Cornish G2 - Guts, Schematic, Layout (from Tracer's Fund)  [traced]
Postby culturejam » 16 Apr 2010, 18:44
At long last, here are the final results of the Tracer's Fund peek inside the Cornish G2.
Credit goes to Dirk Hendrik for the degoop and circuit trace and testing, and madbean for making up a pretty project file and an original PCB layout. Several other Fund members poked, prodded, and tested various schematics and layouts, and of course all members contributed financially to make the purchase.
An additional PCB layout may be forthcoming.
Have a look-see.
Cornish_G2_DEF.pdf
Reason: Added the corrected and final schematic, re-uploaded board layout and component values pictures
For this message the author culturejam has received thanks: 55
dorfmeister (20 May 2011, 19:12), floris (10 Jun 2018, 14:41), gurishka (23 Jan 2013, 15:53), jlsantamaria (16 Nov 2011, 08:28), lamf (27 Oct 2011, 20:53), PmCimini (16 Jan 2012, 20:51), PokeyPete (25 Feb 2011, 23:00), redstone iii (01 Jul 2012, 10:15), Renegadrian (25 Dec 2011, 02:39), sinner (11 Apr 2013, 11:33) and 45 more users
culturejam
Has thanked: 463 times
Have thanks: 582 times
Re: Cornish G2 - Guts, Schematic, Layout (from Tracer's Fund)
Postby keto » 16 Apr 2010, 19:58
his site has a v1.5 layout up. Did not look for differences.
keto
Postby sinner » 16 Apr 2010, 20:57
60 downloads by last two hours, and no single fucking thank you? You guys rocks! It's so FSBish :roll:
For this message the author sinner has received thanks:
joeboo88 (25 Jan 2012, 01:39)
Has thanked: 1240 times
Have thanks: 1099 times
Postby madbean » 16 Apr 2010, 21:21
Here's the updated version. Changes are only minor layout placements. All thanks go to Dirk for the heavy lifting.
madbean
Postby devastator » 16 Apr 2010, 21:37
thanks !
very bad to see the truth . Just a modded version of big muff :? (even if the additional things can be interesting (input buffer and the different tone control). I don't know but I expected something more "personnal" or "worked" .
devastator
Have thanks: 24 times
Postby bajaman » 16 Apr 2010, 21:39
Once again excellent work by Dirk and Madbean and the fsb contributors fund :applause:
This is yet another example of why freestompboxes.org is THE BEST DIY FORUM on the planet :D
There is a whole LOT of useful information for budding DIYers and "solder jockeys" to learn from this G-2 reverse engineering, not just the electronic design but also the well laid out wiring and earthing practices that Pete Cornish uses. Thanks to all the members here who contributed financially to bring this project to fruition :thumbsup
And to all the other members who have yet to make any financial commitments, I say please consider doing so in the near future - even a very small contribution is always appreciated, and the more contributions, the more research and the faster the results appear for ALL members to share. Please always keep in mind that these results are published for educational and DIY purposes only and they should not be used by anybody wishing to compete commercially with the "reverse engineered" product 8) .
http://www.freestompboxes.org always welcomes healthy discussion and criticism but does not condone any commercial competition resulting from this or any other analysis of a commercial product published on this site.
Okay - now get your soldering iron hot and always remember as Bjorn Juhl of BJF effects says: "have fun!!!!" :thumbsup
Victor Nery (15 Oct 2018, 16:01)
Has thanked: 443 times
Have thanks: 1514 times
Postby ech0es » 16 Apr 2010, 21:48
on the last image we can read "P-2/G-2 Pete Cornish 2005", so he uses the same pcb and layout for the two versions ?
It means the P2 is also a modded muff, but with other variations to have two different sounds
ech0es
Have thanks: 6 times
Postby soulsonic » 16 Apr 2010, 22:01
Even though it's very simple, I like the way the tone control sounds in this circuit. It works just right for the smooth sound. I modded an old Maxon to be like this, and the results were very good.
It is funny how different a circuit can sound by just changing a few parts.
Thanks to Dirk, of course!
Has thanked: 56 times
Have thanks: 275 times
Postby SPeter » 16 Apr 2010, 22:06
EXCELLENT!
THANKS A LOT TO ALL INVOLVED!
:applause: :applause: :applause:
:thumbsup
:D :horsey:
SPeter
Have thanks: 76 times
Postby Jarno » 16 Apr 2010, 22:32
Great work, I was expecting some more electronics niftyness for the amount of money these units go for. And I can object to some aspects of the build, from a mechanical standpoint.
But indeed the best forum in the world for organising things like this!
