Earthquaker Devices - Ghost Echo  [traced]
Postby entropicp » 19 Dec 2009, 23:30
For anyone who may be interested, here is a gutshot of the Earthquaker Devices Ghost Echo reverb. Just got it today. It sounds nice and natural and I'm quite impressed overall. It can go from subtle to heavy feedbacking reverb if you max out the knobs. Also the build quality is very nice inside and the sparkle finish is quite good although the case is a Chinese 1590BB clone and the screw threads aren't the greatest.
It has a reverb brick on the underside of the PCB, which you can't see in the pictures. I'm guessing it's a Belton, but I'm not sure because I'm not really willing to take it apart to find out. Also the IC's are a TL074CN and a PT2899. Not sure how similar this is to the GGG/Hermida pedal or the Malekko Spring Chicken.
entropicp
Re: Earthquaker Devices Ghost Echo [guts]
Postby newly » 20 Dec 2009, 13:21
Spring Chicken is only 1 knobs and so to Hermida. Thier build are not much deviated from the datasheet circuit.
This one has added PT chips. I wonder what is it used for :scratch:
newly
Have thanks: 2 times
Postby IvIark » 20 Dec 2009, 13:45
newly wrote:Spring Chicken is only 1 knobs and so to Hermida. Thier build are not much deviated from the datasheet circuit.
Does the attack control add a pre-delay to the reverb?
IvIark
Has thanked: 662 times
Have thanks: 675 times
Postby entropicp » 20 Dec 2009, 14:13
Yeah, the attack knob does add pre-delay to the pick attack of the wet signal, which is what I'm guessing the PT2399 chip is there for (excuse the earlier typo). It also seems to have more of an ambient/roomy delay than the Spring Chicken/Hermda ones when you turn up the Depth control. If you have both the Depth and Dwell on high at the same time it starts self-oscillating and feedbacking a bit. I' wondering if the PT2399 is used to add additional delay to the brick on higher settings or just to set the attack knob.
entropicp
Postby madbean » 31 Dec 2009, 12:46
I'm interested in how they are utilizing the PT2399. I've worked through several designs with the Beton now, but I'm still looking to add more ideas. The design I was working on also used a TL074 and used the extra stage to dirty up the echo and feed it back into the input. Kinda 'meh'.
Anyway, if there's anyway you can get a shot of the other side that would be great. The pins on the Belton are very resilient and will desolder easily. If you don't wanna go through the trouble, I totally understand...no worries.
Thanks for the gut shot!
madbean
Postby Lawnchair » 31 Dec 2009, 23:57
can it do a spring sim?
Lawnchair
Have thanks: 16 times
Postby entropicp » 01 Jan 2010, 13:40
madbean wrote:Anyway, if there's anyway you can get a shot of the other side that would be great. The pins on the Belton are very resilient and will desolder easily. If you don't wanna go through the trouble, I totally understand...no worries.
Sorry to be a tease, but I really don't want to take it apart. It cost £135, which is a lot of money for me and my soldering skills can be a bit rough at times so I don't want to risk ruining it. Also, the soldering and construction are very high quality and it would pain me to undo that.
Lawnchair wrote:can it do a spring sim?
Yeah it can do a fairly passable spring reverb on the lower settings. Check out these demos for a better idea:
http://www.earthquakerdevices.com/devices/ghostecho.htm
http://www.youtube.com/watch?v=mmTpSX2cd9o&feature=related
I have to admit that it sounded slightly more convincing on the demos than in person. I'm sure it is pretty similar to the Malekko or Hermida in its spring emulation. I'm using it as my amp reverb throuh the FX loop, since my amp doesn't have a built in reverb. The really interesting thing about this pedal for me is how much it responds to your picking dynamics. If you you pick really hard you get a slapback effect whereas if you pick softly you get more of a classic reverb sound.
entropicp
Postby RnFR » 18 Jan 2011, 13:45
I do like the idea of the belton and the 2399 together. it sounds like an excellent combo.
Has thanked: 150 times
Have thanks: 173 times
Postby solder_blob » 18 Jan 2011, 17:08
With the PT2399, you can almost a get a decent reverb anyways. Maybe they're some how combined or something?
solder_blob
Postby Hides-His-Eyes » 18 Jan 2011, 21:09
I wonder if some of the ouput of the reverb chip is sent back in before the pre-delay maybe?
