Moolon - switching system
- DWBH
http://www.moollon.com/product/product_cshop01_e.asp
I saw this the other day and the thing that struck me most was the switching system.
I really liked it.
How can you do that, diy-speaking?
I went to GEO, but found nothing.
I really liked it.
- nelson
It isn't that simple. The way the blurb is worded the master switch also selects one or the other pedal. I suspect the blurb is deceivingly worded and it is as you described. Either that or when one of the pedals is on it controls a switching relay. Should be fairly simple to work out. You could switch the relay with the LED power of the effects and have the relay also controlled by the master switch. When both pedals are on the master switch just functions as a bypass via the relay.
- The Rotagilla
There's an article on GEO that shows how to do multiple effects in one box. I would assume it could apply to this situation.
- dave_b
I suppose the switches could be momentary. If the Dist and O/D switches each pulsed a flip flop, you could then have the master switch pulse both flip flops, reversing their state.
- nelson
dave_b wrote:I suppose the switches could be momentary. If the Dist and O/D switches each pulsed a flip flop, you could then have the master switch pulse both flip flops, reversing their state.
And that would be a simpler elegant solution compared to mine.
Triggered RS monostables. Forest Mimms showed how to do this with a few bjt's and diodes. Not clever at all really.