Edit:
Looking at the pictures, there is one major point, and that's the cable harness. It's really thick and contains quite tight bend radii. It's heavy but not supported by tie-ing it to the enclosure.
Why is it so thick? Is it shielded? Inside an enclosure which is very EMI proof (but chopping a great big hole in it for the battery holder doesn't help, of course)?
Jarno
Have thanks: 8 times
Postby Spewbag » 17 Apr 2010, 01:20
I don't really want to criticize here because 1. I didn't contribute and the people that did all did a great job and 2. I did not add any funds for this project........but next time maybe you guys should pick a pedal that for the most part isn't all ready known. I believe it was common knowledge that this was a tweaked BM and I'm sorry but I find most of the Pete Cornish stuff over hyped any how. :scratch: :hmmm: IMHO a good example was when the community here RE the BlackStone distortion.A relatively unique circuit that had been shrouded for some time.
Just my 2 bits.
Spew
Spewbag
Postby madbean » 17 Apr 2010, 01:51
Just to clarify Spew (lol): I think part of the motivation was to determine just how much of a tweak it was, and also to shed some light on the mysterious Cornish buffer of which there was quite a bit of interest. Second point is that the Blackstone was not a community project, but rather funded by me. Sorry to be picky.
madbean
Postby Spewbag » 17 Apr 2010, 02:33
madbean wrote:Just to clarify Spew (lol): I think part of the motivation was to determine just how much of a tweak it was, and also to shed some light on the mysterious Cornish buffer of which there was quite a bit of interest. Second point is that the Blackstone was not a community project, but rather funded by me. Sorry to be picky.
That's fine, and again I really wasn't trying to be a douche.......It's just that IMHO it wasn't worth the price of admission(that damn stuff is criminally priced). As for muff tweaks....a muff is a muff is a muff. As for the Blackstone I was well aware that you did that(and appreciated it :thumbsup ). I was just using that as an example of a more worthy pedal.
No blood, no foul?
Spew
Spewbag
Postby madbean » 17 Apr 2010, 03:01
No blood, no foul?
Spew
Of course....I was not implying anything like that, I'm sure you know. I have to agree on the totally overpriced BS. But, a large part of his clientele is obviously willing to pay for it (for better or worse). I also absolutely agree that future endeavors could most definitely focus on more original effects. Figuring out what those are is a bit of a challenge on its own!
As an aside, I will eventually get my crap together and get the Mojovibe done. Even though it's not unique, it is awesome sounding.
madbean
Re: NSFW content and a thank you is what you tell your boss!
Postby noelgrassy » 17 Apr 2010, 03:13
Dirk Hendrik & madbean,
You two did an excellent job here. Both scraping and preserving the wee components must have been some task!
Thank you fellas, FSB Tracer Fund and Pete Cornish for the edification you bring us,
Noel Grassy.
For this message the author noelgrassy has received thanks:
protakill (08 Jul 2014, 21:36)
noelgrassy
Have thanks: 3 times
Postby Greg » 17 Apr 2010, 03:32
Spewbag wrote:........but next time maybe you guys should pick a pedal that for the most part isn't all ready known. I believe it was common knowledge that this was a tweaked BM and I'm sorry but I find most of the Pete Cornish stuff over hyped any how. :scratch: :hmmm: IMHO a good example was when the community here RE the BlackStone distortion.A relatively unique circuit that had been shrouded for some time.
Just my 2 bits.
Spew
Well.. the decision is based on a discussion followed by a vote, so Cornish was what people wanted.. admittedly we were hoping for a SS2, but availability made the decision for us.. and I think the result has killed most people's desire to do a Cornish again.
:D
Greg
Has thanked: 77 times
Have thanks: 195 times
Postby Spewbag » 17 Apr 2010, 04:18
Just my 2 bits.
Spew
:D
LOL..........Nuff said I guess. :lol:
Spewbag
Postby Spewbag » 17 Apr 2010, 04:22
No blood, no foul?
Spew
Again, thanks for taking on the glorious burden..........I think one thing good came from this.....Folks out there should now know better to put there money back in there pocket and just say I'll pass.
Spewbag
Postby culturejam » 17 Apr 2010, 05:09
Spewbag wrote:I think one thing good came from this.....Folks out there should now know better to put there money back in there pocket and just say I'll pass.
Maybe. But I think there is some very interesting stuff going on in the G2. The tone control is kinda cool, and using super lower v-drop diodes changes the tone.
And the multi-conductor shielded wire is nice. 8)
culturejam
Postby mattpas » 17 Apr 2010, 05:19
I was wondering if the Sustain pot was a 47kA or a 470kA?
The schematic says 47k but the parts list states 470k
mattpas
Next
Users browsing this forum: Kemu, Pete and 13 guests
