Xotic EP-Booster  [traced]
Re: Xotic EP-Booster
Postby wcraffonara » 10 Mar 2014, 13:52
Hi community,
I've successfully build my own PCB of the Xotic EP Booster Clone. Here is the build instruction manual if you are interested in:
https://www.dropbox.com/s/y1ds7zoig42as ... ooster.pdf
You can order this PCB by sending me a pm.
Regards & keep on rockin'!
For this message the author wcraffonara has received thanks:
Manfred (12 Mar 2014, 11:17)
wcraffonara
Have thanks: 2 times
Postby Nacho5 » 24 Oct 2014, 19:24
wcraffonara wrote:Hi community,
link broken! :x
Nacho5
Have thanks: 4 times
Postby mecmast » 20 Feb 2015, 21:42
Today i've tried this layout, but could not succeed.
I've used:
- 100uf 25v caps
- 10uf 50v caps
- Q2: Couldnt find 2n5088 and tried "BC239" and "2SC1815" but didn't work.
Has anyone tried this layout? Is it really "verified"?
mecmast
Postby tabbycat » 20 Feb 2015, 22:11
mecmast wrote:Hi,
[ Image ]
I've used:
- 100uf 25v caps
- 10uf 50v caps
harald has a very good reputation re his layouts. i would initially assume he wouldn't label it verified unless it was. had a quick look at the original page and notice freppo (who posts here) also built it with success, and he also knows his stuff. worth checking the original post for any updates or mods to the schematic just in case it has any idiosyncrasies.
http://www.sabrotone.com/?p=3186
http://www.sabrotone.com/?attachment_id=3185
and back through this thread in case subs for 2n5088 are suggested for this layout.
but i would say get some 2n5088 transistors (as specified by the layout's designer) before suspecting the layout might be out. i know it's a drag when you want to build and not wait for bits to arrive, but if it was specified as 2n5088 i would give that a go first.
i think all your caps should be 16v+ (as specified) if you intend to run it up to 18v. i haven't built this but have i built the ep3 18v pre at guitar fx layouts, but they are two kinds of the same thing (echioplex 3 pre).
good luck with it. they are nice things.
"be a good animal, true to your instincts" (d.h. lawrence).
"there is no excellent beauty that hath not some strangeness in the proportion" (francis bacon).
"ni dieu ni maître" (anarchist slogan).
For this message the author tabbycat has received thanks:
mecmast (21 Feb 2015, 14:09)
tabbycat
Has thanked: 227 times
Have thanks: 64 times
Postby Nocentelli » 20 Feb 2015, 23:31
mecmast wrote:- Q2: Couldnt find 2n5088 and tried "BC239" and "2SC1815" but didn't work.
You know both of those replacements have different pinouts to the 5088 shown on the layout?
mecmast (21 Feb 2015, 14:10)
Nocentelli
Has thanked: 862 times
Have thanks: 837 times
Postby mecmast » 21 Feb 2015, 14:15
@tabbycat
First of all thanks for the reply.
I've re-checked the layout but everything seems ok.
I guess i'll try another schem/layout. It's really disturbing to try to find the problem with this. Building a new one seem easier :)
@Nocentelli
Thanks for the reply.
I've tried all the combinations, but no success :(
mecmast
Postby tabbycat » 21 Feb 2015, 18:25
@ mecast
this is the ep3 pre i built. there are various version here from basic to basic plus. xotic is just a twist on this.
http://tagboardeffects.blogspot.co.uk/2 ... llman.html
sometimes sticking with something and thrashing it out is worth it for the learning you get out of it. what you learn from that battle applies elsewhere henceforth, so good value.
but i've also had ones where the battle took more out of me than it was probably worth and i may have been wiser to walk away and start again.
it's your call. you know how much frustration you can put up with in return for what you may gain.
best of luck.
tabbycat.
tabbycat
Postby mecmast » 21 Feb 2015, 19:56
@tabbycat
Thank you for all your best wishes:)
I'll try these layout asap.
mecmast
Postby mecmast » 10 Oct 2015, 15:26
Case solved.
I had forgotten to connect the grounds all together last time.
Yesterday i had built it.
Thank you all :)
mecmast
Postby Danila-Master » 11 Jan 2016, 22:13
Hello All.
I'm reading this thread third time and still can't understand.
The is 2n5457 - is this a confirmed original value? or it is deducted based on parameters and voltages?
Danila-Master
Postby fernsak » 21 Dec 2017, 22:05
Does anybody know how the +3db/unity gain switch is implemented in the v2? I guess adding a resistor in series with the pot instead of the 100uF in parallel with the 10uF cap would do the trick, but don't know for sure and would need the value of the resistor.
fernsak
Users browsing this forum: blackboarcult, FiveseveN, FlyingWild, steelplayer and 12 guests
