I may be wrong and please correct me if I am...after looking at the data sheets for both IC's quickly, the HK723 looks like a pin for pin drop in for the PT2399. The basic echo app notes look very similar.pz wrote:HK723, a viariation of pt2399, according to datasheet offers delay time up to 700ms.
Mad Professor - Deep Blue Delay [traced]
- The Rotagilla
- soggybag
- Completed builds: Fuzz Face, Tone Bender, Big Muff, ICBM, Ugly Face, Green Ringer, Super Fuzz, Multiplex Echo, Multiplex Jr, Rebote, Echo Base, SHO, Fuzz Factory, Titan Boost/Octave, Easy Face, Tone Bender MkII, Trem Shifter, Zero Point Mini...
- Has thanked: 28 times
- Been thanked: 27 times
- Contact:
That HK723 chip sounds like a pin for pin replacement for the PT2399. Where can you get some to experiment with?
- The Rotagilla
Looking right now.soggybag wrote:That HK723 chip sounds like a pin for pin replacement for the PT2399. Where can you get some to experiment with?
- The Rotagilla
Checked the usual suspects, no dice. I emailed the manufacturer.
- BJF
Actually PT2399 has a low noise up until about 400mS after that there's a limit reached but depending on how you set the controls noise can anyway be accaptable and less than some of the tape echoes I have.
The circuitboard in DBD is three sided and the schematic as posted has a few flaws but it is impressive just the same that somebody took the time to trace thus far
Have fun
BJ
BJF Electronics
Sweden
Have fun
BJ
BJF Electronics
Sweden
Hey guys, sorry for coming back late.
I built one from the schematic I posted and there was no problem.
I tried to find out my flaws but I couldn't so far and don't want to bother any more.
And nice to see you, BJ! I really enjoy your pedals.
Jun
Jun
- lohstah
did you use the tonepad layout and change components and a few traces or did you make a layout yourself ?
in either case, could you post the changed layout or the one you used ?
cheers,
lohstah
cheers,
lohstah
I used my modified tonepad layout which you can find on page 3.
With that layout, you'll have some off-board components and a few jumpers.
I'd like to update it to dbd spec but diy layout creator gets too slow to handle this so I'm afraid I can't do this soon.
Jun
Jun
- The Rotagilla
That must have been the longest walk ever!bajaman wrote:I have built rebote delays and modded them extensively - a NE570 or NE571 makes quite a difference in my humble opinion - more later on - got to feed the dogs and go for my daily walk now
I'm curious to read your findings on PT2399 based delays. Do tell!
- bajaman
- Has thanked: 595 times
- Been thanked: 2058 times
Yep - just got home five minutes ago - sorry, I will dig up my notesThat must have been the longest walk ever!
- BJF
Ah well, engaging an NE570 would roughly cut noise from delay by 20dB, feedbacknetwork needs to be nested into the companding Hm, well background noise is quite low as is but side effects from oscillator triggering can be somewhat lowered.
If powersupply falls below limits there will be just first whining then just white noise..........just an interesting note and that can be good to know for anyone experimenting with this chip
Sound is restored with correct voltage
Have fun
BJ
Have fun
BJ
- The Rotagilla
Well after several emails, attempts to conquer the language barrier and some money I finally received my HK723 samples. Despite the claims of 700ms of delay time, I'm pretty certain the HK723 is a rebranded PT2399. Extending delay times beyond 400ms yielded digital hash and just about the same loss of sound quality as the PT2399. I may continue to play with the components around the IC but in the immortal words of the NYPD..pz wrote:HK723, a viariation of pt2399, according to datasheet offers delay time up to 700ms.
"Nothing to see here. Let's go, move along."
- audioguy
I dont suppose you could type up a little guide to do the conversion? I'm interested in hearing a $350 rebote!neilnil wrote:I used my modified tonepad layout which you can find on page 3.
Jun
- estragon
Hi Rotagilla,The Rotagilla wrote:Well after several emails, attempts to conquer the language barrier and some money I finally received my HK723 samples. Despite the claims of 700ms of delay time, I'm pretty certain the HK723 is a rebranded PT2399. Extending delay times beyond 400ms yielded digital hash and just about the same loss of sound quality as the PT2399. I may continue to play with the components around the IC...
I checked both datasheets and it seems quite plausible that they are indeed the same device.
Something that has intrigued me are the two 100nF capacitors on pins 7 and 8 to ground. Since this is a delta modulation A/D and D/A, I guess that slow clocks (intended for longer delay times) would need some adjustment to avoid saturation in the integrating capacitors. One thing to try this is to increase said capacitors to 220nF (or maybe just 150nF) and see if it helps somehow.
In a similar line of thought, the two 82nF or 100nF capacitors across pins 9-10 and 11-12 (if memory serves me well) could be increased also.
Hope it helps.
- The Rotagilla
As soon as time allows I'll give that a shot. Thanks for the input.estragon wrote:Hi Rotagilla,The Rotagilla wrote:Well after several emails, attempts to conquer the language barrier and some money I finally received my HK723 samples. Despite the claims of 700ms of delay time, I'm pretty certain the HK723 is a rebranded PT2399. Extending delay times beyond 400ms yielded digital hash and just about the same loss of sound quality as the PT2399. I may continue to play with the components around the IC...
Hope it helps.
Is there a modified Rebote layout out jet for the DBD?
I tried it myself...but i'm not really sure if I replaced/added the correct parts
- modman
- a d m i n
- Has thanked: 4394 times
- Been thanked: 2131 times
Man, you really dug up the oldie of the month. I had completely missed this one. Didn't know this one was traced. There are layouts at GGG et al. check the thread from the beginning. There are a number of links there.Camphausen wrote:Is there a modified Rebote layout out jet for the DBD?
- moltenmetalburn
has anyone verified the filtering of this one?
it really is wonderful sounding but there is no way im paying #350 for a rebote, id like to modify mine.
