Fulltone Clyde Deluxe
Did a search, couldn't find it.
Its a really nice wah, quite versatile as well.
Here's some guts:
Here's some guts:
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
One more from me
I'm sure there was a tread about Fulltone Clyde
- culturejam
Please use the upload function built in to the forum for posting photos. That way, we retain a copy here, which avoids problems when hosting accounts close, move, etc.
- sinner
Does anyone knows what caps values are used to switch between wacked/jimi/shaft mods?
- Angle Loss
Just opened mine up. The three green caps next to the rotary selector read:sinner wrote:Does anyone knows what caps values are used to switch between wacked/jimi/shaft mods?
502
103
203
- sinner
Angle Loss wrote:Just opened mine up. The three green caps next to the rotary selector read:sinner wrote:Does anyone knows what caps values are used to switch between wacked/jimi/shaft mods?
502
103
203
That makes;
5nF
10nF (stock Clyde value)
20nF
Thanks Sir!
- beedotman
Does anybody got some gut shots or schematic for fulltone buffer in new clydes?
- sinner
Knowing Fulltone it's just a FoxRox wah retrofit (or variation) with external level control... what else it can be bro?
- beedotman
I'm wondering if this is jfet or opamp based. According to Fuller himself "All the ones I've tried added harsh treble so I developed one that doesn't. " this is something else
- sinner
beedotman wrote:I'm wondering if this is jfet or opamp based. According to Fuller himself "All the ones I've tried added harsh treble so I developed one that doesn't. " this is something else
I must be deaf then it's engaged only when wah is on, and it sounds linear to me... well at least much nicer than without in front of FF
- beedotman
Hello everyone, I ended up redesigning an inverted scheme that I found online because I found it confusing.
The deluxe does not seem to have the buffer as standard. Only an internal 2k trimpot, an input level. And the 3 types of voice.
I hope to help someone who is looking.
If someone finds some error I can fix it.
I think the one you based your redraw on messed up the pot connections. As drawn, you will ground your output at one end of the rotation. This is pretty much a Vox v847 so have a look at it's schematic and you'll see what I mean.
Sure Yellowboy. I'll fix that. thanks for seen that.
