Frantone - Peach Fuzz  [traced]
Postby RnFR » 05 Jul 2008, 23:29
bajaman wrote:i built my Peach fuzz without the relay - I have lots of those 3PDT blue footswitches - no clicks or pops either and still true bypass :wink:
can you explain how you did this? i have all the parts on hand except the relay, and i'd like get this built. thanks!
Has thanked: 150 times
Have thanks: 174 times
Re: Frantone - Peach Fuzz
Postby bajaman » 05 Jul 2008, 23:46
simple :wink: - just wire the switch contacts to the relay pads and ignore the relay coil connection pads
Has thanked: 457 times
Have thanks: 1579 times
Postby RnFR » 06 Jul 2008, 03:04
great. thanks alot man!
why source out a single pole and a relay when you can do it this way right?
Postby culturejam » 17 Nov 2008, 15:40
It seems that the last, most recent schematic for the Peach Fuzz has gone missing (the link is no good anymore).
Does anyone have a final schematic for posting? Or can someone email it to me so I can post it?
culturejam
Has thanked: 466 times
Have thanks: 584 times
Postby Cow4prez » 17 Nov 2008, 17:48
Cow4prez
Have thanks: 5 times
Postby culturejam » 17 Nov 2008, 20:59
Thanks, Cow!
You're my hero!! :applause:
culturejam
Postby squrl » 08 May 2009, 04:06
hmmm does anyone who has this schematic post it up or simply send it to me in a pm? not sure why the images are gone...
squrl
Postby bajaman » 08 May 2009, 04:36
http://freestompboxes.org/members/bajam ... uzz/PF.png
please read the complete thread for more advanced info :wink:
Postby squrl » 08 May 2009, 16:51
thank you baja... :block:
squrl
Postby picassochild » 21 May 2009, 18:39
Guys, what do you think about idea to replace original tone control and build Peach Fuzz with Timmy Bass/Treble control? I had Peach Fuzz and liked it, but sometimes low end was too big and woofy.
picassochild
Have thanks: 7 times
Postby KindaFuzzy » 22 May 2009, 01:19
I used Snail's layout and I'm getting a little bit of motorboating with mine. It is in the same case as a SHO, and only happens intermittently when both effects are engaged. I tried moving all the wires and boards around but nothing gets rid of it. I put a 220uf across the power supply, as well as a 47ohm resistor in series with the 9v to each effect and it tamed it down, but didn't kill it.
Anyone else have this problem and figure out how to fix it?
KindaFuzzy
Has thanked: 106 times
Have thanks: 296 times
Postby monkeyxx » 24 Nov 2011, 09:47
I just verified a stripboard layout over at this other thread on fsb about the peach fuzz, bajaman's mini peach fuzz thread:
http://www.freestompboxes.org/viewtopic.php?f=13&t=1273&p=170826&hilit=peach+fuzz#p170826
it took me ages to stumble across that thread so I thought i would post a link here, too, as well.
interesting fuzzstortion... kind of sounds like a metal zone or metal muff or something... real crisp and dry sounding, not all phat and juicy and whatnot. Someone made a T Rex (The Slider) comparison and I think that's a good one. I like the "voice" of this circuit, it's got a muffy low end and a certain vocal quality that I always search for and am happy to find in a fuzz distortion or overdrive...it's unique. Don't know if this will be a go-to for me but I'm glad I built it. The Sonic Titan is another really great LM386 distortion device. I also really like the Penny Pedals Fingerprint a whole lot another based on a similar chip.
monkeyxx
Has thanked: 48 times
Have thanks: 48 times
Re: Frantone - Peach Fuzz  [traced]
Postby modman » 12 May 2012, 07:08
See BAJA PEACH FUZZ project
Has thanked: 3241 times
Have thanks: 607 times
Postby grrrunge » 15 Feb 2016, 07:14
I recently built this one for a friend. Sounds pretty good.
Including the HF-stabilizing components from the data sheet resulted in considerably less hiss while I had the circuit on my breadboard, so I included them in the schematic as well :) Have fun...
For this message the author grrrunge has received thanks: 6
287m (15 Feb 2016, 18:53), Blitz Krieg (15 Feb 2016, 07:41), IvIark (18 Feb 2016, 18:15), lars-musik (13 Apr 2016, 11:03), Manfred (15 Feb 2016, 12:11), mirosol (22 Feb 2016, 08:20)
grrrunge
Has thanked: 59 times
Have thanks: 207 times
Postby mirosol » 22 Feb 2016, 08:26
Hmm. The unused opamp channel could be used as inverting recovery after the tone stack. It would not need much gain, if any.
mirosol
Has thanked: 160 times
Have thanks: 369 times
Postby grrrunge » 22 Feb 2016, 13:25
mirosol wrote:Hmm. The unused opamp channel could be used as inverting recovery after the tone stack. It would not need much gain, if any.
The output signal is being clipped by the LM386 and is rather close to the supply rails.
If the spare op-amp should be used as an output amp without adding more distortion, it should sit after the volume control. Recovery gain shouldn't be necessary here ;)
grrrunge
Postby grrrunge » 28 Mar 2016, 16:23
I have a stack of spare boards left after building the two i needed.
If anyone's interested, I'll sell them for $4 per board plus postage. PM me for details :thumbsup
grrrunge
Postby marshmellow » 06 Apr 2017, 22:19
Concerning the noise, build the first stage as a non-inverting amplifier. The way it's in the original is rather subpar. Make Rf 15kΩ, Rg 910Ω, should give an improvement of over 20dB while keeping the gain the same. The TL022 isn't a particularly great choice either, but maybe it's part of the sound...
marshmellow
Have thanks: 123 times
Re:
Postby V1nce69 » 13 Jan 2019, 20:48
bajaman wrote:IMPORTANT UPDATE
The first dual opamp is NOT a TL022, it is definately a TLC (rail to rail opamp) NOT TLO, from the photos posted earlier in this thread. My guess is it is a TLC2262 device.
ALSO
There are 3 different types of LM386N power opamps: The LM386N-1, which is the one used in the Peach fuzz is a 6 volt device. The others are LM386N-3 whch is a 9 volt device and the LM386N-4 which is a 16 volt device.
Sorry to resurrect an old thread, but I just wanted to comment that your guess is correct !!
I bought a Peach Fuzz reissue, took a few pictures and traced the board completely.
For this message the author V1nce69 has received thanks: 2
bumblebee (26 Jan 2019, 08:20), dv8r601 (19 Jan 2019, 01:29)
V1nce69
Has thanked: 34 times
Have thanks: 67 times
Previous
Users browsing this forum: No registered users and 12 guests
