Xotic EP-Booster  [traced]
Re: Xotic EP-Booster
Postby Psychotronic » 10 Dec 2011, 22:11
First time posting, I really like this place and plan on trying several builds....if I can get this one working, that is!
I tried to build the above vero layout (my first time using vero), but I'm not getting any signal once the effect is engaged. I do get a clean signal thru it when disengaged, so I believe I have the switch wired correctly. However, once engaged, the LED lights up but there is no sound. I checked the board closely to make sure there is no solder jumping over to the previous/next line. Also, instead of the internal dip switch, I used 2 SPDT switches off board.
Any ideas?
My apologies for the messy wiring, it was only supposed to be temporary until I got it working! Hopefully, these will help...
http://i414.photobucket.com/albums/pp22 ... 011420.jpg
http://i414.photobucket.com/albums/pp22 ... 011422.jpg
http://i414.photobucket.com/albums/pp22 ... 11422b.jpg
http://i414.photobucket.com/albums/pp22 ... 011423.jpg
Psychotronic
Postby okgb » 11 Dec 2011, 00:15
Sounds like something shorting to ground or the connection being broken ,
triple check , follow signal flow with the schematic , good luck
okgb
Has thanked: 196 times
Have thanks: 41 times
Postby TubeOrgasmer » 12 Dec 2011, 00:36
Try running a blade like an xacto knife in between the copper lines and see if the solder pads are touching inbetween the rows, that might cause something to short out, and it's usually the first thing I check and most of the time it's the case.
TubeOrgasmer
Have thanks: 2 times
Postby Psychotronic » 12 Dec 2011, 15:16
Yeah, that was the first thing I tried. I'm questioning whether I have the jacks wired correctly, specifically the input jack.
Psychotronic
Postby miamimart » 13 Jan 2012, 05:36
Has anybody traced the EP Booster version 2....the one with the unity gain feature? Thinking about doing a build, but wouldn't mind that feature. Thanks.
miamimart
Postby bigorangefan79 » 13 Jan 2012, 06:06
miamimart wrote:Has anybody traced the EP Booster version 2....the one with the unity gain feature? Thinking about doing a build, but wouldn't mind that feature. Thanks.
Just put a trim pot between the grounded lug of the volume pot and ground.
bigorangefan79
Have thanks: 28 times
Postby Brainbender » 03 Apr 2012, 09:46
Psychotronic wrote:First time posting, I really like this place and plan on trying several builds....if I can get this one working, that is!
Any ideas?
I have (almost) the same problem with Moska's layout. The only difference is that I do hear some boost, but only when I crank the amp. :blackeye
I'm using Meadbean's wiring metod.
Btw.; is it normal that LED onboard glow all the time, even when the pedal is off/bypassed?
Thanx.
Brainbender
Has thanked: 19 times
Have thanks: 6 times
Postby alexradium » 03 Apr 2012, 12:08
I built one with that MOska layout,very low volume engaged,don't know why,it looks correct as a layout,the led is wired always on,you have to break the coonection with the main switch.
i did the epa booster layout and that is perfect.
alexradium
Has thanked: 53 times
Have thanks: 57 times
Postby Brainbender » 03 Apr 2012, 18:37
Ok, after spending half day resolving what's wrong with Moska layout, I found the solution. [smilie=vibes.gif]
the Q2 (2n5088) should be reversed and collector and base legs twisted. or simply get a 2sc1815 transistor as in original EP. just reverse it as 2n5088. :wink:
Brainbender
Postby Trash Heap » 04 May 2012, 22:51
Hello All. I'm just getting started with building pedals, messing with circuits, etc. But I was wondering. Does anyone know of a Voltage doubling type circuit that can be added to this so that you can get at least around the 18V that is said to make it work/sound better?
Trash Heap
Postby ThoWmas31 » 01 Jun 2012, 19:52
i follow this post, they have some layout but wich is the best ? all work ?
This work ?
and a little question (yeah 'im a noob lol)
in this picture what is the Red square? what does the red square ???
ThoWmas31
Postby IvIark » 01 Jun 2012, 19:55
This one is verified:
For this message the author IvIark has received thanks:
sinner (03 Jun 2012, 14:01)
IvIark
Has thanked: 668 times
Have thanks: 678 times
Postby ThoWmas31 » 01 Jun 2012, 20:09
i don't understand, what is this red square with a circle ?
and thanks for the verified shematics
ThoWmas31
Postby IvIark » 01 Jun 2012, 20:14
It's a cut in the track. Use an oversized drill bit to make the cut or a tool like this:
http://www.ebay.co.uk/itm/130646169681
The layout as you see it is component side, so to see how the cuts will look track side you'd need to mirror the image
IvIark
Postby ThoWmas31 » 01 Jun 2012, 20:20
i see, it's a vertical track, like a protoboard (i can remember it's named portoboard or plugboard in english)
ThoWmas31
Postby IvIark » 01 Jun 2012, 20:25
Yes, like this:
IvIark
Postby ThoWmas31 » 03 Jun 2012, 12:22
Are your sure for 10kb potentiometer ???
ThoWmas31
Postby IvIark » 03 Jun 2012, 12:26
C10K, it's reverse log in the schematic I did this from. Linear would work as well but the increase in boost probably won't be as uniform.
IvIark
Postby ThoWmas31 » 05 Jun 2012, 17:31
my proto doesn't work :'( , i use a BC 549 because i haven't 2sc1815 ... pin for 2SC1815 -> ECB and for the BC549 CBE , EBC reverse
i twisted the B and C ... but didn't work :(
ThoWmas31
Postby ThoWmas31 » 08 Jun 2012, 16:42
Yeah , it's work haha :D
but my booster are a lower or attenuator lol, i use a BC549 and not a 2SC1815 that is the problem ?
or maybe change my capa ( i use for exemple 10µ63V it's better if i use a 10µ20V?)
ThoWmas31
Users browsing this forum: Art, deemackv6, matching_mole, vot and 10 guests
