul 2015, 01:40), roseblood11 (27 Jun 2015, 15:16)
Manfred
Has thanked: 1048 times
Have thanks: 629 times
Postby soulsonic » 26 Jun 2015, 22:43
roseblood11 wrote:@ the3secondrule: Could you measure the hfe of all transistors and the leakage of the 2n1309? That would be helpful to understand the biasing...
The 2N1309 in mine had "329" marked on the side. I assume this is the Hfe.
For this message the author soulsonic has received thanks: 3
HENK (28 Jun 2015, 05:29), Manfred (27 Jun 2015, 19:56), roseblood11 (27 Jun 2015, 15:16)
Has thanked: 56 times
Have thanks: 280 times
Postby Manfred » 27 Jun 2015, 08:09
I'm sorry but I made a mistake on the schematic, the FET types are 2N5952.
For this message the author Manfred has received thanks: 3
HENK (28 Jun 2015, 05:30), modman (10 Jul 2015, 12:29), roseblood11 (27 Jun 2015, 15:16)
Manfred
Postby Manfred » 28 Jun 2015, 18:43
I took closer look at the PLC shot,
and found a resistor value of 470kOhms on the gate of the second FET.
By the way, the FET stages are alike in the circutry of the Baby Pink Booster,
Manfred
Postby Manfred » 01 Jul 2015, 11:34
Better readable now.
For this message the author Manfred has received thanks: 4
deltafred (01 Jul 2015, 15:36), HENK (01 Jul 2015, 15:11), modman (10 Jul 2015, 12:29), soulsonic (01 Jul 2015, 20:20)
Manfred
Postby Manfred » 01 Jul 2015, 20:36
The LED circuitry is the same as with other BJFE pedals.
Manfred
Postby deep_intruder » 02 Jul 2015, 13:39
In my opinion there are two mistakes, the two caps: 1u and the 4n7 of the last fet, both must be wired to the drain and not to the source!
For this message the author deep_intruder has received thanks:
Manfred (02 Jul 2015, 19:46)
deep_intruder
Have thanks: 3 times
Postby smanq » 02 Jul 2015, 16:41
deep_intruder wrote:In my opinion there are two mistakes, the two caps: 1u and the 4n7 of the last fet, both must be wired to the drain and not to the source!
I think the 4n7 cap is right connected to the source (like on other BJF circuits), but the 1uf cap (the circuit output) must be connected to the drain.
smanq
Have thanks: 2 times
Postby deep_intruder » 02 Jul 2015, 17:38
I do not know how is the original, but the layout from tagboardeffects.blogspot.se is as I said.
deep_intruder
Postby Frank_NH » 02 Jul 2015, 19:34
I've been following this thread and deep_intruder is correct. The vero layout has the 4.7 nF cap connected to the drain. There is already a 22 uF source resistor bypass cap at the last JFET, so I don't know if connecting the 4.7 nF cap also to the JFET source would do anything. Hence, it's probably correct going to drain, but perhaps someone could confirm that.
Frank_NH
Has thanked: 20 times
Have thanks: 77 times
Re: BJFE - Emerald Green Distortion Machine  [traced]
Postby Manfred » 02 Jul 2015, 19:58
You are right, thanks for pointing out the mistake.
My bad. The stripboard layout is all right.
Here the corrected schematic:
For this message the author Manfred has received thanks: 2
Frank_NH (03 Jul 2015, 13:09), HENK (03 Jul 2015, 04:26)
Manfred
Postby smanq » 03 Jul 2015, 08:27
OK, the schematics reflect the board layout.
But if the A50K pot controls trebles, I confirm what I said before.
If we connect the 4n7 cap to source, when the wipe is full CW, both first and last stages have a boost on high frequencies (exactly a low cut on first stage); when the pot is full CCW last stage is around linear (4n7 has no effect on circuit) and first stage has a boost on low frequencies. It's same behavior we can see in other BJF circuits, like honey bee. So, in this way: CW=treble boost, CCW=bass boost.
If we connect the 4n7 cap to drain, when the pot is full CW we have a treble cut on last stage and a low frequencies cut on first stage (around a non sense); when the pot is full CCW last stage is around linear, the first stage has a boost on lows. This behavior for me is strange: CW=treble cut, CCW=bass boost.
smanq
Postby Manfred » 03 Jul 2015, 21:05
smanq wrote:OK, the schematics reflect the board layout.
Your explanation makes sense because there is already a treble control.
It is hard to find out the real circuitry on the pcb shots.
Is there an owner of this device who could check it out which the real circuit is?
Manfred
Postby IvIark » 10 Jul 2015, 14:03
Hi guys. The schematic was sent to me a while ago and I think at the time I was asked not to share it, but can't completely remember so here it is. If the author would prefer me not to then please let me know and i'll remove it from here.
It doesn't flow like many of us may be used to seeing schematics for these things and as such the scheme isn't as straight forward to follow at first. Q1 has the source at the top and drain at the bottom
For this message the author IvIark has received thanks: 5
deltafred (10 Jul 2015, 18:37), HENK (11 Jul 2015, 15:01), Manfred (10 Jul 2015, 17:50), modman (10 Jul 2015, 16:11), nickthemen (10 Jul 2015, 21:28)
IvIark
Has thanked: 668 times
Have thanks: 683 times
Postby modman » 10 Jul 2015, 16:22
Manfred top drawing conforms to this schematic made in 2014...look at the 4nF cap marked as
However, have a look at C14 in the old one: there is written "100k = 10pF", other schematic has this value as 100pF, don't know where that came from.
Maybe the solution the capacitor has 100k written on it, meaning 100,000 (pF) = 100nF?
C15 = 22nF or 22µF? - if you have the unit in front of you, how could you have to guess? Maybe it was traced from pictures, not from a unit.
Has thanked: 3283 times
Have thanks: 611 times
Postby asimplesample » 24 Oct 2016, 01:38
I just ran across this effect today, and found this thread and the 'tagboard' layout. This thread ends with some doubts...has anyone made a final confirmation? Has anyone built one all-silicon?
Larry S.
asimplesample
Have thanks: 11 times
Postby BJF » 25 Oct 2016, 15:00
Hi There,
Oh that schematic doesn't flow well at all.
Really it's a straight forward design and as I wrote several years ago that if you'd take a BJF EGDM apart you would find three transistors
Indeed BJF version is all silicon while when I was making this for Bearfoot and seeing they had 2N1308's in stock I just went for it and really liked the sound and that is precisely what happened.
At your service
BJ
For this message the author BJF has received thanks:
J0K3RX (25 Oct 2016, 18:57)
BJF
Have thanks: 56 times
Postby Seiche » 27 Apr 2018, 05:39
Manfred, the top one should be correct.
I'm working on it to verify.
For this message the author Seiche has received thanks: 2
Manfred (27 Apr 2018, 14:59), Nocentelli (27 Apr 2018, 07:21)
Seiche
Has thanked: 264 times
Have thanks: 214 times
Users browsing this forum: Chugs, jimini, tono1202, Visualdistortion and 15 guests
