Zvex - Distortron  [traced]
Re: Zvex Distortron
Postby Mich P » 22 Jul 2010, 13:21
Any update on this one ?
Thanks !
Mich P.
Mich P
Has thanked: 60 times
Have thanks: 16 times
Re: Zvex Distortron
Postby BrownMagic » 23 Jul 2010, 07:59
Since this forum has taught me so much, and given me so many awesome effects, I just went out and bought a Distortron and cracked it open so that I could investigate the implementation of the Hi/Lo and Subs switches for you guys.
If you look at the AWESOME schematic of the box of rock in the other thread for reference...
-The High/Low switch shorts out the 330ohm resistor connected to the 3rd mosfet. I dunno if I can say this is verified, but I traced it to be this, and I run my continuity checker on the 330ohm resistor with the switch in both positions. When the switch was set to Hi, my meter told me that the 330ohm resistor was shorter. Good enough for me!
-The Subs switch is a spdt on-off-on switch.
The switch is connected to what WOULD be the 1uf coupling cap that connects gain stage 2 to gain stage 3, but this cap is cannot be 1uf any longer. I don't know the exact value. But in the center position (subs 1), it is just 1 coupling cap. Positions 2 and 3 each add in a different value capacitor in parallel to the coupling cap. Zvex says that position 3 is the stock BoR setting.
Using everything that we know, I'm going to assume that the coupling cap between stage 2 and 3 on the distortron is .47uf, and Subs 2 adds in a .22uF cap, and Subs 3 adds in a .47uf cap. I
I'm assuming this because .47uf in parallel with .47uf is close to 1uf, which is the stock box of rock coupling cap between gain stages 2 and 3. And adding in .22uf seems like a pretty decent halfway point.
I hope this clears up some of the confusion for you guys! Thanks again for everything!! :D
BrownMagic
Re: Zvex Distortron
Postby Mich P » 23 Jul 2010, 08:28
Many thanks BrownMagic .
Mich P.
Mich P
Re: Zvex Distortron
Postby Mich P » 23 Jul 2010, 17:57
Hi brownMagic
Pictures maybe ?
Mich P.
Mich P
Re: Zvex Distortron
Postby BrownMagic » 23 Jul 2010, 18:36
It really wouldn't be worth it. It's SMT, and I could barely see the traces myself. I'm positive my camera would fail at even picking up the resistor codes. But if you really want it just to see the build quality, I'll try.
BrownMagic
Re: Zvex Distortron
Postby Mich P » 23 Jul 2010, 19:32
Yes please, it just curiosity !!
Mich P.
Mich P
Re: Zvex Distortron
Postby caspercody » 23 Jul 2010, 22:49
Are you saying that the cap between stage 2, and 3 is 470n instead of the BOR value of 22n (looking at the BOR schematic)? Than the switch would in the first position be straight thru, second position add in parallel a 220n, and than in the third position add in parallel a 470n capacitor?
caspercody
Has thanked: 30 times
Have thanks: 43 times
Re: Zvex Distortron
Postby BrownMagic » 23 Jul 2010, 22:57
OMG! I messed up! Good call!
I meant between stage 3 and the Tonestack!!!! I will edit the post ASAP! Thanks caspercody!
BrownMagic
Re: Zvex Distortron
Postby BrownMagic » 24 Jul 2010, 00:00
BrownMagic wrote:Since this forum has taught me so much, and given me so many awesome effects, I just went out and bought a Distortron and cracked it open so that I could investigate the implementation of the Hi/Lo and Subs switches for you guys.
The switch is connected to what WOULD be the 1uf coupling cap that connects gain stage 3 to the tonestack, but this cap is cannot be 1uf any longer. I don't know the exact value. But in the center position (subs 1), it is just 1 coupling cap. Positions 2 and 3 each add in a different value capacitor in parallel to the coupling cap. Zvex says that position 3 is the stock BoR setting.
Using everything that we know, I'm going to assume that the coupling cap between stage 3 and the tonestack on the distortron is .47uf, and Subs 2 adds in a .22uF cap, and Subs 3 adds in a .47uf cap. I
NOTE: This is the edited and correct version of my initial post. Disregard that one.
