Mad Professor Sky Blue Overdrive [traced]
- analogguru
I would think so.ibodog2 wrote:Anyone able to decipher the value from the markings? Would it be a 1K linear?
Try acetone (or the finger-nail remover from your girlfriend or mother).Any tips for removing the neoprene/glue left over on the bottom?
Heat it with a soldering iron an remove it with a pick or little flat screwdriver.How about the hard black gunk at the top?
And when you take another pictures please don´t forget to make one (or more) where the wiring between the pcb and the potis can be seen.... yes and one with the tracks between the FET´s.
- TheLemon
Cool stuff! From some of Bjorn's recent designs, I am guessing that the transistors are used as clippers shunted to ground while the red LEDs are used as clippers in the opamp feedback loop. Although, the OP275 is a dual op amp chip.. hmm.
- culturejam
analogguru wrote: finger-nail remover
Reminds me of that awful torture scene in Syriana where Clooney gets his fingernails pulled out with pliers. Ouch.
I have a few carbon film resistors that are aqua-green and have four color bands. At first I thought they were inductors. But those inductors are usually in the low micro-henry range at that size. Not sure how useful they would be in this context.ibodog2 wrote: Actually, are some of them inductors?
- analogguru
Ooops.... somewhere the word color got lost....culturejam wrote:analogguru wrote: finger-nail remover
should read finger-nail color remover.
- IvIark
COD V1.0 on the PCB?
Dano Coolcat Overdrive clone!
- mictester
Perhaps. More likely "Crap Over Drive V1.0"! I was very disappointed when I tried one of these recently.IvIark wrote:COD V1.0 on the PCB?
- Greg
The plastic parts will melt before the goop is destroyed.. you need to use localised heat.ibodog2 wrote:I was looking on this site for some degooping techniques (in addition to the soldering iron AG mentioned). What do you think would happen if I rigged this board up in a toaster oven component side down over a small pan to try to melt the goop off? How hot do you think it would need to be to melt the goop and not damage the board or components?
- mictester
I was expecting something rather different - these have been hyped so much, I was expecting something special. The "Z" control just loads down the pickups, and just loses some level with modern humbuckers - it's a wasted control. The "Texture" control is a tone control that they got wrong, and decided that because it sounds a bit weird, they can leave it like that. It also hisses more than a modern pedal should. I was not impressed.ibodog2 wrote:Not that I disagree with you, but what were you expecting versus what you heard when you played it?mictester wrote:Perhaps. More likely "Crap Over Drive V1.0"! I was very disappointed when I tried one of these recently.
- Greg
These are 2 things that BJ seems to like to do with his circuits, and I agree that they're often not terribly effective.mictester wrote: I was expecting something rather different - these have been hyped so much, I was expecting something special. The "Z" control just loads down the pickups, and just loses some level with modern humbuckers - it's a wasted control. The "Texture" control is a tone control that they got wrong, and decided that because it sounds a bit weird, they can leave it like that. It also hisses more than a modern pedal should. I was not impressed.
A pot to lower Input Impedance and a non-straight forward Tone Control that only allows limited tones.
- Greg
That's a pretty good description I think.. and the problem is that you can't just add or cut Treble or Bass individually.. which is often needed to suit your other equipment.ibodog2 wrote: On one side the tone is more mid rangey and the other side the highs and lows are hyped. Like a car stereo graphic eq going between smiley face and slight frowny face settings.
- soulsonic
Looks like you probably need to swap the Noninverting and Inverting inputs on the opamp symbols, but other than that, it looks like you're probably more than 80% there. The part with the FETs connected to half the tone control looks strange, but I guess it sorta makes sense....
Actually, looking at this makes me not even care what the actual values are.
- Greg
Yeah I think we've pretty much seen it before.. except it's using the 2nd stage of the opamp for a bit of tone shaping instead of the usual JFet buffer.soulsonic wrote:
And a control on how much clipping the (transistor) diodes to ground do.
- soulsonic
First thing I thought was, "oh, another one of those... nevermind, then."
- Greg
Probably not.. it looks like it just has the RAT style filters.ibodog2 wrote:Sorry for the messy schematic. But yeah I was thinking still it would be good to get the filters on this one. I kept probing around trying to find a feedback loop back to the 1st op amp. But I'm pretty sure there's not one here. If anyone sees evidence of something different from the photos let me know.
BTW - not knocking the work you've done in saying it's nothing much new.. it's appreciated..
Do you like the sound of it ?
- analogguru
The FET-configuration is nothing surprisingly new. It can be found in the Boss MG-80 from 1989.
- RnFR
just a heads up- i think you have to careful when measuring resistors in circuit. you can get some off readings.
- Greg
Yes.. always good to confirm with colours if possible..RnFR wrote:just a heads up- i think you have to careful when measuring resistors in circuit. you can get some off readings.
also, I would suspect the voltage divider resistors are more likely in the 30 to 50 K range.
- analogguru
470k is correct. You forget, that the bias divider is connected directly to the non-inverting input, resulting in a total max. input impedance of only 150k. (47k would give a max. input impedance of < 20k). BTW, I think R2 should be 2M7.Greg_G wrote:Yes.. always good to confirm with colours if possible..RnFR wrote:just a heads up- i think you have to careful when measuring resistors in circuit. you can get some off readings.