Hides-His-Eyes
Has thanked: 53 times
Have thanks: 84 times
Postby Motter » 22 Jan 2013, 20:50
Took some photos of mine last night, and desoldered the reverb brick (boy was that a pain) to get some shots of the trace side. I'm working on my own trace, but I thought I'd put up the photos if anyone wants to beat me to it. Let me know if there are any close-ups or measurments you'd like. I'll try and read the cap values tonight, but they're so bunched together some of them might be really hard to see without desoldering
For this message the author Motter has received thanks: 16
bubstance (23 Jan 2013, 09:15), centraleuropean (23 Jan 2013, 13:52), jbgron (23 Jan 2013, 08:07), jrod (22 Jan 2013, 22:26), lohstah (27 Jan 2013, 17:24), Mich P (22 Jan 2013, 23:11), Nocentelli (22 Jan 2013, 21:00), p.eat (22 Jan 2013, 22:09), rocklander (28 Jan 2013, 20:31), tp801 (27 Jan 2013, 20:09) and 6 more users
Motter
Has thanked: 26 times
Have thanks: 92 times
Postby Motter » 23 Jan 2013, 17:46
I've been working on a trace, but it's proving to be rather difficult, because there are a number of traces hidden by caps and ICs on the component side and I've never worked on a circuit this complicated before. I think I can do it, but I might not have much to show until maybe this weekend or next week.
Motter
Postby Motter » 25 Jan 2013, 23:42
Anyone want to take a look at this, and tell me if anything sticks out as blatantly incorrect?
see here for updated schem
Keep in mind this is the first time I've traced or drawn a circuit involving any sort of IC; 90% of my pedals are fuzzes. This one has 5 ICs, including 2 digital ones, so there may still be an error or two.
For this message the author Motter has received thanks: 3
lohstah (27 Jan 2013, 17:24), Mich P (26 Jan 2013, 00:22), rocklander (28 Jan 2013, 20:32)
Motter
Postby Motter » 26 Jan 2013, 02:19
LED is backwards :slap:
Motter
Re: Earthquaker Devices Ghost Echo [guts]  [traced]
Postby Motter » 28 Jan 2013, 20:18
I have revised my schematic to:
-More accurately reflect the switching method used in the pedal
-Correct the LED orientation
-Fix the grounding scheme for the reverb IC. Pins 2 and 4 are internally connected, so pin 2 of the BTDR-2H and pin 2 of the 78L05 are not directly grounded, but grounded through pin 4 on the reverb IC. This was presumably a way to separate the digital ground of the brick from the analog ground of the rest of the circuit. Curiously, there is no separation of the digital and analog grounds on the PT2399, as pins 3 and 4 are soldered directly together on the trace side of the PCB. Also, the ground from pin 6 through the Attack pot (VR1) is decoupled from the 9V supply through a large electrolytic cap.
-I have double-checked every node in this schematic with my multimeter on the actual circuit board, so this schematic is as correct as I can make it. Let me know if you see any issues and I can triple check.
-If the mods can remove the attachment from my previous post, the schematic attached to this post is the revised schematic.
For this message the author Motter has received thanks: 10
Intripped (27 Sep 2014, 13:20), Kingsac (29 Jan 2013, 16:09), Mich P (31 Jan 2013, 22:24), micromegas (17 Mar 2013, 20:13), p.eat (28 Jan 2013, 22:41), roax (30 Jan 2013, 18:49), rocklander (28 Jan 2013, 20:32), Shepherd214 (15 Aug 2013, 17:17), terrapin (12 Feb 2013, 23:40), yudzhin777 (30 Jun 2014, 16:35)
Motter
Postby kodiakklub » 24 Mar 2013, 01:20
VERIFIED!!
notes:
1.the reverb brick gets soldered on the bottom of the board once everything else is soldered on, which includes the lead for the LED+ pad
2. 2 jumpers: A1---->A2 and B1----->B2
For this message the author kodiakklub has received thanks: 9
cdeschenes (24 Mar 2013, 07:08), destro (24 Mar 2013, 17:04), jbgron (24 Mar 2013, 04:50), Mich P (24 Mar 2013, 11:44), Motter (24 Mar 2013, 02:28), Nicht Bernd (22 Jan 2014, 14:06), rocklander (24 Mar 2013, 05:19), ShameOnATrip (22 Sep 2014, 18:54), Shepherd214 (15 Aug 2013, 17:18)
kodiakklub
Have thanks: 10 times
Postby Motter » 24 Mar 2013, 08:41
Does this fit in a 1590B? Any chance you have a spare board? I don't etch but I'd love to build one of these to compare to the store bought one. I haven't looked at your schematic too closely, but did you spot any errors in my trace?
Motter
Postby kodiakklub » 24 Mar 2013, 18:47
you would have to lay the jacks out within a half millimeter of their lives to make it fit in a 125B. it would be incredibly tight.
im pretty sure i copied your schematic part for part. good work on tracing it. i dont have any spare boards. i etch them as i build them. it sounds very "spooky" for a reverb. its a little different but interesting and good.
kodiakklub
Postby destro » 05 Apr 2013, 21:14
Interesting that the new version has two voltage regulators, one for the brick, one for the pt2399.
destro
Have thanks: 34 times
Postby nativetrash » 15 Apr 2013, 20:13
First time poster here - I just built this circuit w/ the PCB transfer & it sounds great except that it knocks my volume in half when I engage the effect. Any idea what could be causing that?
nativetrash
Next
Users browsing this forum: marcelomd, nenecarrizo83 and 13 guests