Can anyone tell me how to edit posts? Heh...
BrownMagic
Re: Zvex Distortron
Postby jfk1063 » 25 Jul 2010, 13:26
Does this cap between gainstage 3 and the tonestack have to be a polarized cap (elco) or is MKT-cap ok?
jfk1063
Re: Zvex Distortron
Postby dune2k » 25 Jul 2010, 14:41
both are fine.
dune2k
JOHNO wrote:P.S Great pedal for playing 70's porn music.
dune2k
Re: Zvex Distortron
Postby chris_d » 25 Jul 2010, 17:44
Thanks for this BrownMagic!
I will have to open up my BOR build at some point and experiment with these. :thumbsup
chris_d
Have thanks: 3 times
Re: Zvex Distortron
Postby jfk1063 » 25 Jul 2010, 21:31
dune2k wrote:Hi,
both are fine.
dune2k
Yeah thanks!
I allready tried it with the first filter cap, but then there is very little difference.
jfk1063
Re: Zvex Distortron
Postby BrownMagic » 25 Jul 2010, 21:35
Anytime Chris!
And Mich, I can't get pics, sorry! Camera's being stupid. But yeah. Here's a link to the vexter box of rock http://www.beavisaudio.com/gg/images/zv ... vexter.jpg . It's similar to that, but SMT. The jacks are OK quality, not something I'd use in my own builds. The switch is cheaper too. But a decently solid pedal, and great sound for the money.
BrownMagic
Re: Zvex Distortron
Postby steveb » 26 Jul 2010, 19:05
jfk1063 wrote:
dune2k wrote:Hi,
both are fine.
dune2k
Yeah thanks!
Please let us know the results. I'm curious to know if changing the 1uf cap to .47uf will decrease the low end. I just bought one, & would like to decrease the lows a bit.
Thanks,
Steve
steveb
Re: Zvex Distortron
Postby jfk1063 » 09 Aug 2010, 19:31
Just finished building a BOR/Distortron. Pics will follow.
It sounds great, but I don't hear any difference when using the sub-switch (between gainstage 3 and tonestack). I used a 0.47uf and then in parallel another 0.47 or a 0.22. Should the values be lower or is it something else?
For this message the author jfk1063 has received thanks:
modman (09 May 2015, 02:08)
jfk1063
Re: Zvex Distortron
Postby Mich P » 09 Aug 2010, 22:57
Hi, same problem here with this values
So i change for :
0.056uF parallel with 0,82uF = position 3 (BOR stock)
0.056uF parallel with 0,047uF = position 2
0,056uF alone = position 1.
It works better for me like this.
Mich P.
For this message the author Mich P has received thanks:
Mich P
Re: Zvex Distortron
Postby BrownMagic » 10 Aug 2010, 04:33
Like I said. I couldn't read the values at all, So I just guessed some values that made sense on paper. But if you got some good values Mich, I guess those are a great jumping off point for tweakers.
BrownMagic
Re: Zvex Distortron
Postby culturejam » 10 Aug 2010, 04:56
BrownMagic wrote:Like I said. I couldn't read the values at all, So I just guessed some values that made sense on paper. But if you got some good values Mich, I guess those are a great jumping off point for tweakers.
Most SMD resistors have a code printed on them that is for the value. Check out this page to "decode":
http://www.hobby-hour.com/electronics/4 ... istors.php
culturejam
Has thanked: 462 times
Have thanks: 582 times
Re: Zvex Distortron
Postby BrownMagic » 10 Aug 2010, 06:35
Yeah, I used the resistor codes to verify that the distortron is the Box of Rock minus boost + switches. I'm very certain that I have the switching setups pegged correctly, but if someone disproves me, I'll commit effects hari kari. The values of the caps, I can't tell because they're not marked. And it's not possible to read with my DMM w/o desoldering them. In either case, you can mess with your own cap values. Why make a straight clone when you can do better? Heh
BrownMagic
Users browsing this forum: seppia and 14 guests
