in short, can i replace the LM324 and your 2 x TL072 with a TL074??riesling wrote:1. I have at least 20 TL072Dr. Nöres wrote:Why did you replace the LM324 by two TL072?
2. I don't like Quad OP-Amps (just a personal thing)
But feel free to change the layout to your needs
Mad Professor - Snow White Auto Wah [traced]
- jmwreck
- roseblood11
Is it possible to add a switch that reverses the filter sweep?
That´s an interesting mod for the MXR Envelope Filter (see tonepad.com), but I think it would sound much better with the SWAW, because the overall sound is better.
- jmwreck
hello to everyone, i have redrawn the schematics based on the one posted here, and i have matched it with dimebug's layout. i have found out that the LM324 pinouts in the schematics was arranged in a different way with regards to the layout. I have been thankful for both the scheme and layout. Im just concern of the pins of LM324 specifically the COMMON pins.
correct me if im wrong with this
- my favorite amplifier: U-Sound
- Completed builds: U-Sound Pedals:
more then 20 pedals made and more then 100 mods... - Location: Russian Federation
- Contact:
The thread may already outdated, but I want to ask colleagues to do this pedal - attached diagram is correct, if not, please indicate my mistakes.
Thanks in advance.
Thanks in advance.
- snowwhite.pdf
- (21.19 KiB) Downloaded 1085 times
- Ice-9
- Degoop Doctor
vorokha wrote:The thread may already outdated, but I want to ask colleagues to do this pedal - attached diagram is correct, if not, please indicate my mistakes.
Thanks in advance.
A quick look over and everything looks fine.
- devastator
about the lm13700, are they fragile ?
I soldered some wire (for the pots) and the enveloppe doesn't work any more (but the sound still there)
- mictester
You need the "Eagle" software. It's free from Cadsoft.uncleboko wrote:Vista will not open .sch files, what is the workaround please?
- Contact:
Maybe you're not power off when soldering?devastator wrote:about the lm13700, are they fragile ?
I did a lot of their Phasers on these chips, their scheme in 4 pieces, I was not the case that they were burned.
- devastator
yes, no power going into. But the chip stay in place when I put the wire.
I can hear the decay and sensitivity control act on sound, but any sweep or "quack" is presents. The signal goes into the filter whitout being changed (like a fixed wah ) .
- ckyvick
Are you sure its not how you have it set? because it does a fixed wah too. if not it sounds like your wiringdevastator wrote:The signal goes into the filter whitout being changed (like a fixed wah ) .
- devastator
i'm from japan and sorry for my poor English
I made one using NJM13600 because LM13700 or NJM13700 is hard to get in japan (or it's so expensive)
and the results were discouraging. So I ordered LM13700 from overseas with expensive shipping charge,
So I'll report soon.
Anyway , thanks for great project !
- Ice-9
- Degoop Doctor
To be Honest the NJM13600 should just drop in place of the 13700. You should get very similar results if not the exact. What exactly is the problem you have with the effect ?waaap wrote:Hi,
